elsak Član
Pridružen-a: Čet 30 Sep 2010 22:55 Prispevkov: 571 Aktiv.: 3.19 Kraj: Koroška
Objavljeno: Sre Sep 25, 2013 12:41 am Naslov sporočila: OCR ZA ANDROID |
LP!
NIMAM ŠE ANDROIDA. ZATO BI PROSIL ČLANE FORUMA, TISTI KI IMMATE ANDROID, ZA TEST.
RAD BI SI USTVARIL ZA GSM, DA BI MI PREBRAL BESEDILO. TEŽAVE SO V TRGOVINI, KER JE PREDALEČ IN PREMAJHNO BESEDILO.
ČE SE DA DOBIT KAKŠEN BREZPLAČEN OCR SCAN READ PROGRAM ZA ANDROIDA.
NAPRAVE ZA TAK NAMEN, SO KAR DRAGE. CENEJE ME PRIDE EN NAVADEN GSM ZANDROIDOM IN APLIKACIJE.
NA YOUTUBU SEM PREISKAL OGROMNO GRADIVA IN NIKJER NI OMENJENO O IMENU PROGRAMA ALI PROIZVAJALCU.
HVALA
_________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
Pridružen-a: Pon 23 Avg 2004 16:16 Prispevkov: 16777190 Aktiv.: 70795.57
Objavljeno: Sre Sep 25, 2013 1:31 am Naslov sporočila: |
elsak Član
Objavljeno: Sre Sep 25, 2013 2:21 am Naslov sporočila: |
SEM VIDEL, NJIHOVO PREZENTACIJO. SAMO O PROGRAMU PA NIČ. SAMO KAJ DELAJO IN BLA, BLA.
MI LAHKO MALO VEČ OPIŠEŠ.
-BI JAZ LAHKO V TRGOVINI PRIBLIŽAL BESEDILO ALI NALEPKO Z CENO , JO SLIKAL IN DA MI PREBERE?
-LAHKO NAREDIŠ KAKŠEN TEST, ČE IMAŠ TO APLIKACIJO?
-KAKŠEN TELEFON IMAŠ ALI KAKŠEN MORA BIT ZA TO APLIKACIJO?
-KAJ BI NAMESTIL?
-TA KI SLOVENSKO BERE, SE NAMETI NA ANDROIDA?
SE TO DOBI IN KAKŠNA JE CAN?
KER NISEM PRAV RAZUMEL. JE TO RAZLIČNA ZADEVA, KI SI JIH OMENIL ALI DVE ZA ENO CENO?
ČE MI OPIŠEŠ, KAKO DELUJE ALI DAŠ PRAVO IME, DA GREM NA NET GLEDAT, ČE JE KAKŠNA PREZENTACIJA PROGRAMA.
TAKŠNI BRALNIKI PRIDEJO OD 150€ IN NAPREJ. PA SAMO PREBERE IN POVEČA.
PA NE V SLO.
SUPER...
red_mamba Član
Pridružen-a: Ned 20 Feb 2005 17:56 Prispevkov: 1486 Aktiv.: 6.27 Kraj: Yogyakarta
Objavljeno: Sre Sep 25, 2013 11:37 am Naslov sporočila: |
SAMO IDEJA,
A NEBI BILA KAKSNA APLIKACIJA V STILU POVECEVALNEGA STEKLA BOLJ PRIMERNA ZA TVOJE POTREBE?
_________________ Bad things happen to good people all the time for no reason!
Blog |
elsak Član
Objavljeno: Sre Sep 25, 2013 4:20 pm Naslov sporočila: |
NAŠEL SEM EN PRGRAM MOBILE OCR, KI PODPIRA TUDI SLOVENSKI JEZIK IN PIŠE, DA JE FREE. SAMO NISEM NIKJER NAŠEL, DA SE GA DA POTEGNIT.
red_mamba Član
Objavljeno: Sre Sep 25, 2013 4:39 pm Naslov sporočila: |
elsak je napisal/a: |
NAŠEL SEM EN PRGRAM MOBILE OCR, KI PODPIRA TUDI SLOVENSKI JEZIK IN PIŠE, DA JE FREE. SAMO NISEM NIKJER NAŠEL, DA SE GA DA POTEGNIT. |
KER MORAS ITI NA SPLETNO STRAN PREKO ANDROID TELEFONA ALI CE IMAS ANDROID NAPRAVE REGISTRIRANE NA SVOJEM PLAY RACUNU.
Blog |
Objavljeno: Sre Sep 25, 2013 4:41 pm Naslov sporočila: |
elsak Član
Objavljeno: Sre Sep 25, 2013 6:55 pm Naslov sporočila: |
ZA ENKRAT NIMAM NOBENEGA GOVORCA, KER UPORABLJAM SYMBIAN. SAMO KER SE NIČ VEČ NE DOBI ZA SYMBIAN, MORAM PREIT NA ANDROIDA.
SEM ŠE NEKAJ NAŠEL, KI PA BO POTREBNO PISAT, DA DOBIM INFO. PROGRAM SE IMENUJE TEXT DETECTIVE IN JE SAMO ZA IPHONE 4 IN NAPREJ. KOT SEM RAZUMEL IZ VIDEA, DA JE POTREBNO IMET DOLOČEN GOVORC.
NIEM VEDEL GLEDE GOOGLE PLAY, DA JE TREBA MET RAČUN IN NE ORE KAR VSAK IN KUPIT.
