elsak Član
Pridružen-a: Čet 30 Sep 2010 22:55 Prispevkov: 571 Aktiv.: 3.18 Kraj: Koroška
Objavljeno: Sob Apr 20, 2013 6:34 pm Naslov sporočila: |
SE PRAVI. ČE RELEJA DELUJETA, POTEM JE Z MODULOM IN SPREJEMNIKOM VSE OK?
ONA PRAVI, DA GA NA SERVIS NE BO DALA, KER PRIDE VEČ, KOT JE AVTO VREDEN.
ZDAJ LAHKO SAMO UGIBAMO, KER DOKLER STVAR NE DOBIM V ROKE, SE NE VE.
MOGOČE KOD OD VAS VE. KAKO JE KAJ ZAKOMPLICIRANO GLEDE DEMONTAŽE VRAT? TAPETA, ROČKE, ELEKTRONIKA.
_________________ TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO. |
airwolf Član
Pridružen-a: Sre 28 Maj 2008 17:17 Prispevkov: 2219 Aktiv.: 10.68 Kraj: Polhov Gradec
Objavljeno: Sob Apr 20, 2013 9:08 pm Naslov sporočila: |
DEMONTAŽA NI NEKA UMETNOST. NAJBOLJ ZOPRNO BO ZADAJ ZARADI TISTE ROČKE ZA STEKLA. DRUGAČE JA, NOTRANJA LUČKA MALO POMEŽIKNE IN SLIŠI SE KLIK RELEJA ČE JE VAROVALKA PREGORELA. JUTRI SPOROČIM KATERA VAROVALKA JE PA ZA MODUL IN KAKO ODSTRANITI TAPETO NA VRATIH.
_________________ LP Gašper |
elsak Član
Objavljeno: Sob Apr 20, 2013 9:44 pm Naslov sporočila: |
PRB. V KATERM ČASU BOŠ VEDEL? DA JI SPOROČIM, DA NE BO ISKALA BREZ VEZE.
HVALA GAŠPER.
airwolf Član
Objavljeno: Sob Apr 20, 2013 10:24 pm Naslov sporočila: |
ZJUTRAJ MI BO PRIORITETA ZAMENJATI BLATNIK KER V TEM KI GA IMAM ZDAJ ZEVA ENA LEPA LUKNJA ČE ME NE BO HECALO BOM DO POLDNEVA ŽE VSE VEDEL.
AMPAK VEM DA ME BO HECALA RJA NA VIJAKIH, NIČ HUDEGA RJO IMAM RAD.
NA ZADNJIH VRATIH SE SPOMNIM DA VEČINO TAPETE DRŽIJO SAMO PLASTIČNE KLIPSNE, OZ VSAJ VIDETI JE BILO TAKO KO SEM ZADEVO PRED LETOM NAPADEL Z KLADIVOM DA SEM STISNIL POČENO PLASTIKO. .
ZA TISTO VAROVALKO TE PA TUDI OBVESTIM. VEM DA NI TISTA PRI KATERI JE NARISAN KLJUČ.
elsak Član
Objavljeno: Ned Apr 21, 2013 3:11 am Naslov sporočila: |
JAZ SE POPRAVILA KAR Z MACOLO LOTIM.
RJO DOL ZBRUSIŠ, POKITAŠ IN POBARVAŠ. EDINO, ČE NI VEČJA POVRŠINA IN NA VIDNEM MESTU.
MAMA NIMA KLJUKIC ZA POMIK OKEN. IMA VSE NA EL. POMIK.
FORDE IN MAZDE SEM ŽE RAZDIRAL , TO PA ŠE NE.
KATERI LETNIK IN TIP CLIOTA IMAŠ? ČE BOM MOGOČE ŠE KAKŠNO POMOČ POTREBOVAL.
GREM STAVT, DA BO HOTLA MET ŠE UZ SENZORJE ZA PARKIRAT AL PA KAMERCO. ČE IMA TO SPLOH SMISEL GOR DEVAT.
Profesor Einstein Član
Pridružen-a: Ned 24 Sep 2006 0:13 Prispevkov: 1437 Aktiv.: 6.30 Kraj: Rogaška Sl.
Objavljeno: Ned Apr 21, 2013 9:09 am Naslov sporočila: |
Zdravo
Malo "Cyclot-a" bo potrebenga za našpricati vodilo motorčka in ostali mehanizem.
Lp.
Darko
8.15 KB |
11406 krat |
_________________ --
airwolf Član
Objavljeno: Ned Apr 21, 2013 11:23 am Naslov sporočila: |
IMAM CLIOTA II PH1 . PREDNJO TAPETO DRŽIJO ŠTIRJE VIJAKI. DVA TORX-A STA NA SPODNJEM ROBU, EN V DRŽALU VRAT IN EN V KLJUKI. TISTI NA SPODNJEM ROBU IN V DRŽALU SO ENAKI, UNI V KLJUKI PA JE ENO CIFRO VEČJI. POTEM PA SAMO ŠE KOVINSKE VZMETI NA VRATIH DRŽIJO PLASTIČEN ROB NA TAPETI. NE POZABI SNETI ZVOČNIKA IN IDKLOPITI STIKAL ZA STEKLA. MREŽICA ZA ZVOČNIKE JE SAMO NATAKNJENA . NAJPREJ SPROSTIŠ SPODNJI DEL NATO PA ŠE ZGORNJEGA. NAZAJ RAVNO OBRATNO NATAKNJEŠ POD OHIŠJE ZA STIKALA IN SAMO POTISNEŠ NA MESTO. ZADAJ JE ŠE BOLJ SIMPL, SAMO DVA VIJAKA EN V KLJUKI IN EN V ROČAJU.
