| Avtor |
trot Član
Pridružen-a: Čet 18 Jan 2007 20:25 Prispevkov: 1312 Aktiv.: 5.60 Kraj: glej fogl
Objavljeno: Pon Jan 14, 2008 7:25 pm Naslov sporočila: fpga - 7 segmentni prikaz |
Rad bi preizkusil 7 segmentni prikaz na x bordu. Spisal sem tole:
main.vhd
| Koda: |
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity main is
port ( clock : in STD_LOGIC;
tipka : in STD_LOGIC;
ledica1 : out STD_LOGIC;
ledica2 : out STD_LOGIC;
prvi_disp_7seg_led_out : out std_logic_vector (7 downto 1)
end main;
architecture Behavioral of main is
signal clk_div : std_logic_vector (20 downto 0);
signal clk_disp_7seg : std_logic_vector (3 downto 0);
component disp_7seg
port ( seg_hex: in STD_LOGIC_VECTOR (3 downto 0);
seg_led: out STD_LOGIC_VECTOR (6 downto 0));
end component;
begin
process (clock)
begin
if rising_edge(clock) then
clk_div <= clk_div + 1;
end if;
end process;
process (clk_div(15))
begin
if rising_edge(clk_div(15)) then
clk_disp_7seg <= clk_disp_7seg + 1;
end if;
end process;
prvi_disp_7seg : disp_7seg port map(seg_hex => clk_disp_7seg, seg_led => prvi_disp_7seg_led_out);
ledica1 <= clk_div(14);
ledica2 <= clk_disp_7seg(1);
end Behavioral;
7seg.vhd
| Koda: |
library IEEE;
--library UNISIM;
entity disp_7seg is
Port ( seg_hex: in STD_LOGIC_VECTOR (3 downto 0);
end disp_7seg;
architecture Behavioral of seg is
begin
-- segment encoinputg
-- 0
-- 5 | | 1
-- --- <- 6
-- 4 | | 2
-- 3
with seg_hex SELect
seg_led <= "1111001" when "0001", --1
"0100100" when "0010", --2
"0110000" when "0011", --3
"0011001" when "0100", --4
"0010010" when "0101", --5
"0000010" when "0110", --6
"1111000" when "0111", --7
"0000000" when "1000", --8
"0010000" when "1001", --9
"0001000" when "1010", --A
"0000011" when "1011", --b
"1000110" when "1100", --C
"0100001" when "1101", --d
"0000110" when "1110", --E
"0001110" when "1111", --F
"1000000" when others; --0
end Behavioral;
Javi mi napako:
ERROR:NgdBuild:604 - logical block 'prvi_disp_7seg' with type 'disp_7seg' could
not be resolved. A pin name misspelling can cause this, a missing edif or ngc
file, or the misspelling of a type name. Symbol 'disp_7seg' is not supported
in target 'xbr'.
Mogoče kdo ve, kaj bi bilo narobe. Kakšen misspelling, jaz ne vidim nobene napake.
| Nazaj na vrh |
icek Član
Pridružen-a: Ned 15 Maj 2005 22:31 Prispevkov: 105 Aktiv.: 0.42 Kraj: Ruše
Objavljeno: Tor Jan 15, 2008 8:33 am Naslov sporočila: |
| Narediti moraš še port map s katerim boš povezal signale v main.vhd in 7seg.vhd.
| Nazaj na vrh |
trot Član
Objavljeno: Tor Jan 15, 2008 10:35 am Naslov sporočila: |
Saj imam, če misliš to:
| Koda: |
| Nazaj na vrh |
icek Član
Objavljeno: Tor Jan 15, 2008 10:55 am Naslov sporočila: |
| Pa res, sem spregledal.
| Nazaj na vrh |
aly Član
Pridružen-a: Tor 28 Sep 2004 14:51 Prispevkov: 9407 Aktiv.: 38.07 Kraj: Kranj - struževo
Objavljeno: Tor Jan 15, 2008 3:59 pm Naslov sporočila: |
Si dodal tadrugi fajl (disp_7seg) vmes med source?
Meni tale error diši na to, da ne najde podkomponente.
| Nazaj na vrh |
trot Član
Objavljeno: Tor Jan 15, 2008 4:04 pm Naslov sporočila: |
Sem (glej priponko), vsaj tako mislim - dal sem "new sorce", in spisal to kar je v 7seg.vhd.
A je potrebno ta fajl (7seg.vhd) kako vključit v glavni fajl (main.vhd) - tako kot se to dela npr. v c-ju (#include ...).
| Opis: |
| Velikost datoteke: |
113.13 KB |
| Pogledana: |
15 krat |
| Nazaj na vrh |
trot Član
Objavljeno: Tor Jan 15, 2008 8:20 pm Naslov sporočila: |
Sem našel napako, v 7seg.vhd sem pisal enkrat "disp_7seg", dugič pa "seg".
| Koda: |
entity disp_7seg is
end disp_7seg;
Samo ne vem zakaj mi preverjanje sintakse samo za 7seg.vhd ni javilo nobene napake...
| Nazaj na vrh |
aly Član
Objavljeno: Sre Jan 16, 2008 12:38 pm Naslov sporočila: |
Če gledam tvojo sliko - fajl 7seg se mora postaviti pod Main fajl. Zraven UCF. Sicer ne bo šlo. Ampak očitno si že našel napako.
Pri VHDL-u je potrebno biti pazljiv - marsikdaj se zadeva na videz normalno prevede. In če ne deluje, je potrebno preveriti vse Warning izpise.
Še ena zanimiva funkcija obstaja - izpis mapiranja pinov.
Med projektnimi fajli nadeš eno takšno datoteko: "<ime_top_modula>_pad.csv"
Tam so izpisani vsi pini izbranega čipa.
| Nazaj na vrh |
trot Član
Objavljeno: Sre Jan 16, 2008 1:10 pm Naslov sporočila: |
| aly je napisal/a: |
| Če gledam tvojo sliko - fajl 7seg se mora postaviti pod Main fajl. Zraven UCF. Sicer ne bo šlo. Ampak očitno si že našel napako. |
Sej potem ko naredim en "instance" tega modul (in ko ni napak) se postavi spodaj. Najbrž bo to v redu.
| Nazaj na vrh |
Uptime: 233 dni
