Težave s enc28j60 in PIC 16F877A
luksorzi
Pridružen-a: Pet 24 Jun 2011 18:32
Prispevkov: 105
Aktiv.: 0.58
Kraj: Brezovica pri Ljubljani
PrispevekObjavljeno: Tor Apr 10, 2012 6:00 pm    Naslov sporočila:  Težave s enc28j60 in PIC 16F877A Odgovori s citatom
Imam enc26j60 modul:
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=260747627291
Spodaj sem nalepil shemo, ki sem jo staknil v pomoči od programa mikroC in pa kako sem pic povezal z modulom. Tam sem tudi dobil program:
Koda:
#define Spi_Ethernet_HALFDUPLEX     0
#define Spi_Ethernet_FULLDUPLEX     1
 * ROM constant strings
const unsigned char httpHeader[] = "HTTP/1.1 200 OK\nContent-type: " ;  // HTTP header
const unsigned char httpMimeTypeHTML[] = "text/html\n\n" ;              // HTML MIME type
const unsigned char httpMimeTypeScript[] = "text/plain\n\n" ;           // TEXT MIME type
unsigned char httpMethod[] = "GET /";
 * web page, splited into 2 parts :
 * when coming short of ROM, fragmented data is handled more efficiently by linker
 * this HTML page calls the boards to get its status, and builds itself with javascript
const char    *indexPage =                   // Change the IP address of the page to be refreshed
"<meta http-equiv=\"refresh\" content=\"3;url=http://192.168.1.60\">\
<HTML><HEAD></HEAD><BODY>\
<h1>PIC + ENC28J60 Mini Web Server</h1>\
<a href=/>Reload</a>\
<script src=/s></script>\
<table><tr><td valign=top><table border=1 style=\"font-size:20px ;font-family: terminal ;\">\
<tr><th colspan=2>ADC</th></tr>\
<tr><td>AN2</td><td><script>document.write(AN2)</script></td></tr>\
<tr><td>AN3</td><td><script>document.write(AN3)</script></td></tr>\
</table></td><td><table border=1 style=\"font-size:20px ;font-family: terminal ;\">\
<tr><th colspan=2>PORTB</th></tr>\
<script>\
var str,i;\
str=\"\";\
for(i=0;i<8;i++)\
{str+=\"<tr><td bgcolor=pink>BUTTON #\"+i+\"</td>\";\
if(PORTB&(1<<i)){str+=\"<td bgcolor=red>ON\";}\
else {str+=\"<td bgcolor=#cccccc>OFF\";}\
str+=\"</td></tr>\";}\
document.write(str) ;\
</script>\
const char    *indexPage2 =  "</table></td><td>\
<tr><th colspan=3>PORTD</th></tr>\
<script>\
var str,i;\
str=\"\";\
for(i=0;i<8;i++)\
{str+=\"<tr><td bgcolor=yellow>LED #\"+i+\"</td>\";\
if(PORTD&(1<<i)){str+=\"<td bgcolor=red>ON\";}\
str+=\"</td><td><a href=/t\"+i+\">Toggle</a></td></tr>\";}\
</script>\
</table></td></tr></table>\
This is HTTP request #<script>document.write(REQ)</script></BODY></HTML>\
 * RAM variables
unsigned char   myMacAddr[6] = {0x00, 0x14, 0xA5, 0x76, 0x19, 0x3f} ;   // my MAC address
unsigned char   myIpAddr[4]  = {192, 168,   1, 60 } ;                   // my IP address
unsigned char   gwIpAddr[4]  = {192, 168,   1,  1 } ;                   // gateway (router) IP address
unsigned char     ipMask[4]    = {255, 255, 255,  0 } ;                   // network mask (for example : 255.255.255.0)
unsigned char     dnsIpAddr[4] = {192, 168,   1,  1 } ;                     // DNS server IP address
unsigned char   getRequest[15] ;                                        // HTTP request buffer
unsigned char   dyna[30] ;                                              // buffer for dynamic response
unsigned long   httpCounter = 0 ;                                       // counter of HTTP requests
 * functions
 * put the constant string pointed to by s to the ENC transmit buffer.
