SimonS Član
Pridružen-a: Čet 01 Jul 2004 11:18 Prispevkov: 4769 Aktiv.: 20.13 Kraj: Kobarid
Objavljeno: Sre Dec 11, 2024 6:16 pm Naslov sporočila: |
Evo, tako pa chatGPT nariše shemo na ukaz uporabe low-side mosfeta. Meni je jasno... nič!
332.87 KB |
4 krat |
_________________ Lep dan
Simon |
mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3531 Aktiv.: 31.54
Objavljeno: Ned Dec 15, 2024 2:37 pm Naslov sporočila: |
Sem mu dal isti tekst, pa ga potem okaral, da trosi neumnosti. Pa je vrnil tole:
Koda: |
from matplotlib import pyplot as plt
import matplotlib.patches as patches
# Create a new figure for the circuit
def draw_circuit_diagram():
fig, ax = plt.subplots(figsize=(8, 6))
# Power Supply
ax.text(0.1, 0.9, "3V Power Supply", fontsize=12, ha="center")
ax.plot([0.1, 0.4], [0.85, 0.85], color='black', lw=2)
ax.plot([0.4, 0.4], [0.85, 0.7], color='black', lw=2)
# Load (e.g., LED or Motor)
ax.text(0.45, 0.75, "Load (3V Device)", fontsize=10, ha="left")
ax.plot([0.4, 0.6], [0.7, 0.7], color='black', lw=2)
ax.plot([0.6, 0.6], [0.7, 0.55], color='black', lw=2)
# N-channel MOSFET
ax.text(0.65, 0.6, "N-channel MOSFET", fontsize=10, ha="left")
ax.add_patch(patches.Rectangle((0.6, 0.35), 0.1, 0.3, edgecolor='black', facecolor='none'))
ax.plot([0.65, 0.65], [0.35, 0.3], color='black', lw=2, linestyle='--') # Arrow for Source
# Source to Ground
ax.plot([0.65, 0.65], [0.35, 0.15], color='black', lw=2)
ax.text(0.65, 0.1, "Ground", fontsize=10, ha="center")
# Gate control signal
ax.plot([0.75, 0.75], [0.55, 0.8], color='black', lw=2)
ax.text(0.8, 0.75, "Control Signal", fontsize=10, ha="left")
# Drain
ax.plot([0.6, 0.65], [0.55, 0.55], color='black', lw=2)
# Adjust plot limits and hide axes
ax.set_xlim(0, 1)
ax.set_ylim(0, 1)
ax.axis('off')
# Show the plot
plt.show()
# Call the function to draw the circuit diagram
Lovro7 Član
Pridružen-a: Pet 06 Sep 2024 18:31 Prispevkov: 27 Aktiv.: 2.84
Objavljeno: Ned Dec 15, 2024 7:37 pm Naslov sporočila: |
2 dni nazaj sem delal nekaj z tkinterjem in plot. Nekaj nisem znal narediti in sem vprašal chat. Prilepim kodo v VS code, kliknem run in napaka. Posljem chatu napako in napiše:
Oprostite, ker je prišlo do zmede. Napaka se je pojavila v funkciji update_plot(). Tukaj je popravljena koda: |
Napiše novo kodo, ki je bila identična.
Nato sem mu ponovno napisal: “popravi napake v kodi + koda”
In dobim nazaj kodo, ki ji manjka 3/4 funkciji.
3x sem ponovil vprašanje in vsakič je bili slabše.
_________________ Vse je lahko žarnica, če je dovolj toka.
Ne mi zamerit, če se zmotim! |
twom Član
Pridružen-a: Ned 26 Okt 2003 0:37 Prispevkov: 986 Aktiv.: 4.16 Kraj: Ljubljana
Objavljeno: Pet Jan 03, 2025 4:11 pm Naslov sporočila: |
42.19 KB |
11 krat |
mosqito Član
mosqito Član
Objavljeno: Pet Apr 04, 2025 9:14 pm Naslov sporočila: |
Oma…
137.29 KB |
3 krat |
Objavljeno: Ned Apr 06, 2025 8:39 am Naslov sporočila: |
Pogajanja ...
76.95 KB |
12 krat |
Dober_Dan Član
Pridružen-a: Ned 27 Mar 2022 20:13 Prispevkov: 38 Aktiv.: 0.97 Kraj: Ljubljana
Objavljeno: Tor Apr 08, 2025 3:00 pm Naslov sporočila: |
Kaj reče elektron, ko ga vprašajo, zakaj je tako negativen?
"To je samo moja narava!"
Ivor Član
Pridružen-a: Pet 15 Feb 2008 19:49 Prispevkov: 213 Aktiv.: 1.01
Ivor Član
Ivor Član
mateik Član
Pridružen-a: Sob 06 Avg 2022 18:31 Prispevkov: 262 Aktiv.: 7.51 Kraj: Ljubljana
jozkoc Član
Pridružen-a: Sre 16 Jun 2010 13:32 Prispevkov: 589 Aktiv.: 3.22 Kraj: Ljubljana
Objavljeno: Sre Apr 16, 2025 1:18 pm Naslov sporočila: |
@mateik, car humorja.
_________________ Nikoli ni tako dobro da ne bi moglo biti še boljše. |
Ivor Član
Objavljeno: Čet Apr 17, 2025 10:53 am Naslov sporočila: |
Poroka je zveza, v kateri ima ena oseba vedno prav, druga oseba je pa mož.
_________________ Mirno spim na lovorikah že 17 let.  |
Ivor Član
