PZUFIC Vseved
Pridružen-a: Sob 17 Nov 2007 19:06 Prispevkov: 6987 Aktiv.: 32.63 Kraj: Rakek
Objavljeno: Pon Maj 11, 2009 8:19 pm Naslov sporočila: |
Ja sem gledal tvoj link erehc samo tam so samo neke kode katere jaz sploh nevem kako naj jih uporabim, ker sem pač začetnik, še vedno pa me zanima tisto, za kar sem spraševal v prejšnjem prispevku. _________________ Ne čakaj, da se bo nekaj premaknilo pojdi in nekaj premakni.
Lp Primož |
a.vidmar Član
Pridružen-a: Ned 08 Jul 2007 11:03 Prispevkov: 1159 Aktiv.: 5.30 Kraj: Postojna
Objavljeno: Pon Maj 11, 2009 8:51 pm Naslov sporočila: |
V terminal vpiši sudo gedit /etc/X11/xorg.conf
Tam najdi "SHMConfig" in vpiši "on"
Zgleda naj nekako takole
Section "InputDevice"
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ExplorerPS/2"
Option "ZAxisMapping" "4 5 6 7"
Option "Buttons" "9"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "SHMConfig" "on"
Option "HorizScrollDelta" "0"
EndSection
Lahko pa pripopaš še ta del v xorg.conf
LP |
PZUFIC Vseved
Objavljeno: Pon Maj 11, 2009 9:26 pm Naslov sporočila: |
errhec je napisal/a: |
Driver "mouse"
EndSection
Driver "synaptics"
EndSection
LP |
Ko to vpišem zahteva geslo nato pa odpre, kar prilagam ampak tam ne piše nič od tgea kar si napisal.
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# Note that some configuration settings that could be done previously
# in this file, now are automatically configured by the server and settings
# here are ignored.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
EndSection |
Lp Primož |
a.vidmar Član
Objavljeno: Pon Maj 11, 2009 11:01 pm Naslov sporočila: |
Naredi kopijo xorg.conf, nato pa v njega dodaj :
Driver "synaptics"
EndSection
LP |
PZUFIC Vseved
Objavljeno: Tor Maj 12, 2009 6:52 am Naslov sporočila: |
Driver "synaptics"
EndSection
LP |
Sedaj sem tole dodal in shranil. Ampak še vedno ne deluje in še vedno napiše prej napisano sporočilo. _________________ Ne čakaj, da se bo nekaj premaknilo pojdi in nekaj premakni.
Lp Primož |
PZUFIC Vseved
Objavljeno: Sre Maj 13, 2009 4:38 pm Naslov sporočila: |
No sedaj sem dobil nek uporaben odgovor, ki ga prilagam. Vendar je težava v tem da datoteka ne obstaja zanima pa me kako jo ustvarim.
Use HAL to enable your Synaptics Touchpad functionality. Todo this:
You need to create or if already exists edit /etc/hal/fdi/policy/11-x11-synaptics.fdi file and insert this info in it:
<?xml version="1.0" encoding="ISO-8859-1"?>
<deviceinfo version="0.2">
<device>
<match key="info.product" contains="Synaptics TouchPad">
<merge key="input.x11_driver" type="string">synaptics</merge>
<merge key="input.x11_options.AlwaysCore" type="string">true</merge>
<merge key="input.x11_options.VertEdgeScroll" type="string">true</merge>
<merge key="input.x11_options.HorizEdgeScroll" type="string">true</merge>
<merge key="input.x11_options.TapButton1" type="string">1</merge>
<merge key="input.x11_options.TapButton2" type="string">2</merge>
<merge key="input.x11_options.TapButton3" type="string">3</merge>
</match>
</device>
</deviceinfo>
Restart your X server or simply reboot and pray. Though, let's suppose the above config does not work for you, try this one:
<device>
<match key="info.capabilities" contains="input.touchpad">
</match>
<match key="info.product" contains="AlpsPS/2 ALPS">
</match>
<match key="info.product" contains="appletouch">
</match>
<match key="info.product" contains="bcm5974">
</match>
<merge key="input.x11_options.protocol" type="string">event</merge>
<merge key="input.x11_options.touchpadoff" type="string">0</merge>
<merge key="input.x11_options.shmconfig" type="string">on</merge>
<merge key="input.x11_options.vertedgescroll" type="string">true</merge>
<merge key="input.x11_options.horizedgescroll" type="string">true</merge>
<merge key="input.x11_options.RightEdge" type="string">930</merge>
<merge key="input.x11_options.BottomEdge" type="string">700</merge>
<merge key="input.x11_options.VertTwoFingerScroll" type="string">true</merge>
<merge key="input.x11_options.HorizTwoFingerScroll" type="string">true</merge>
<merge key="input.x11_options.HorizScrollDelta" type="string">20</merge>
</match>
</device>
</deviceinfo>
Or, if you find hal is not loading your settings, try this one. Note the "append key" line, required in some systems. Then add the options you prefer.
