| Avtor |
Musty Član
Pridružen-a: Sob 28 Apr 2007 8:54 Prispevkov: 1575 Aktiv.: 6.82 Kraj: Rače
Objavljeno: Pon Jul 01, 2013 3:51 pm Naslov sporočila: |
IRC server mi ne deluje, pa mislim da nisem edini:
| Koda: |
NICK musti
USER musti 0 * xxxxxxxx
NOTICE AUTH *** Looking up your hostname...
NOTICE AUTH *** Found your hostname (cached)
451: CAP You have not registered
PING A83767EF
PONG A83767EF
010: irc.sioff.net 6667 Please use this Server/Port instead
ERROR Closing Link: musti[xxxxxxxxxxxxx.net] (This server is full.)
Kakšna ideja? |
| Nazaj na vrh |
klemen88 Član
Pridružen-a: Tor 01 Jan 2008 17:37 Prispevkov: 747 Aktiv.: 3.35 Kraj: Slovenj Gradec
Objavljeno: Pon Jul 01, 2013 3:57 pm Naslov sporočila: |
Meni ne deluje od kar sem menjal ponudnika. Sedaj mi vsake toliko časa le poveže vendar ne za dolgo :/
| Koda: |
Perl interface loaded
* Looking up irc.sioff.net
* Connecting to irc.sioff.net (93.103.7.99) port 6667...
* Connected. Now logging in...
* *** Looking up your hostname...
* *** Couldn't resolve your hostname; using your IP address instead
Meni to izpiše na X-chatu |
| Nazaj na vrh |
gumby Član
Pridružen-a: Sob 28 Apr 2007 12:32 Prispevkov: 4066 Aktiv.: 17.60
Objavljeno: Pon Jul 01, 2013 4:03 pm Naslov sporočila: |
Probate lahko na triglav.sioff.net _________________ Tule nisem več aktiven. |
| Nazaj na vrh |
klemen88 Član
Objavljeno: Pon Jul 01, 2013 4:08 pm Naslov sporočila: |
| Koda: |
* Looking up triglav.sioff.net
* Connecting to triglav.sioff.net (91.185.207.167) port 6667...
* Welcome to the SiOff IRC Network klemen88!Klemen@91.185.207.167
* Your host is triglav.sioff, running version Unreal3.2.10.1
* This server was created Thu Apr 18 2013 at 11:51:06 CEST
* triglav.sioff Unreal3.2.10.1 iowghraAsORTVSxNCWqBzvdHtGpI lvhopsmntikrRcaqOALQbSeIKVfMCuzNTGjZ
* UHNAMES NAMESX SAFELIST HCN MAXCHANNELS=20 CHANLIMIT=#:20 MAXLIST=b:60,e:60,I:60 NICKLEN=30 CHANNELLEN=32 TOPICLEN=307 KICKLEN=307 AWAYLEN=307 MAXTARGETS=20 :are supported by this server
* WALLCHOPS WATCH=128 WATCHOPTS=A SILENCE=15 MODES=12 CHANTYPES=# PREFIX=(qaohv)~&@%+ CHANMODES=beI,kfL,lj,psmntirRcOAQKVCuzNSMTGZ NETWORK=SiOff CASEMAPPING=ascii EXTBAN=~,qjncrRa ELIST=MNUCT STATUSMSG=~&@%+ :are supported by this server
* EXCEPTS INVEX CMDS=KNOCK,MAP,DCCALLOW,USERIP,STARTTLS :are supported by this server
* There are 1 users and 134 invisible on 2 servers
* iglav.sioff 252 klemen88 1 :operator(s) online
* 28 :channels formed
* I have 11 clients and 0 servers
* 11 137 :Current local users 11, max 137
* 135 314 :Current global users 135, max 314
* - triglav.sioff Message of the Day -
* - 9/11/2009 10:26
* - Pozdravljeni na strezniku irc.sioff.net.
* - Welcome to irc.sioff.net server.
* - _ _____ _ _____ ___ ___ _
* - |_|___ ___ | __|_| | _| _| ___ ___| |_
* - | | _| _|_|__ | | | | _| _|_| | -_| _|
* - |_|_| |___|_|_____|_|_____|_| |_| |_|_|_|___|_|
* - Supported features:
* - - SSL
* - SSL service is available on port 6697. Interserver links are encrypted.
* - - IPv6
* - irc.sioff.net supports IPv6
* - for IPv6 ONLY connectivity use irc6.sioff.net
* - If you use irssi, do "/set resolve_prefer_ipv6 ON" before connecting.
* - - Services
* - We have: nickserv, chanserv, memoserv, botserv and hostserv.
* - For further information use "/helpserv help" or "/quote helpserv help".
* - Rules in short:
* - - No bots, no flooding, no spamming, no abuse or harassment.
* - - Use your common sense.
* - Please direct your comments, questions, complaints and abuse reports
* - to the staff in channel #opers.
* - Enjoy your stay.
* End of /MOTD command.
* klemen88 sets mode +i klemen88
* klemen88 sets mode +x klemen88
* Disconnected (Vzpostavljeno povezavo je prekinil program v gostitelju).
