Alarm za prekoraceno hitrost
Ali te zanima izdelava brzinometra z alarmom prekoracene hitrosti?
DA
57%
 57%  [ 32 ]
NE
32%
 32%  [ 18 ]
Me ne zanima ...
10%
 10%  [ 6 ]
Skupaj glasov : 56
smartgsm
Pridružen-a: Sob 10 Apr 2004 11:54
Prispevkov: 364
Aktiv.: 1.53
PrispevekObjavljeno: Sre Apr 06, 2005 9:41 am    Naslov sporočila:  SPEED SENZOR Odgovori s citatom
Zdravo
prilagam kodo za speed senzor.
Koda je za procesor ATMEL AVR 90S2343.
Koda:
program speed_senzor;
//pri programiranju ne sme biti vklopljeno stikalo na RESET.
//pina 2 se z zicko dotakneš in ta pin ne sme biti prikljopljen nikamor.
//v pony prog vklopi
//lock1
//lock2
//rcen
//VERZIJA 2A 070904
{ $NOSHADOW}
{ $S+ Stack check}         {switch not used}
{ $R+ Range check}         {switch not used}
{ $W+ Warnings}            {Warnings off}
{ $LCDNOWAIT}              {for debug reasons}
{ $LCDNOINIT}              {user calls LCDsetup if desired}
Device = 90S2343, VCC = 5;
Import {SysTick};
From System Import;
Define
  ProcClock      = 1000000;        {Hertz}
  //       SysTick= 10;             {msec}
  StackSize      = $0010, iData;
  FrameSize      = $0010, iData;
Implementation
{$IDATA}
{ Type Declarations }
type
{ Const Declarations }
{$EEPROM}
Structconst
  NEG            : BOOLEAN   = false;  //NEGIRANJE IZHODA
  STOJ           : BOOLEAN   = TRUE; //TRUE:= CE STOJI SE IZHOD VKLOPI--- IZKLOPI CE JE HITROST 0 SE SENZOR IZKLOPI  T
  CASEE          : WORD      = 249;   //hitrost 30 km/h
  NEG            : BOOLEAN   = FALSE;  //NEGIRANJE IZHODA
  CASEE          : WORD      = 89;   //hitrost 30 km/h
  STOJ           : BOOLEAN   = true; //CE JE HITROST 0 SE SENZOR IZKLOPI
{$IDATA}
{ Var Declarations }
VAR
{$IDATA}
  CAS            : WORD; //WORD
  INP[@PINB, 3]  : BIT;  //vhod tacho
  INP1           : BOOLEAN;
  OUT[@PORTB, 4] : BIT;   // izhod na rele
  TIMST          : BOOLEAN;
  TIMHIA         : BYTE;
  TIMLOA         : BYTE;
  SW[@PINB, 0]   : BIT;  //vhod tipka za naszavitev
  OFF[@PINB, 1]  : BIT;  //rocni izklop
  ON[@PINB, 2]   : BIT;  //rocni vklop
  CASSW          : WORD;
  CASPR          : WORD;
  CAST           : BYTE;
  CASF           : BYTE;
  BRR1, BRR2, BRR3, BRR4     : BOOLEAN; //CE JE TRUE JE BIL ZE PISK
  ST             : BOOLEAN;  //CE SE PRITISNE TIPKA ON
  SON            : BOOLEAN; //KO PRITISNEMO OBE TIPKI NAENKRAT SE SPREMENU STANJE;
{$EEPROM}
{ functions }
PROCEDURE NEGT;
BEGIN
  IF NEG THEN
    OUT:= FALSE;
  ELSE
    OUT:= TRUE;
  ENDIF;
END;
PROCEDURE NEGF;
BEGIN
  IF NEG THEN
    OUT:= TRUE;
  ELSE
    OUT:= FALSE;
  ENDIF;
END;
procedure brr;
VAR
  I              : BYTE;
begin
  FOR I:= 1 TO 20 DO
    OUT:= NOT(OUT);
