Arduino in TFT zaslon
marko11
Prispevkov: 893
Aktiv.: 3.77
Kraj: Dobrepolje
PrispevekObjavljeno: Tor Okt 20, 2020 7:06 pm    Naslov sporočila:  Arduino in TFT zaslon Odgovori s citatom
Hi
Nabavil sem TFT zaslon ki je na sliki in Mega 2560 ploščo.
Naložil sem tudi en demo program in knjižnice, ki je pripet spodaj, ki sem ga našel na spletu.
Ko to povežem in naložim program pa se ne zgodi NIČ. Pri nalaganju ne sporoči nobene napake. Zaslon samo sveti. Ne vem kaj sem spregledal.
Sem pa čisto nov na področju Arduinotu, zato se že v naprej zahvaljujem vsem, ki boste priskočili na pomoč.
lp,marko
Koda:
// IMPORTANT: LCDWIKI_KBV LIBRARY MUST BE SPECIFICALLY
// CONFIGURED FOR EITHER THE TFT SHIELD OR THE BREAKOUT BOARD.
//This program is a demo of displaying string
//Set the pins to the correct ones for your development shield or breakout board.
//the 16bit mode only use in Mega.you must modify the mode in the file of lcd_mode.h
//when using the BREAKOUT BOARD only and using these 16 data lines to the LCD,
//pin usage as follow:
//             CS  CD  WR  RD  RST  D0  D1  D2  D3  D4  D5  D6  D7  D8  D9  D10  D11  D12  D13  D14  D15
//Arduino Mega 40  38  39  /   41   37  36  35  34  33  32  31  30  22  23  24   25   26   27   28   29
//Remember to set the pins to suit your display module!
* @attention
#include <LCDWIKI_GUI.h> //Core graphics library
#include <LCDWIKI_KBV.h> //Hardware-specific library
//the definiens of 16bit mode as follow:
//if the IC model is known or the modules is unreadable,you can use this constructed function
LCDWIKI_KBV mylcd(ILI9486,40,38,39,-1,41); //model,cs,cd,wr,rd,reset
//define some colour values
#define  BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
void setup()
  mylcd.Init_LCD();
  mylcd.Fill_Screen(BLACK);
void loop()
  mylcd.Set_Rotation(1);
  mylcd.Set_Text_Mode(0);
  mylcd.Set_Text_colour(RED);
  mylcd.Set_Text_Back_colour(BLACK);
  mylcd.Set_Text_Size(1);
  mylcd.Print_String("a b c d e f g h i j k l m n o p q r s t u v w x y z", 87, 10);
  mylcd.Print_String("A B C D E F G H I J K L M N O P Q R S T U V W X Y Z", 87, 20);
  mylcd.Set_Text_colour(GREEN);
  mylcd.Set_Text_Size(2);
  mylcd.Print_String("a b c d e f g h i j k l m", 90, 40);
  mylcd.Print_String("n o p q r s t u v w x y z", 90, 60);
  mylcd.Print_String("A B C D E F G H I J K L M", 90, 80);
  mylcd.Print_String("N O P Q R S T U V W X Y Z", 90, 100);
  mylcd.Set_Text_colour(BLUE);
  mylcd.Set_Text_Size(3);
  mylcd.Print_String("a b c d e f g h i j k l m", 15, 130);
  mylcd.Print_String("n o p q r s t u v w x y z", 15, 160);
  mylcd.Print_String("A B C D E F G H I J K L M", 15, 190);
  mylcd.Print_String("N O P Q R S T U V W X Y Z", 15, 220);
  mylcd.Set_Text_colour(CYAN);
  mylcd.Print_String("0 1 2 3 4 5 6 7 8 9", 183, 255);
  mylcd.Set_Text_colour(WHITE);
  mylcd.Print_String("0 1 2 3 4 5 6 7 8 9", 126, 265);
  mylcd.Set_Text_colour(MAGENTA);
  mylcd.Print_String("0 1 2 3 4 5 6 7 8 9", 69, 285);
  //display 1 times string
  delay(2000);
  mylcd.Set_Rotation(0);
  mylcd.Fill_Screen(0x0000);
  mylcd.Print_String("Hello World!", 0, 0);
  mylcd.Print_Number_Float(01234.56789, 2, 0, 8, '.', 0, ' ');
  mylcd.Print_Number_Int(0xDEADBEF, 0, 16, 0, ' ',16);
  //mylcd.Print_String("DEADBEF", 0, 16);
  //display 2 times string
  mylcd.Print_String("Hello World!", 0, 40);
  mylcd.Print_Number_Float(01234.56789, 2, 0, 56, '.', 0, ' ');
  mylcd.Print_Number_Int(0xDEADBEF, 0, 72, 0, ' ',16);
  //mylcd.Print_String("DEADBEEF", 0, 72);
  //display 3 times string
  mylcd.Print_String("Hello World!", 0, 104);
  mylcd.Print_Number_Float(01234.56789, 2, 0, 128, '.', 0, ' ');
  mylcd.Print_Number_Int(0xDEADBEF, 0, 152, 0, ' ',16);
 // mylcd.Print_String("DEADBEEF", 0, 152);
  //display 4 times string
  mylcd.Set_Text_Size(4);
  mylcd.Print_String("Hello!", 0, 192);
  //display 5 times string
  mylcd.Set_Text_colour(YELLOW);
  mylcd.Set_Text_Size(5);
  mylcd.Print_String("Hello!", 0, 224);
  //display 6 times string
  mylcd.Set_Text_Size(6);
  mylcd.Print_String("Hello!", 0, 266);
  //display 7 times string
  mylcd.Set_Text_Size(7);
  mylcd.Print_String("Hello!", 0, 315);
  //display 8 times string
  mylcd.Set_Text_Size(8);
  mylcd.Print_String("Hello!", 0, 372);
  delay(2000);
 Velikost datoteke:  1.9 MB
 Pogledana:  10 krat
rplink3r
Prispevkov: 507
Aktiv.: 2.27
Kraj: Levec
PrispevekObjavljeno: Sre Okt 21, 2020 10:09 am    Naslov sporočila:   Odgovori s citatom
Prvo preveri, če so pini pravilno definirani v programu.
Koda:
Če se tole ujema z dejanskim lcd-jem. Ter tisto DB0-DB15 kar je v komentarju napisano, če je to res tako na LCD-ju.
marko11
Prispevkov: 893
Aktiv.: 3.77
Kraj: Dobrepolje
PrispevekObjavljeno: Sre Okt 21, 2020 1:02 pm    Naslov sporočila:   Odgovori s citatom
rplink3r je napisal/a:
Koda:
Točno tako, to je treba prilagoditi, sedaj dela. Hvala
Koda:
 myLCD(ILI9486,38,39,40,41,28);
