Vprašanje
jure94
Pridružen-a: Sre 05 Maj 2010 17:11
Prispevkov: 433
Aktiv.: 2.23
Kraj: Jesenice / Lj
PrispevekObjavljeno: Pon Sep 13, 2010 8:07 pm    Naslov sporočila:  Vprašanje Odgovori s citatom
Imam vprašanje glede naslednje kode:
Koda:
 * rgb_strobe.c
 * Distributed under Creative Commons 3.0 -- Attib & Share Alike
 *  Created on: Feb 6, 2010
 *      Author: PaulBo
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#ifndef F_CPU
    #define F_CPU 8000000UL
#endif
//Hardware definitions
#define RED_LED      PB2
#define GREEN_LED    PB1
#define BLUE_LED     PB0
#define ALL_LEDS    ((1 << RED_LED) | (1 << GREEN_LED) | (1 << BLUE_LED))
//Maximum value for led brightness
#define R_MAX 255
#define G_MAX 255
#define B_MAX 255
#define RED_INDEX   0
#define GREEN_INDEX 1
#define BLUE_INDEX  2
//Cycle States
#define RedToYellow     0
#define YellowToGreen   1
#define GreenToCyan     2
#define CyanToBlue      3
#define BlueToMagenta    4
#define MagentaToRed     5
//set red to max (we start in the RedToYellow state)
volatile unsigned char mRgbBuffer[] = {0,0,0};
unsigned char mRgbValues[] = {255,0,0};
unsigned char mState;
void init_timers()
    TIMSK0 = (1 << TOIE0);         // enable overflow interrupt
    TCCR0B = (1 << CS00);          // start timer, no prescale
    //enable interrupts
    sei();
void rgbCycle(){
    switch (mState) {
    case RedToYellow:
        mRgbValues[GREEN_INDEX]++;
        if (mRgbValues[GREEN_INDEX] == G_MAX)
            mState++;
        break;
    case YellowToGreen:
        mRgbValues[RED_INDEX]--;
        if (mRgbValues[RED_INDEX] == 0)
            mState++;
        break;
    case GreenToCyan:
        mRgbValues[BLUE_INDEX]++;
        if (mRgbValues[BLUE_INDEX] == B_MAX)
            mState++;
        break;
    case CyanToBlue:
        mRgbValues[GREEN_INDEX]--;
        if (mRgbValues[GREEN_INDEX] == 0)
            mState++;
        break;
    case BlueToMagenta:
        mRgbValues[RED_INDEX]++;
        if (mRgbValues[RED_INDEX] == R_MAX)
            mState++;
        break;
    case MagentaToRed:
        mRgbValues[BLUE_INDEX]--;
        if (mRgbValues[BLUE_INDEX] == 0)
            mState++;
        break;
    //state should never advance beyond 5.
    //It wraps back to 0 when we reach 6
    mState %= 6;
int main(void){
    //Set LED pins to output
    DDRB |= ALL_LEDS;
    init_timers();
    while (1) {
        rgbCycle();
        _delay_ms(250);
        //I like the orange state and it only lasts for a second
        //so lets extend it a little bit more
        if(mState == RedToYellow)
            _delay_ms(250);
            _delay_ms(250);
    return 0;
 * Timer/Counter overflow interrupt. This is called each time
 * the counter overflows (255 counts/cycles).
ISR(TIM0_OVF_vect)
    //static variables maintain state from one call to the next
    static unsigned char sPortBmask = ALL_LEDS;
    static unsigned char sCounter = 255;
    //set port pins straight away (no waiting for processing)
    PORTB = sPortBmask;
    //this counter will overflow back to 0 after reaching 255.
    //So we end up adjusting the LED states for every 256 interrupts/overflows.
    if(++sCounter == 0)
        mRgbBuffer[RED_INDEX] = mRgbValues[RED_INDEX];
        mRgbBuffer[GREEN_INDEX] = mRgbValues[GREEN_INDEX];
        mRgbBuffer[BLUE_INDEX] = mRgbValues[BLUE_INDEX];
        //set all pins to low (remember this is a common anode LED)
        sPortBmask &=~ ALL_LEDS;
    //this loop is considered for every overflow interrupt.
    //this is the software PWM.
    if(mRgbBuffer[RED_INDEX]   == sCounter) sPortBmask |= (1 << RED_LED);
    if(mRgbBuffer[GREEN_INDEX] == sCounter) sPortBmask |= (1 << GREEN_LED);
    if(mRgbBuffer[BLUE_INDEX]  == sCounter) sPortBmask |= (1 << BLUE_LED);
Imam AVR Studio 4 in mi pokaže opozorilo :
c:/winavr-20100110/lib/gcc/../../avr/include/util/delay.h:85:3: warning: #warning "F_CPU not defined for <util/delay.h>"
Zanima me kaj je narobe.
Lep pozdrav Jure
PS koda je iz te strani : http://www.fangletronics.com/2010/02/rgb-night-lights.html
gumby
Prispevkov: 4066
Aktiv.: 17.60
PrispevekObjavljeno: Pon Sep 13, 2010 8:29 pm    Naslov sporočila:   Odgovori s citatom
Si prebral opozorilo?
Piše, da ni definirana frekvenca procesorja. Brez tega bo prevajalnik bolj težko generiral rutine za zakasnitev...
Tule nisem več aktiven.
jure94
Prispevkov: 433
Aktiv.: 2.23
Kraj: Jesenice / Lj
PrispevekObjavljeno: Pon Sep 13, 2010 8:37 pm    Naslov sporočila:   Odgovori s citatom
Prebral sem že ampak razumel ne. Kako naj pa to popravim (koda je kopirana iz že omenjene strani, sam pa tudi ne znam).
chaos
Prispevkov: 1063
Aktiv.: 4.46
Kraj: Zagorje ob Savi
PrispevekObjavljeno: Pon Sep 13, 2010 8:41 pm    Naslov sporočila:   Odgovori s citatom
Dovolj bo, če premakneš tole:
Koda:
#ifndef F_CPU
#endif
nad #include stavke.
LP!
jure94
Prispevkov: 433
Aktiv.: 2.23
Kraj: Jesenice / Lj
PrispevekObjavljeno: Pon Sep 13, 2010 9:28 pm    Naslov sporočila:   Odgovori s citatom
Build succeeded with 0 Warnings...
Hvala za odgovore Very Happy
Z temle programom sem začel učenje C in ga večino že rezumem.
Lp Jure
gumby
Prispevkov: 4066
Aktiv.: 17.60
PrispevekObjavljeno: Pon Sep 13, 2010 9:43 pm    Naslov sporočila:   Odgovori s citatom
chaos je napisal/a:
Koda:
#ifndef F_CPU
#endif
LP!
Še lepše bi bilo, če bi navedel dejansko hitrost notranjega oscilatorja, ki je na tiny13 4.8 ali 9.6 MHz, ne pa 8.
Prevajalnik se sicer ne bo pritoževal, le zakasnitve bodo popolnoma mimo...
lojzek
Prispevkov: 3407
Aktiv.: 15.35
PrispevekObjavljeno: Tor Sep 14, 2010 6:24 am    Naslov sporočila:   Odgovori s citatom
@jure94:
Druga možnost pa je, da v AVR studiu pritisneš Project -> Configuration Options.
Potem pa v polju "Frequency" vpišeš dejansko frekvenco, s katero bo mikro delal.
Prevajalnik bo pri prevajanju kode pogledal tudi sem, če je tukaj definirana frekvenca.