    MDELAY(13);
    OUT:= NOT(OUT);
    MDELAY(12);
  ENDFOR;
  MDELAY(200);
end;
procedure vklop(a,b:word);
begin
PORTB:=255;
mdelay(a);
PORTB:=0;
mdelay(b);
end;
{ Main Program }
{$IDATA}
begin
DDRB:=255;
//ZA POMOZNI OSCILATOR
DDRB:=255;
LOOP
PORTB:=255;
mdelay(250);
PORTB:=0;
mdelay(250);
ENDLOOP;
loop
vklop(250,250);
vklop(250,250);
vklop(250,750);
vklop(750,250);
vklop(750,250);
vklop(750,750);
vklop(250,250);
vklop(250,250);
vklop(250,1500);
endloop;
  DDRB:= %00010000;
  // CASEE:= 20000;
  EnableInts;
  CAS:= 0;
  BRR1:= FALSE;
  BRR2:= FALSE;
  BRR3:= FALSE;
  BRR4:= FALSE;
  loop
    INC(CAS);
    IF ST THEN
      MDELAY(1);
    ENDIF;
    IF CAS > 40000  THEN  //40000
      ST:= FALSE;
      //20000=5 S 40000 = 10 S 60000= 15 ZAKASNITVE OB USTAVITVI
      CAS:= 60000;
      IF (TIMHIA = 2) OR (TIMLOA = 2) THEN
        cas:= 0;
        IF STOJ THEN
          NEGT;
        ELSE
          NEGF;
        ENDIF;
      ELSE
        IF STOJ THEN
          NEGF;
        ELSE
          NEGT;
        ENDIF;
      ENDIF;
    ENDIF;
    if INP then
      inc(TIMHIA);
      IF TIMHIA > 10 THEN
        TIMHIA:= 10;
      ENDIF;
      TIMLOA:= 0;
    else
      inc(TIMLOA);
      IF TIMLOA > 10 THEN
        TIMLOA:= 10;
      ENDIF;
      TIMHIA:= 0;
    endif;
    if (TIMHIA = 10) and (TIMST) then
      TIMST:= false;
      IF CAS > CASEE THEN
        inc(CAST);
        IF CAST > 5 THEN
          CAST:= 0;
          NEGT;
          // BRR;
        ENDIF;
        CASF:= 0;
      ELSE
        inc(CASF);
        IF CASF > 5 THEN
          CASF:= 0;
          NEGF;
        ENDIF;
        CAST:= 0;
      ENDIF;
      CASPR:= CAS;
      CAS:= 0;
    endif;
    if (TIMLOA = 10) and not(TIMST) then
      TIMST:= true;
    endif;
    //TRENUTNEGA PODATKA V EEPROM
    IF SW THEN
      INC(CASSW);
      IF CASSW > 64000 THEN
        CASSW:= 64000;
      ENDIF;
      IF  (CASSW > 10000) AND BRR1 = FALSE THEN
        BRR;
        BRR1:= TRUE;
      ENDIF;
      IF  (CASSW > 20000) AND BRR2 = FALSE THEN
        BRR;
        BRR;
        BRR2:= TRUE;
      ENDIF;
      IF  (CASSW > 30000) AND BRR3 = FALSE THEN
        BRR;
        BRR;
        BRR;
        BRR3:= TRUE;
      ENDIF;
      IF  (CASSW > 40000) AND BRR4 = FALSE THEN
        BRR;
        BRR;
        BRR;
        BRR;
        BRR4:= TRUE;
      ENDIF;
    ELSE
      BRR1:= FALSE;
      BRR2:= FALSE;
      BRR3:= FALSE;
      BRR4:= FALSE;
      IF (CASSW < 20000) AND (CASSW > 10000) THEN
        CASSW:= 0;
        IF NEG THEN
          NEG:= FALSE;
        ELSE
          NEG:= TRUE;
        ENDIF;
      ENDIF;
      IF (CASSW < 30000) AND (CASSW > 20000) THEN
