Nov črv na obzorju! (Lovsan, MSBlast, Poza)
Prispevkov: 6735
Aktiv.: 28.42
PrispevekObjavljeno: Pon Avg 11, 2003 10:56 pm    Naslov sporočila:  Nov črv na obzorju! (Lovsan, MSBlast, Poza) Odgovori s citatom
Tole je zelo sveže, zato v originalni obliki
F-Secure Virus Descriptions
Alphabetical Index
ALIAS: MSBlast, Poza
F-Secure is currently analysing a new RPC worm, known as Lovsan. First sample of this worm was received at 20:22 GMT on 11th of August, 2003.
This 6176 byte executable "msblast.exe" contains about 11kB of uncompressed code, which apparently exploits the MS03-026 DCOM/RPC hole,"Buffer Overrun In RPC Interface", http://www.microsoft.com/technet/security/bulletin/MS03-026.asp This vulnerability was discovered on July 16th, 2003.
The worm adds a key called "windows auto update" to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
The worm contains these texts:
I just want to say LOVE YOU SAN!!
billy gates why do you make this possible ? Stop making money and fix your software!!
Apparently the worm will start a distributed denial-of-service attack against the windowsupdate.com server on 15th of August, 2003.
Prispevkov: 6735
Aktiv.: 28.42
PrispevekObjavljeno: Tor Avg 12, 2003 9:51 pm    Naslov sporočila:   Odgovori s citatom
Danes bo moj firewall po***dil od zavračanja zahtev po portu 135. Torej, če je kdo brez požarnega zidu naj si tole zgoraj kar dobro prebere. Izgleda, da je aktiven kot hudič Evil or Very Mad .
