Azrael Član
Pridružen-a: Čet 29 Jan 2009 19:46 Prispevkov: 4432 Aktiv.: 22.21 Kraj: Gorje
Objavljeno: Pon Jun 06, 2011 7:42 pm Naslov sporočila: |
LLB je sicer lahko tudi liquid-lubricated bearings, ampak v tem primeru gre za izvedbo tesnenja ležaja, v grobem enako kot oznaka 2RS:
What is the difference between LLB & LLU seals?
The "LB" seal is a non-contact seal for reduced torque or higher speed requirements. The "LU" seal is a contact seal for better contamination control, but the contact friction increases torque and lowers the limiting speed.
Vir.
Po domače, z gumo zaprt ležaj za visoke vrtljaje. |
