BrunoS Neznanec
Pridružen-a: Ned 08 Avg 2021 14:49 Prispevkov: 4 Aktiv.: 0.08 Kraj: Pivka
Objavljeno: Ned Avg 08, 2021 3:05 pm Naslov sporočila: Gorenje pečica napaka f10 |
Ko smo prišli z daljšega dopusta, se je po javljeni napaki na Boschovem pomivalnem stroju (e09 - grelec) zdaj javila napaka še na Gorenjevi vgradni pečici - napaka f10 (napaka napajanja).
Ali je kdo tukaj, ki je imel podobno težavo in kako jo je odpravil?
Hvaležen bom za kakršnokoli informacijo!
Lep pozdrav,
Bruno |
Pridružen-a: Pon 24 Feb 2003 17:09 Prispevkov: 14673 Aktiv.: 61.89 Kraj: Koroška-okolica Dravograda
Objavljeno: Pon Avg 09, 2021 8:43 am Naslov sporočila: |
Premalo informacij. Model pečice?
V koliko bi šlo za kako podobno krmilje opis napak:
F1 - Meat probe defect (short circuit) during use - check cable set and probe, change them if neccessary
F2 - Error in the measurement circuit - change the module
F3 - Error in the measurement circuit - change the module
F4 - Pt1000 defect (short circuit or not connected)
F6 - One of relays in malfunction - if first code F8 or F4 appears and then F6 is F6 consequentialy included
F8 - Oven temperature to high (>310°C) - check switching off of the heaters - possible error on one of the relays or cooling fan in malfunction
F10 - Error of power supply (relay board defect or connection between relay board and display board not correct)
F15 - Temperature sensor of the module ambient temperature defect
F16 - Power supply failure - check the flat cable to the control module
F18 - Defect in the circuit for touch sensor
F2* - Error in the Touch Sensor circuit of the Keyboard, * advises which key (number)
F85 - module ambient temperature too high (> 85°C)
Debata pred leti... _________________ lp
BrunoS Neznanec
Objavljeno: Tor Avg 10, 2021 2:43 pm Naslov sporočila: |
Model pečice je BO9950AX. Upam, da kaj pomaga...
Hvala Silvo. Tisto starejšo temo sem že prebral... |
Objavljeno: Tor Avg 10, 2021 6:34 pm Naslov sporočila: |
Si poskusil izklopiti napajalno napetost za par minut, da se elektronika resetira? _________________ lp
BrunoS Neznanec
Objavljeno: Ned Avg 15, 2021 12:36 pm Naslov sporočila: |
Silvo je napisal/a: |
Si poskusil izklopiti napajalno napetost za par minut, da se elektronika resetira? |
Sem poskusil tudi to. Zdaj moram samo poskusiti, če je to to... |
BrunoS Neznanec
Objavljeno: Pon Avg 23, 2021 4:57 pm Naslov sporočila: |
Napaka odpravljena... Zaenkrat...
Je bilo potrebno samo vse izklopiti in vklopiti nazaj... |
Uptime: 498 dni