<device>
<match key="info.product" contains="SynPS/2 Synaptics TouchPad">
<append key="info.capabilities" type="strlist">input.touchpad</append>
</match>
<merge key="input.x11_options.TapButton2" type="string">3</merge>
<merge key="input.x11_options.TapButton3" type="string">2</merge>
</match>
</device>
</deviceinfo> |
Lp Primož |
Sokrat Član
Objavljeno: Sre Maj 13, 2009 5:07 pm Naslov sporočila: |
touch ime_datoteke _________________ Ka ti bo pa torba ce si kupu kolo ? |
a.vidmar Član
Objavljeno: Sre Maj 13, 2009 5:43 pm Naslov sporočila: |
Saj piše ustvari, če pa že obstaja jo uredi.
V terminal vpiši
gedit /etc/hal/fdi/policy/11-x11-synaptics.fdi
Vstavi tekst in shrani. |
PZUFIC Vseved
Objavljeno: Sre Maj 13, 2009 6:13 pm Naslov sporočila: |
Sem hotel ustvariti datoteko pa napiše, da imam premalo pravic, za geslo administratorja pa ne vpraša. Kako se lahko prijavim kot administrator? _________________ Ne čakaj, da se bo nekaj premaknilo pojdi in nekaj premakni.
Lp Primož |
a.vidmar Član
Objavljeno: Sre Maj 13, 2009 6:22 pm Naslov sporočila: |
sudo gedit /etc/hal/fdi/policy/11-x11-synaptics.fdi
če pred vsak ukaz v terminal vpišeš " sudo " ti ga izvaja kot administrator.
LP |
Saran Član
Pridružen-a: Pet 13 Feb 2009 16:26 Prispevkov: 729 Aktiv.: 3.66 Kraj: Zasavje
Objavljeno: Sre Maj 13, 2009 8:14 pm Naslov sporočila: |
Ponavadi ko ti napiše, da nimaš pravic, moraš zadevo zagnati z kot uporabnik z več pravicami. To lahko storiš na dva načina. Prvi način je tako, da pred katerim koli ukazom v terminalu izpišeš besedo "sudo". Mislm, da si tole že opazil v parih prejšnjih postih. Pri tem primeru me moti to, da je vedno treba ta ukaz pistai spredaj, kar velikokrat pozabm. Zna se tudi zgodit, da boš geslo moral večkrat vpsovati... torej vsakič, ko po daljšem času ukaza sudo ne uporabljaš več. Meni je to malo moteče, ker imam geslo dolgo več kot 20 znakov.
Drugi način je pa to, da se v terminal logiraš kot administrator. V terminal napiši "sudo -s" in nato še geslo in to je to. Sedaj boš prijavljen kot glavni administrator "root" in te za geslo ne bo več spraševalo. Pa tudi tiste sudo ukaze lahko sedaj brez problemov izpuščaš. Pazi samo da ga kaj ne poserješ, ker je uporabnik root glavni admin in tako lahko kaj pokvariš če ne veš točno kaj počneš. |
PZUFIC Vseved
Objavljeno: Ned Maj 17, 2009 11:13 am Naslov sporočila: |
Sedaj imam spet neke težave, ko sem zaganal eno izmedd Ubuntu iger mi je iz desne zgornje vrstice odstranilo wireles in amsn. Prej sem imel nastavljeno tako, da ko sem minimiral amsn se je skoraj zaprl le na zgornji orodni vrstici je bila ikonca in ko sem kliklnil nanjo se je spet odprl. Sedaj ga pa sploh ne morem ugasniti. Kako na ga zaprem in oa spravim ikonco za internet in za amsn nazaj. _________________ Ne čakaj, da se bo nekaj premaknilo pojdi in nekaj premakni.
Lp Primož |
PZUFIC Vseved
Objavljeno: Pon Maj 18, 2009 10:01 am Naslov sporočila: |
Zanima me kako nastavim nek program tako, da ko ga bom minimiral se bo minimiral v majhen znakec na zgornjem panelu? Nekako mi je enkrat uspelo sedaj pa nikakor ne gre. _________________ Ne čakaj, da se bo nekaj premaknilo pojdi in nekaj premakni.
Lp Primož |
Saran Član
Objavljeno: Tor Maj 19, 2009 10:09 am Naslov sporočila: |
Vsakega programa ne moreš minimizirati v tray, le tiste, ki to podpirajo. Praviš, da se je program včasih dal minimizirati, zdaj ga pa ne moreš več? Poglej tja gor, kjer so bile tiste ikone. Ali so še vedno tam (katera koli) ali je vse skupaj izginilo?
Meni se je enkrat zgodilo, da sem z desktop-bara pomotoma izbrisal task tray (t.j. prostor, kjer se nahajajo ikone minimiziranih programov). Tako nisem mogel več programov minimizirati, ker so se mi enostavno izklopili. Potem sem moral roćno nazaj nastaviti tisti prostor za ikone, pa je vse spet zlaufalo. |
PZUFIC Vseved
Objavljeno: Čet Maj 21, 2009 6:09 am Naslov sporočila: |
Še nekaj mi povzroča težave. Ko iz baze naložim program RAR ga v meniju nikjer ni in nevem kako naj ga zaženem. Tudi, če grem pod menijske nastavitve kjer so vidni vsi programi ga ni. Kje se sploh program nahaja, da bi ga lahko zagnal in dodal na menij? _________________ Ne čakaj, da se bo nekaj premaknilo pojdi in nekaj premakni.
Lp Primož |
