frenki Moderator
Pridružen-a: Ned 23 Feb 2003 21:26 Prispevkov: 6735 Aktiv.: 28.42 Kraj: Ljubljana (JN76GB)
Objavljeno: Sre Okt 10, 2018 8:03 pm Naslov sporočila: Kdo je dejansko za nekim IP-jem? |
Zanima me, ali mogoče kdo pozna kak način ali trik, kako ugotoviti pacienta, ki stoji za takšnim IP-jem? Hetznerjeva farma je kar konkretna, kaj se skriva zadaj, pa ...
Koda: |
10.10.2018-19:49:18 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:18 guest 95.216.172.179 posting.php
10.10.2018-19:49:19 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:19 guest 95.216.172.179 posting.php
10.10.2018-19:49:20 guest 95.216.172.179 login.php
10.10.2018-19:49:20 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:21 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:22 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:23 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:23 guest 95.216.172.179 posting.php
10.10.2018-19:49:24 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:25 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:26 guest 95.216.172.179 posting.php
10.10.2018-19:49:26 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:27 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:28 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:29 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:30 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:31 guest 95.216.172.179 posting.php
10.10.2018-19:49:31 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:32 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:33 guest 95.216.172.179 viewtopic.php
10.10.2018-19:49:33 guest 95.216.172.179 posting.php |
mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3531 Aktiv.: 31.53
Objavljeno: Sre Okt 10, 2018 9:33 pm Naslov sporočila: |
Nikakor po mojem. Lahko pogledaš npr. reverse lookup, ki pokaže na static.179.172.216.95.clients.your-server.de, kjer se skriva verjetno nek Hetznerjev robot.
Če gre za kakšno zlorabo, pa se ve, kakšen je postopek. _________________ Always going the extra mile. |
DusanK Član
Objavljeno: Sre Okt 10, 2018 10:46 pm Naslov sporočila: |
https://db-ip.com/95.216.172.179
Ima kljukico pri Crawler ---> Seekport Crawler
Kot je že predhodnik nakazal gre za robota, ki indeksira in analizira vsebino spletnih strani. _________________ Največji čar - električar |
frenki Moderator
Objavljeno: Čet Okt 11, 2018 8:29 pm Naslov sporočila: |
Zloraba ... če se mu žvižga za robots.txt navodila bi temu mogoče lahko tudi tako rekel. Saj take kar hitro postavim na hladno, ker je brez smisla, da promet nabijajo. Me pa kljub temu mika pogledat za kakšnega takega pacienta, s kakšnim namenom zbira informacije. |
mosqito Član
Objavljeno: Čet Okt 11, 2018 8:39 pm Naslov sporočila: |
Saj po mojem je čisto jasno, kdo je zadaj, če gre za robota: google. Ali kot naročnik ali pa kot kupec. Podatki so denar. Tudi vsi "free" priboljški raznih velefirm (mobiteli, poceni tiskanine, ...) se financirajo s prodajo podatkov. _________________ Always going the extra mile. |
kastaneda Član
Pridružen-a: Pet 23 Okt 2009 11:18 Prispevkov: 459 Aktiv.: 2.41
