PIC16F676
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Osnove programiranja PIC-a v Assembler-ju
djtech
Pridružen-a: Sob 18 Okt 2003 21:47
Prispevkov: 113
Aktiv.: 0.46
Kraj: Cerkvenjak
PrispevekObjavljeno: Sre Okt 20, 2004 11:33 am    Naslov sporočila:  PIC16F676 Odgovori s citatom
Description: Microchip's 14-Pin 16F676 8-Bit Processor. 1K of program space and 12 I/O lines. 8 channel Analog to Digital Converter! Runs up to 20MHz with external crystal or up to 4MHz with the internal RC oscillator. Package can be programmed in circuit. If you need A/D channels, this is packed with 'em! These are industrial packages - will run as low as 2V.
In še datasheet
PIC16F676.pdf
 Ime datoteke:  PIC16F676.pdf
 Velikost datoteke:  2.59 MB
 Downloadano:  21 krat
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Osnove programiranja PIC-a v Assembler-ju Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
Uptime: 233 dni