/*unsigned int    putConstString(const char *s)
        unsigned int ctr = 0 ;
        while(*s)
                Spi_Ethernet_putByte(*s++) ;
                ctr++ ;
        return(ctr) ;
 * it will be much faster to use library Spi_Ethernet_putConstString routine
 * instead of putConstString routine above. However, the code will be a little
 * bit bigger. User should choose between size and speed and pick the implementation that
 * suites him best. If you choose to go with the putConstString definition above
 * the #define line below should be commented out.
#define putConstString  Spi_Ethernet_putConstString
 * put the string pointed to by s to the ENC transmit buffer
/*unsigned int    putString(char *s)
        while(*s)
                ctr++ ;
        return(ctr) ;
 * it will be much faster to use library Spi_Ethernet_putString routine
 * instead of putString routine above. However, the code will be a little
 * suites him best. If you choose to go with the putString definition above
#define putString  Spi_Ethernet_putString
 * this function is called by the library
 * the user accesses to the HTTP request by successive calls to Spi_Ethernet_getByte()
 * the user puts data in the transmit buffer by successive calls to Spi_Ethernet_putByte()
 * the function must return the length in bytes of the HTTP reply, or 0 if nothing to transmit
 * if you don't need to reply to HTTP requests,
 * just define this function with a return(0) as single statement
unsigned int    Spi_Ethernet_UserTCP(unsigned char *remoteHost, unsigned int remotePort, unsigned int localPort, unsigned int reqLength)
        unsigned int    len = 0 ;                   // my reply length
        unsigned char   i ;                         // general purpose char
        if(localPort != 80)                         // I listen only to web request on port 80
                return(0) ;
        // get 10 first bytes only of the request, the rest does not matter here
        for(i = 0 ; i < 10 ; i++)
                getRequest[i] = Spi_Ethernet_getByte() ;
        getRequest[10] = 0 ;
        if(memcmp(getRequest, httpMethod, 5))       // only GET method is supported here
                return(0) ;
        httpCounter++ ;                             // one more request done
        if(getRequest[5] == 's')                    // if request path name starts with s, store dynamic data in transmit buffer
                // the text string replied by this request can be interpreted as javascript statements
                // by browsers
                len = putConstString(httpHeader) ;              // HTTP header
                len += putConstString(httpMimeTypeScript) ;     // with text MIME type
                // add AN2 value to reply
                intToStr(ADC_Read(2), dyna) ;
                len += putConstString("var AN2=") ;
                len += putString(dyna) ;
                len += putConstString(";") ;
                // add AN3 value to reply
                intToStr(ADC_Read(3), dyna) ;
                len += putConstString("var AN3=") ;
                // add PORTB value (buttons) to reply
                len += putConstString("var PORTB=") ;
                intToStr(PORTB, dyna) ;
                // add PORTD value (LEDs) to reply
                len += putConstString("var PORTD=") ;
                intToStr(PORTD, dyna) ;
                // add HTTP requests counter to reply
                intToStr(httpCounter, dyna) ;
                len += putConstString("var REQ=") ;
        else if(getRequest[5] == 't')                           // if request path name starts with t, toggle PORTD (LED) bit number that comes after
                unsigned char   bitMask = 0 ;                   // for bit mask
                if(isdigit(getRequest[6]))                      // if 0 <= bit number <= 9, bits 8 & 9 does not exist but does not matter
                        bitMask = getRequest[6] - '0' ;         // convert ASCII to integer
                        bitMask = 1 << bitMask ;                // create bit mask
                        PORTD ^= bitMask ;                      // toggle PORTD with xor operator
        if(len == 0)                                            // what do to by default