HVALA LEPA ZA TEST IN DA SI TO NAREDIL SI MORAL KAJ PLAČAT ALI NE?.
bostjan 2 Član
Pridružen-a: Pon 05 Dec 2011 19:35 Prispevkov: 121 Aktiv.: 0.73 Kraj: Vače
Objavljeno: Sre Sep 25, 2013 7:44 pm Naslov sporočila: |
ELSAK, KAJ PA KAMERA TER SLIKA NA EKRANU?? BI BILO TO UPORABNO; GLEDE NA TO DA IMAŠ TI (KOT VSI OSTALI) HUD OCR V GLAVI?? ČE BI IMEL KAKE 5" EKRAN DOVOLJ BI BILO TUDI ENOSTAVNO NAPISAT APLIKACIJO ZA FOTOAPARAT, KI KAŽE OPCIJSKO ŠE ZOOMIRANO SLIKO ?
LP BOŠTJAN
_________________ Ja še vedno se ne da... |
. Neznanec
Objavljeno: Sre Sep 25, 2013 8:11 pm Naslov sporočila: |
2.13 MB |
2 krat |
BluPhenix Član
Pridružen-a: Pet 05 Mar 2004 12:54 Prispevkov: 1018 Aktiv.: 4.30 Kraj: Sežana
Objavljeno: Sre Sep 25, 2013 8:47 pm Naslov sporočila: |
ELSAK, LAHKO PREMISLIŠ TUDI O KAKŠNEM SAMSUNG GALAXY NOTE ANDROID TELEFONU, KER IMAJO SEDEM INČNI ZASLON IN JE PISAVA DOKAJ VELIKA. KAR SE TIČE ANDROID APLIKACIJ JE NAČELOMA TAKO, DA TUDI ČE JO KUPIŠ IMAŠ 45 MIN ČASA, DA JO PREIZKUŠIS IN ČE TI NI VŠEČ, SI PREMISLIŠ, ODINŠTALIRAŠ IN TAKO TEST NE STANE NIČ.
SICER NE VEM KAKO JE KAJ ANDROID V ZADNJI INKARNACIJI, VEM PA, DA SO IPHONI SVOJ ČAS BILI VELIKO BOLJ PRIJAZNI DO SLABOVIDNIH LJUDI, SAJ SO V NASTAVITVAH OMOGOČALI NASTAVITI VISOKO KONTRASTNI POGLED IN PRECEJŠNJE VEČANJE SAMIH ČRK VEČ LAHKO PREVERIŠ NA URADNI STRANI (LINK SPODAJ), NE VEM PA KAKO JE S SLOVENŠČINO, PE NAJBOLJŠE BI BILO PREVERIT V KAKŠNI TRGOVINI KJER GA IMAJO.
ANDROID JE OČITNO TUDI NEKAJ VKLJUČIL V VERZIJO 4.0, LINK NA OUTUBE TUDI SPODAJ:
LINK APPLE ACCESSIBILITY http://www.apple.com/accessibility/ios/
ANDROID 4.0 http://www.youtube.com/watch?v=3DeprwFkl3U
Pravilo št. 1: Pišite slovensko, velja za vse.
elsak Član
Objavljeno: Sre Sep 25, 2013 11:43 pm Naslov sporočila: |
MOGOČE BI PRIŠLO V POŠTEV OČALA Z LCD ZASLONI IN KAMERA. SAMO V TRGOVINI, MI MALO ČUDNO IZGLEDAL, DA BI BIL TAKO OPREMLJEN, PA TUDI NE GRE.
JAZ NA GSM NE VIDIM, ZATO IMAM GOVORCA. TUDI POVEČAVA MI NIČ NE PRIDE V POŠTEV. DOMA VIDIM NA GSM Z POMOČJO KAMERE, KI SO MOJE DRUGE OČI. Z NJO LAHKO DELAM.
JAZ BEREM VAŠE PRISPEVKE IN OSTALO, NA 150CM VELIKI PLAZMI IN 14X POVEČAVI+POVEČAVA, KI JO PODPIRA TV. KURZOR OD MIŠKE, JE VELIK 25-30CM. VELIKE TISKANE ČRKE, SO PA VELIKE NEKJE 15CM. ZRAVEN PA IMAM ŠE SLOVENSKEGA GOVORCA, KI MI VSE BERE.
VSE JE ODVISNO OD SVETLOBE IN KONTRASTI. .
SAJ MISLIM NA EN ANDROID 3, DA BI LAHKO NAMESTIL TAKŠNE IN PODOBNE APLIKACIJE.
TO POTREBUJEM SAMO TAKRAT, KO SEM Z DOMA. DOMA IMAM KAMERE ZA POEČVO. POVEČEVALNO STEKLO IMAM 10X POVEČAVO IN NE MOREM BRATI Z NJO.
KAKRŠNA KOLI IDEJA, JE DOBRODOŠLA.
HVALA ZA POMOČ.
elsak Član
Objavljeno: Čet Sep 26, 2013 12:04 am Naslov sporočila: |
MOGOČE KDOVE, KAKO BI LAHKO SLEPA OSEBA NAPISALA SMS SPOROČILO NA TOUCH TELEFONU?
Z TEM, DA GA NE PIŠE PO URE PAR VRSTIC.
KOLIKOR SEM USPEL NAJT GLEDE TEH PRORAMOV ZA SLIKANJE IN DA PREBERE BESEDILO, JE SAMO TEXT DETECTIVE. ŽENSKA NA YOUTUBU, KI OPISUJE TA PROGRAM. PRAVI DA SE GA DOBI ZA 9.99 US DOLARJEV.
Objavljeno: Čet Sep 26, 2013 12:26 am Naslov sporočila: |
elsak Član
Objavljeno: Čet Sep 26, 2013 1:09 am Naslov sporočila: |
KER NIAMM IZKUŠNJ GLEDE TEH NOVIH TELEFONOV.
KAJ JE BOLJ POMEMBNO DA KUPIM. SMARTPHONE Z ANDROIDOM ALI IPHONE APPLE?