Me poveže vendar mi čez 10s prekine povezavo. |
| Nazaj na vrh |
Musty Član
Objavljeno: Pon Jul 01, 2013 6:46 pm Naslov sporočila: |
| Meni triglav zdaj normalno deluje. |
| Nazaj na vrh |
kobranka Član
Pridružen-a: Sob 24 Jul 2010 19:37 Prispevkov: 3403 Aktiv.: 17.76 Kraj: nekje v zgornjem posočju
Objavljeno: Sob Apr 05, 2014 12:31 pm Naslov sporočila: |
| No meni se je tudi uspelo povezat po nekaj čaranju v eMuli, ki ima že vdelanga klienta. Moram priznat, da tudi jaz tega, že dolgo nisem uporabljal in sem se zato lovil. |
| Nazaj na vrh |
VolkD Član
Pridružen-a: Pet 24 Sep 2004 21:58 Prispevkov: 14228 Aktiv.: 57.58 Kraj: Divača (Kačiče)
Objavljeno: Ned Avg 17, 2014 3:18 pm Naslov sporočila: |
Več vprašanj je prišlo na temo kako na IRC ?
Najprej nekaj res malega o IRC-u.
To je sistem chatanja - ali pogovarjanja po naše - v skoraj realnem času.
Kako to gre? Imamo enega ali več strežnikov, ki so povezani v neko IRC skupino. Na ta sistem strežnkov se povežemo z ustreznim klientom.
To pa še ni dovolj. Vedeti moramo še par stvari. Ena od teh je ime kanala, kjer se nam zanimivi pogovori odvijajo. V našem primeru je to kanal #elektronik.si
Imena serverjev:
irc.sioff.net
triglav.sioff.net
Ni v odvisnosti od klienta ki ga imamo na razpolago moramo vedeti še vsaj port. Za naše potrebe je to 6667.
O klientih, ki jih bomo uporabili je govora tule.
IRC ima dolgo zgodovino, ki obsega celo internetne vojne in podobne stvari. No kljub temu ostaja po mojem najboljši sistem za pogovarjanje znotraj neke skupine.
Ko se enkrat prijavimo na IRC strežnik in pridemo na kanal, pa se vprašanja šele začno.
-kaj je to voice ?
-kaj je to OP ?
-kaj je to kick, kaj je ban verjetno veste
-kakšni so parametri , ki se jih da nastavljati,....
Mnogo tega je, vse pa je dosegljivo na netu. In ne pozabite! Najpomembnejše je - to je sistem, ki omogoča medsebojne pogovore neke skupine. Vse ostalo je samo za zraven. _________________ Dokler bodo ljudje mislili, da živali ne čutijo, bodo živali čutile, da ljudje ne mislijo. |
| Nazaj na vrh |
marksev Član
Pridružen-a: Sre 11 Feb 2009 20:26 Prispevkov: 98 Aktiv.: 0.47 Kraj: Gorenjska - okolica Kranja
Objavljeno: Sob Avg 23, 2014 9:16 pm Naslov sporočila: |
Aha vidim, da je irc kanal še aktiven, lepo  |
| Nazaj na vrh |
fullbang Neznanec
Pridružen-a: Ned 31 Avg 2014 12:03 Prispevkov: 2 Aktiv.: 0.01 Kraj: Novo mesto
Objavljeno: Ned Avg 31, 2014 12:48 pm Naslov sporočila: |
Mene pa zadeva zanima bolj iz "zgodovinskega stališča". Verjetno ste starejši člani bli priosotni na IRCju od vsega začetka, pa imate najbrž tudi drugačen pogled na to, kot mi mladina ki smo se vpeljali u internetno sporočanje šele z MSN in ostalim zadevam.
Se drugače še kej zbere "stara garda" na slovenskih kanalih IRC pa kakšno debato upali kot u starih časih? |
| Nazaj na vrh |
VolkD Član
Objavljeno: Ned Avg 31, 2014 7:50 pm Naslov sporočila: |
OH ja,...
Naš kanal sicer ni več na IRCNET, pa vseeno. S tem ko je IRC-anje postalo manj popularno je ceveda zamrl tudi IRC WAR. No ko se je to zgodilo je ena precej velika skupina IRC-arjev končno uspela ugotoviti, da je IRC sistem resnično idealen kot CHAT sistem. To bi se sicer lahko zgodilo že zdavnaj, če bi bila politika sysop-ov IRCNET-a pametna. Pa ni bila. Ravno zato so si skupine ljudi postavile svoj IRC sisitem. Tu veljajo malo drugačna pravila, ki načeloma dodobra preprečujejo IRC WAR. S tem je nastal sistem strežnikov, kjer je IRC kot chat sistem resnično zaživel.
In to je zdaj to. Smo v tej točki, kjer zgodovino od tu dalje lahko pišemo sproti. _________________ Dokler bodo ljudje mislili, da živali ne čutijo, bodo živali čutile, da ljudje ne mislijo. |
| Nazaj na vrh |