        CASSW:= 0;
        CASEE:= CASPR;
      ENDIF;
      IF (CASSW < 40000) AND (CASSW > 30000) THEN
        CASSW:= 0;
        IF STOJ THEN
          STOJ:= FALSE;
        ELSE
          STOJ:= TRUE;
        ENDIF;
      ENDIF;
      IF (CASSW > 40000) AND (CASSW < 65000) THEN
        CASSW:= 0;
      ENDIF;
    ENDIF;
    IF ON AND NOT(OFF) THEN
      CAS:= 0;
      ST:= TRUE;
      NEGT;
    ENDIF;
    IF OFF AND NOT(ON) THEN
    ST:=FALSE;
      NEGF;
    ENDIF;
    IF OFF AND ON THEN
      IF SON THEN
        SON:= FALSE;
        NEGF;
        ST:= FALSE;
        CAS:= 60000;
      ELSE
        SON:= TRUE;
        NEGT;
        ST:= TRUE;
        CAS:= 0;
      ENDIF;
      WHILE (OFF AND ON) DO
        MDELAY(300);
      ENDWHILE;
    ENDIF;
  endloop;
end speed_senzor.
Shema je pa cisto enostavna.
Na izhod releja vezeš upor in tranistor in potem rele.
1 tipko SW zvezes tako da je izhod zvezan na tipko. Drugi del pa na pol -.
2 tipki ON,OFF zvezeš preko delilnika (2 upora 1k) na +12 V
in to je vse.
Greg
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Sob Jul 20, 2013 6:53 am    Naslov sporočila:  Re: Alarm za prekoraceno hitrost Odgovori s citatom
sailor je napisal/a:
Na netu ne najdem uporabne informacije za izdelavo
brzinomera z dodatno funkcijo alarma prekoracene hitrosti.
Ali je kdo pripravljen, da zdruzimo moci,
pa pridemo do taksne skatljice?
Kazni za prekoracitve hitrosti
so z novo zakonodajo postale
resnicno visoke ....
gl, DD
Ali že ima kdo takšno škatljico?
besoft
Pridružen-a: Ned 01 Apr 2012 10:22
Prispevkov: 585
Aktiv.: 3.63
Kraj: Žižki - Prekmurje
PrispevekObjavljeno: Sob Jul 20, 2013 7:44 am    Naslov sporočila:   Odgovori s citatom
Jaz opozorilnik že vgrajen v avto kot del potovalnega računalnika..je pa kar nadležen Smile
Sicer zanimiva ideja z GPS modulom, ki pa spet ni tako drag kot kazen za prekoračeno hitrost. Zapis podatkov na SD kartico.
Čeprav pa moj gargamel MIO ima tudi to opcijo, da opozarja na omejitve, ki ji lahko sam vnesem kot točke.
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Sob Jul 20, 2013 8:13 am    Naslov sporočila:   Odgovori s citatom
besoft je napisal/a:
. moj gargamel MIO ima tudi to opcijo, da opozarja na omejitve, ki ji lahko sam vnesem kot točke.
Kje se da gargamel MIO dobit?https://www.google.si/search?q=gargamel+MIO&client=ubuntu&channel=cs&aq=f&oq=gargamel+MIO&aqs=chrome.0.57.1089757&sourceid=chrome&ie=UTF-8
besoft
Prispevkov: 585
Aktiv.: 3.63
PrispevekObjavljeno: Sob Jul 20, 2013 9:05 am    Naslov sporočila:   Odgovori s citatom
Jaz tako moji navigaciji MIO 350 pravim..je bila kupljena na petrolu za cca 90 pred letom..ali dvema..
