Objavljeno: Pon Avg 11, 2003 10:56 pm Naslov sporočila: Nov črv na obzorju! (Lovsan, MSBlast, Poza) |
Tole je zelo sveže, zato v originalni obliki
F-Secure Virus Descriptions
Alphabetical Index
ALIAS: MSBlast, Poza
F-Secure is currently analysing a new RPC worm, known as Lovsan. First sample of this worm was received at 20:22 GMT on 11th of August, 2003.
This 6176 byte executable "msblast.exe" contains about 11kB of uncompressed code, which apparently exploits the MS03-026 DCOM/RPC hole,"Buffer Overrun In RPC Interface", http://www.microsoft.com/technet/security/bulletin/MS03-026.asp This vulnerability was discovered on July 16th, 2003.
The worm adds a key called "windows auto update" to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
The worm contains these texts:
I just want to say LOVE YOU SAN!!
billy gates why do you make this possible ? Stop making money and fix your software!!
Apparently the worm will start a distributed denial-of-service attack against the windowsupdate.com server on 15th of August, 2003. |
Objavljeno: Tor Avg 12, 2003 9:51 pm Naslov sporočila: |
Danes bo moj firewall po***dil od zavračanja zahtev po portu 135. Torej, če je kdo brez požarnega zidu naj si tole zgoraj kar dobro prebere. Izgleda, da je aktiven kot hudič . |
