R.P. Član
Pridružen-a: Čet 21 Apr 2005 19:26 Prispevkov: 98 Aktiv.: 0.41 Kraj: Ribnica
Objavljeno: Ned Okt 14, 2007 11:59 am Naslov sporočila: |
Pa še postopek nastavitve višine snopa luči
here are certain test conditions that must be met before doing this procedure:
Vehicle must be parked on level ground and "settled" on its suspension
Parking brake should be OFF
Ignition should be in the "On" position
Headlamps should be "Off"
Procedure for Aligning Xenon Headlamps:
[Select]
[55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
[Basic Settings - 04]
Group 001
[Go!]
Wait at least 20 seconds for the headlamp motors to move. The headlamps are now in their adjustment position. Turn on headlights. Adjust them via their manual adjusting screws as referenced against a suitable aiming target.
Scroll up to Group 002. The Xenon Range controller has now learned this position as its Home position.
Click the [Done, Go Back] button and you're all set. _________________ Rešitev problema spremeni bistvo problema. |
dj robee Član
Pridružen-a: Ned 05 Okt 2003 20:34 Prispevkov: 68 Aktiv.: 0.29
Objavljeno: Tor Okt 30, 2007 10:18 am Naslov sporočila: |
SimonS je napisal/a: |
Pojma nimam, kaj je bilo prej notri...... Jaz sem kar avtomatsko krivil xenonke za to...  |
Kolikor je tudi meni znano, imajo xenonke majnšo temperaturo... Ne vem pa, kako je z UV sevanjem, kajti nekatere luči so imele probleme z žarnicami, ki so oddajale preveč UV spektra... Sicer nisem slišal da bi škodovalo paraboli ampak steklu (plastiki ?ki naj bi bil leksan?) |