TUDI TU SO KOVINSKE VZMETI IN PLASTIČEN ROB.
PS: PREDNJI BLATNIK JE PLASTIČEN IN TEGA SE MI NE DA POPRAVLJAT, PA ŠE USTREZNEGA SEM IMEL V KLETI.
elsak Član
Objavljeno: Ned Apr 21, 2013 2:52 pm Naslov sporočila: |
KOLK JE ŠTEVILKA TROXA? MAM [slovenščina je zame španska vas], ČE BO PRAVI.
airwolf Član
Objavljeno: Ned Apr 21, 2013 3:06 pm Naslov sporočila: |
T20 KLJUKA, T15 OSTALI.
marsovcek Član
Pridružen-a: Pet 08 Jun 2012 11:27 Prispevkov: 160 Aktiv.: 1.01 Kraj: Okolica Celja
Objavljeno: Ned Apr 21, 2013 10:39 pm Naslov sporočila: |
JE BATERIJA V KLJUČU ZAGOTOVO V REDU? MOTORČKE IN INŠTALACIJO PA NAJLAŽJE PREVERIŠ Z GUMBOM ZA ZAKLEPANJE V AVTU (VOZNIKOVA VRATA MORAJO BITI PRI TEM ZAPRTA).
elsak Član
Objavljeno: Pon Apr 22, 2013 12:24 am Naslov sporočila: |
BATERIJO JE TAKOJ NOVO KUPILA, KO JI NI VEČ DELALO.
KAKO TO MISLIŠ PRITISNE GUMB ZNOTRAJ AVTA? ONA LAHKO ODPRE, SAMO Z KLJUČEM ALI GUMBOM NA KLJUČU ZA DALJINSKO.
Z KJLUČEM SE NIHČE NI IGRAL, KER JIH IMA SAMO ONA. KO JI NI VEČ DELALO IN JE MENJALA BATERIJO, JE NEKAJKRAT POIZKUŠASLA. SAMO NE 100X ALI VEČKRAT.
airwolf Član
Objavljeno: Pon Apr 22, 2013 11:10 am Naslov sporočila: |
ZDAJ TE PA NE RAZUMEM VEČ.
1. VPRAŠANJE.
ALI LAHKO KADARKOLI KO JE V AVTU ZAKLJENE AVTO Z PRITISKOM NA GUMB NA KLJUČU?
2. VPRAŠANJE
ALI ČE PRITISNE NA TIPKO ZA CENTRALNO ZAKLEPANJE V AVTU (NE NA DALJINCU AMPAK NA PLOŠČI) ALI SE AVTO ZAKLENE?
3. VPRAŠANJE
ALI TI NE DELA SAMO KLJUČAVNICA NA PRTLJAŽNIKU ALI ŠE KJE DRUGJE?
zok Član
Pridružen-a: Pet 02 Jan 2009 23:59 Prispevkov: 1115 Aktiv.: 5.56 Kraj: Ponikva
Objavljeno: Pon Apr 22, 2013 12:02 pm Naslov sporočila: |
CLIOTI, NAREJENI MARCA 2001 IN KASNEJE:
VAROVALKE ZA CENTRALNO ZAKLEPANJE:
F1 (15 A) (SPREJEMNIK)
F21 (5 A) (VERJETNO SAMO ZA OSVETLITEV TIPKE NA ARMATURI??)
F27 (10 A) (OPCIJA Z DAYLIGHT RUNNING LIGHTS)
F31 (20 A) (MOTORJI)
VSI MOTORJI SO VEZANI VZPOREDNO.
CLIOTI, IZDELANI DO FEBRUARJA 2001:
F1 (15 A)
F21 (5 A)
F27 (10 A) - OSVETLITEV TIPKE - DOVOD IZ KOMBINACIJSKEGA STIKALA
F29 (20 A) - SAMO DO LETNIKA 99 - NAPAJANJE ALARMA, KASNEJE ZA TO UPORABIJO DOVOD PREKO F21
F31 (20 A) - NAPAJANJE MOTORJEV
elsak Član
Objavljeno: Pon Apr 22, 2013 3:24 pm Naslov sporočila: |
NAPISAL SEM. BATERIJO JE MENJALA ZA KLJUČ IN JI NE DELA.
CENTRALNO JI NE DELA.
ČE JI CENTRALNO NE DELA, JI NOBEN NOTORČEK NE DELA. NOBENA VRATA IN TUDI PRTLJAŽNIK NE.
VZNOTRI AVTA NIMA NOBENEGA GUMBA ZA CENTRALNO.
SEDAJ JI DELUJE SAMO MEHANSKO ODKLEPANJE AVTA IN VŽIGA. PRTLJAŽNIK JE PA SKOZ ODKLENJEN.
POVEDAL SEM ŽE. DA TO NI MOJ AVTO, DA MAMA NE ŽIVI V MOJEM KRAJU. ZATO NE VIDIM V AVTO IN GOVORIM, KAR MI ONA POVE.
SERIJA CLIOTA JUNIJ 2001.
marsovcek Član
Objavljeno: Pon Apr 22, 2013 8:32 pm Naslov sporočila: |
elsak je napisal/a: |
MORA BITI, ČE SE PRAV SPOMNIM JE ZRAVEN MENJALNIKA.
ČE JE BILA BATERIJA PRAZNA, JE POTREBNO KLJUČ SINHRONIZIRATI:
- PRITISNEŠ GUMB V AVTU IN DRŽIŠ PAR SEKUND, PRIŽGE SE RDEČA LUČKA NA ARMATURKI
- PRITISNEŠ GUMB NA KLJUČU IN LUČKA MORA UGASNITI