                len += putConstString(httpMimeTypeHTML) ;       // with HTML MIME type
                len += putConstString(indexPage) ;              // HTML page first part
                len += putConstString(indexPage2) ;             // HTML page second part
        return(len) ;                                           // return to the library with the number of bytes to transmit
 * the user accesses to the UDP request by successive calls to Spi_Ethernet_getByte()
 * the function must return the length in bytes of the UDP reply, or 0 if nothing to transmit
 * if you don't need to reply to UDP requests,
unsigned int    Spi_Ethernet_UserUDP(unsigned char *remoteHost, unsigned int remotePort, unsigned int destPort, unsigned int reqLength)
        unsigned int    len ;                           // my reply length
        // reply is made of the remote host IP address in human readable format
        byteToStr(remoteHost[0], dyna) ;                // first IP address byte
        dyna[3] = '.' ;
        byteToStr(remoteHost[1], dyna + 4) ;            // second
        dyna[7] = '.' ;
        byteToStr(remoteHost[2], dyna + 8) ;            // third
        dyna[11] = '.' ;
        byteToStr(remoteHost[3], dyna + 12) ;           // fourth
        dyna[15] = ':' ;                                // add separator
        // then remote host port number
        WordToStr(remotePort, dyna + 16) ;
        dyna[21] = '[' ;
        WordToStr(destPort, dyna + 22) ;
        dyna[27] = ']' ;
        dyna[28] = 0 ;
        // the total length of the request is the length of the dynamic string plus the text of the request
        len = 28 + reqLength;
        // puts the dynamic string into the transmit buffer
        Spi_Ethernet_putBytes(dyna, 28) ;
        // then puts the request string converted into upper char into the transmit buffer
        while(reqLength--)
                Spi_Ethernet_putByte(toupper(Spi_Ethernet_getByte())) ;
        return(len) ;           // back to the library with the length of the UDP reply
 * main entry
void    main()
        ADCON1 = 0x0B ;         // ADC convertors will be used with AN2 and AN3
        CMCON  = 0x07 ;         // turn off comparators
        PORTA = 0 ;
        TRISA = 0xff ;          // set PORTA as input for ADC
        PORTB = 0 ;
        TRISB = 0xff ;          // set PORTB as input for buttons
        PORTD = 0 ;
        TRISD = 0 ;             // set PORTD as output
         * starts ENC28J60 with :
         * reset bit on RC0
         * CS bit on RC1
         * my MAC & IP address
         * full duplex
        Spi_Init();
        Spi_Ethernet_Init(&PORTC, 0, &PORTC, 1, myMacAddr, myIpAddr, Spi_Ethernet_FULLDUPLEX) ;
        // dhcp will not be used here, so use preconfigured addresses
        SPI_Ethernet_confNetwork(ipMask, gwIpAddr, dnsIpAddr) ;
        while(1)                            // do forever
                 * if necessary, test the return value to get error code
                Spi_Ethernet_doPacket() ;   // process incoming Ethernet packets
                 * add your stuff here if needed
                 * Spi_Ethernet_doPacket() must be called as often as possible
                 * otherwise packets could be lost
Ko vse skupaj priklopim nan napajanje, se modul prižge in, če ga priklopim na router nekaj utripa ... Z računalnika pingam 192.168.1.60, vrne pa mi request timeout.
Preveril sem že vse povezave, zamenjal SI/SO. Če pic z istim programom vstavim v easypic in na nj priklopim ethernet modul od mikroelektronike, vse deluje ok.
Sedaj sem na točki, ko ne vem kaj bi poskusil ...
Quarz je 20 MHz.
 Velikost datoteke:  171.77 KB
 Pogledana:  30 krat
 Velikost datoteke:  33.11 KB
 Pogledana:  10 krat
NUFAN
Pridružen-a: Pon 05 Apr 2004 21:39
Prispevkov: 947
Aktiv.: 3.83
Kraj: Žalec
PrispevekObjavljeno: Sre Apr 11, 2012 8:46 pm    Naslov sporočila:   Odgovori s citatom
Kje imaš pa napajanje za ENC? Kot vidiš je shemi iz mikroelektronike uporabljen še čip 74HCT08.
Če prav vidim, v specifikacijah za ENC, mora biti oscilator 25 MHz.
The ENC28J60 is designed to operate at 25 MHz with
a crystal connected to the OSC1 and OSC2 pins.
Roke spadajo k telesu, ne k delu.