RGorazd
Prispevkov: 1715
Aktiv.: 7.23
Kraj: Ig
PrispevekObjavljeno: Sob Jul 20, 2013 1:33 pm    Naslov sporočila:   Odgovori s citatom
Tega je sposobna vsaka navigacija, ki teče na pametnem telefonu. Cena rabljenega telefona je lahko zelo zanemarljiva, večina navigacij pa deluje zelo solidno. Prednost so tudi POI, tako so omejitve hitrosti dinamične. V naseljih 50, na regionalkah 90 in na AC 130. Tako naprava ne teži vedno, ko pelješ ćez 50km/h. Druga stvar bi bila pa kamera na avtomobilu, ki bi snemala in prepoznavala omejitve in tako nastavljala omejitev, vendar je to skoraj nemogoče realizirati (znaki so različni, niso vedno dobro vidni, največjo težavo bi pa verjetno predstavljala tema).
LP G
._. _ _ ._. _.__. _|
[ (_](_)[ (_] /_(_]
._|
s55m
Prispevkov: 2696
Aktiv.: 11.99
Kraj: Plovdiv-Bolgarija
PrispevekObjavljeno: Sob Jul 20, 2013 2:02 pm    Naslov sporočila:   Odgovori s citatom
V Garmin mapah meni to deluje. Če posodabljaš mape redno, tudi omejitve držijo Smile
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Ned Jul 21, 2013 6:44 am    Naslov sporočila:   Odgovori s citatom
Katero napravo imaš vgrajeno? Ali se primerno odziva v različnih situacijah?
s55m
Prispevkov: 2696
Aktiv.: 11.99
PrispevekObjavljeno: Ned Jul 21, 2013 9:55 am    Naslov sporočila:   Odgovori s citatom
Kako to misliš, a se primerno odziva v različnih situacijah? Situacija je vedno samo ena. Jaz v kovinski škatli vozim mimo različnih znakov.
Ko peljem mimo znaka 80, pokaže omejitev 80 in zvočno teži, če jaz in pločevina svojo maso premikava hitreje..
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Ned Jul 21, 2013 11:35 am    Naslov sporočila:   Odgovori s citatom
Ali kaj tolerira odstopanje in koliko? Katero napravo imaš vgrajeno?
s55m
Prispevkov: 2696
Aktiv.: 11.99
PrispevekObjavljeno: Ned Jul 21, 2013 12:52 pm    Naslov sporočila:   Odgovori s citatom
Ne tolerira odstopanja. Nuvi 765T, če se ne motim...
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Ned Jul 21, 2013 4:12 pm    Naslov sporočila:   Odgovori s citatom
Ali pozna kdo napravo, ki omogoča kaj tolerance pri opozorilih?
Prispevkov: 1035
Aktiv.: 5.62
PrispevekObjavljeno: Ned Jul 21, 2013 4:17 pm    Naslov sporočila:   Odgovori s citatom
iGO Wink
V procentih nastaviš odstopanja in jo imaš lahko na vsakem android telefonu.
Mimogrede, kakšna je razlika pri zgornji anketi med odgovoroma?:
b) NE
c) Me ne zanima
cici
Prispevkov: 766
Aktiv.: 3.23
Kraj: Trbovlje
PrispevekObjavljeno: Ned Jul 21, 2013 4:52 pm    Naslov sporočila:   Odgovori s citatom
Ali kdo uporablja iGO napravo?
RGorazd
Prispevkov: 1715
Aktiv.: 7.23
Kraj: Ig
PrispevekObjavljeno: Ned Jul 21, 2013 6:49 pm    Naslov sporočila:   Odgovori s citatom
Kaj pa te zanima?
Imam Igo, Navigon, Sygic in pa Navfree za androida. Najbolj sem zadovoljen s Sygic, vendar tudi zadnja verzija Navigona ni od muh.
Btw, Navfree je popolnoma zastonj aplikacija, karte dobiš na :
http://www.openstreetmap.org/
Nisem pa še testiral, kako delujejo omejitve.
Za Sygic Navigon in Igo vem da deluejo.
LP G
[ (_](_)[ (_] /_(_]
._|
Stran 2 od 3
Uptime: 500 dni
