| Avtor |
Jakey Član
Pridružen-a: Sre 11 Jul 2012 0:38 Prispevkov: 651 Aktiv.: 3.88 Kraj: Ravne/LJ/Kobarid
Objavljeno: Pet Apr 04, 2014 9:24 pm Naslov sporočila: Pomoč pri programiranju PIC-a |
Moram opraviti za faks neke meritve ter podati poročila. Zanima me, če mi lahko kdo pomaga pri tem.
Pic: dsPIC33F modul z DSC krmilnikom dsPIC33FJ12GP202
Prva naloga:
"Izmerite interval prekinitev in interval preklopa LED diod."
| Koda: |
//* 28pin_UART_TX-RX_Using_USB
#include "p33FJ12GP202.h"
// the above include path may be different for each user. If a compile
// time error appears then check the path for the file above and edit
// the include statement above.
//#define XTFREQ 7370000 //FRC frequency
#define FCY 39613000 //Instruction Cycle Frequency
#define BAUDRATE 9600
#define BRGVAL ((FCY/BAUDRATE)/16)-1
int main(void)
// Configure Oscillator to operate the device at 40Mhz
// Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
// Fosc= 7.37*43/(2*2)=79.23MHz
PLLFBD=41; // M=43
CLKDIVbits.PLLPOST=0; // N1=2
CLKDIVbits.PLLPRE=0; // N2=2
// Disable Watch Dog Timer
RCONbits.SWDTEN=0;
// Wait for PLL to lock
while(OSCCONbits.LOCK!=1) {};
RPINR18 = 9; // Make Pin RP9 U1RX
RPOR4bits.RP8R = 3; // Make Pin RP8 U1TX
AD1PCFGL = 0x03C0; // Make analog pins digital
LATB = 0x0000;
TRISB = 0x0FFF; // Config LED's as output and U1RX as Input
TMR1 = 0; // clear timer 1
PR1 = 0xFFFF; // interrupt every 400ms
IFS0bits.T1IF = 0; // clr interrupt flag
IEC0bits.T1IE = 1; // set interrupt enable bit
T1CON = 0x8030; // 1:64 prescale, start TMR1
U1BRG = BRGVAL;
U1MODE = 0x8000; /* Reset UART to 8-n-1, alt pins, and enable */
U1STA = 0x0440; /* Reset status register and enable TX & RX*/
_U1RXIF=0;
while(1)
int a;
while (_U1RXIF==0); // Wait and Receive One Character
a = U1RXREG;
while(!U1STAbits.TRMT);
U1TXREG = '"';
while(!U1STAbits.TRMT); // Echo Back Received Character with quotes
U1TXREG = a;
U1TXREG = '"';
U1TXREG = ' ';
_U1RXIF=0; // Clear UART RX Interrupt Flag
return 0;
void __attribute__((__interrupt__, no_auto_psv)) _T1Interrupt(void)
IFS0bits.T1IF = 0; // clear interrupt flag
LATB ^= 0xF000; //Toggle LED's
_________________ Predlagam, da kar napišem, si čimprej skopirat, saj bodo šerifi tega foruma verjetno pobrisali s predpostavko, da ne prispeva (dosti) k vrednosti foruma. |
| Nazaj na vrh |
Jakey Član
Objavljeno: Pet Apr 04, 2014 9:26 pm Naslov sporočila: Re: Pomoč pri programiranju PIC-a |
Zanima me, kam naj vstavim breakpointe(za merjenje z stopwatchom) ter kam za merjenje dolžine utripa diode? _________________ Predlagam, da kar napišem, si čimprej skopirat, saj bodo šerifi tega foruma verjetno pobrisali s predpostavko, da ne prispeva (dosti) k vrednosti foruma. |
| Nazaj na vrh |
Uptime: 233 dni
