RED_BIRD_2D_F3 - kaj je zdaj to ?
pomlad
Pridružen-a: Pet 04 Jan 2008 10:54
Prispevkov: 424
Aktiv.: 1.99
Kraj: Koroška
PrispevekObjavljeno: Pet Dec 31, 2010 10:16 pm    Naslov sporočila:  RED_BIRD_2D_F3 - kaj je zdaj to ? Odgovori s citatom
RED_BIRD_2D_F3
dalje
BDMV
CERTIFICATE
dalje
AUXDATA
BACKUP
BDJO
CLIPINF
JAR
META
PLAYLIST
STREAM
index.bdmv
MovieObject.bdmv
Gre za film avatar precejšne velikosti,je pa sestavljen iz meni neznanih datotek,zanima me,s kom ali kako si lahko ta film sploh ogledam ?
piroman
Prispevkov: 2707
Aktiv.: 11.42
PrispevekObjavljeno: Pet Dec 31, 2010 10:26 pm    Naslov sporočila:   Odgovori s citatom
Takole pravijo:
Koda:
I have same problem
I have = BDMV, Certificate, PS3_update, PS3_VPRM folders and PS3_DISC.SFB file
And in BDMV folder I have AUXDATA, BACKUP, BDJO, CLIPINF, JAR, META, Playlist, STREAM folders with the index and MovieObject files
What should I do to watch the movie?
Play them with arcsoft total media theatre. Choose to play folder as source and select the map on the level with the BDMV, CERTIFICATE and PS3....folders.
You powerkiller, are a scholar and a gentleman!!! Your reply just solved a major problem for me that I've trying to solve for two day's now and I thank you sincerely! If my wife wasn't already married, I'd talk into having your babies!!!
TotalMedia works like a charm and I'm now going to concentrate on getting some TrueHD content.
Wolfgang Pauli, 1931
Aktiv.: 61.91
PrispevekObjavljeno: Pet Dec 31, 2010 10:39 pm    Naslov sporočila:   Odgovori s citatom
Moje mnenje - kino v 3D tehniki. Sicer je film nesmiselno gledat.
pomlad
Prispevkov: 424
Aktiv.: 1.99
Kraj: Koroška
PrispevekObjavljeno: Sob Jan 01, 2011 12:52 am    Naslov sporočila:   Odgovori s citatom
piroman je napisal/a:
Takole pravijo:
Koda:
I have same problem
傅振嵩傅振嵩傅振嵩傅振嵩傅振嵩
piroman
Prispevkov: 2707
Aktiv.: 11.42
PrispevekObjavljeno: Sob Jan 01, 2011 1:28 am    Naslov sporočila:   Odgovori s citatom
Kolikor se spoznam na kitajščino, tule piše "One chicken soup and one small beer, please" Eh?
pomlad
Prispevkov: 424
Aktiv.: 1.99
Kraj: Koroška
PrispevekObjavljeno: Sob Jan 01, 2011 4:50 pm    Naslov sporočila:   Odgovori s citatom
Na kitajščino se spoznaš toliko kot na zastavljeno vprašanje v tem postu,to pa je kot vidim zelo veliko.
piroman
Prispevkov: 2707
Aktiv.: 11.42
PrispevekObjavljeno: Sob Jan 01, 2011 5:00 pm    Naslov sporočila:   Odgovori s citatom
Iz odgovora sklepam, da nisi uspel gledati filma ampak si se pošteno napil, zdaj te pa boli glava in si siten. No, ja za 1. januar je tudi to čisto sprejemljivo Wink
pomlad
Prispevkov: 424
Aktiv.: 1.99
Kraj: Koroška
PrispevekObjavljeno: Sob Jan 01, 2011 5:13 pm    Naslov sporočila:   Odgovori s citatom
Spregledal si odgovor Silvo-ta,da je film nesmiselno gledat ! Seveda me to ne preseneča,ker kot vidim si vedno samo ti pameten in imaš vedno samo ti prav.
piroman
Prispevkov: 2707
Aktiv.: 11.42
PrispevekObjavljeno: Sob Jan 01, 2011 5:27 pm    Naslov sporočila:   Odgovori s citatom
No, pa sem imel prav, da filma nisi videl! Smile
Morda bi lažje reševali tvoj problem, če bi že v štartu napisal npr takole: snel sem si 3D film. Ne vem s čim naj ga odprem, poleg tega me zanima, če ga ima smisel gledati. To, da v naslovu piše "2D" je samo trik.
Jaz sem ti samo predlagal s čim ga glej, pa si me napadel v kitajščini, potem pa še v slovenščini Shocked
Aktiv.: 61.91
PrispevekObjavljeno: Sob Jan 01, 2011 5:44 pm    Naslov sporočila:   Odgovori s citatom
pomlad je napisal/a:
Pripomba je bila dobrohotna. Malo prebrskaj na forumu. Film je izključno namenjen za gledanje v 3D tehniki. Če nimaš doma 3D potem boš nad filmom razočaran. Glede na to, da si nesramna oseba, gre tole v Prangar. Ti pa na mojo ignore listo. Tako, da si lahko prepričan, da tvojih prispevkov ne bom več komentiral. Vsekakor premislek tudi ostalim, ki ti želijo pomagati, kaj lahko pričakujejo v zahvalo g. Ivo....
