| Avtor |
supermaxx Neznanec
Pridružen-a: Ned 24 Apr 2011 17:12 Prispevkov: 4 Aktiv.: 0.02 Kraj: U.K.
Objavljeno: Pon Apr 25, 2011 8:16 pm Naslov sporočila: What Pic Programmer do you use, Are you Happy With It? |
I have 3 pic programmers.
1st Is the EPE TK3 Programmer, I built it myself for use with the EPE mag Teach in series, It is very good and reliable, I've had no problems with It but It's a bit limited with the range of PIC's it is able to program.
2nd is the Brunning software Programmer, It's really a training and development system with integrated LCD and number keypad ETC. I've only programmed a 16F628a with it so far but seems good and reliable with no problems.
3rd is JDM variant I built from a circuit on the internet, I built it because I wanted to program a small 10f device, Its very flakey on my serial port though.
Ive been thinking of making a com port booster with a MAX205 chip, something like this..
http://www.qsl.net/eb4eqa/serial_booster/serial_booster.htm
I'm not sure it will work ok though as I have read that a JDM programmer needs to see a real UART chip to work properly, I invite your views on this.
My next programmer will probably be a PICKIT2, I might build a clone but the Willem programmer also looks interesting as does the Brenner.
Neil |
| Nazaj na vrh |
supermaxx Neznanec
Objavljeno: Pon Apr 25, 2011 10:05 pm Naslov sporočila: |
Hi
Prosimo, upotevajte, je bil ta post prvotno objavljen v oddelku "anglekem jeziku in drugih forumih. "
Moderator se je preselil sem.
Menim, da je le vljudno, da vsaj po google prevod shraniti vsakdo, ki ima prevesti posamično.
Prosimo vas, da odgovor na vse, kar je va materin jezik.
Hvala
Neil
Kaj Pic Programer ne uporabljate, ste zadovoljni s tem?
Imam 3 pic programerje.
1. Ali je EPE TK3 programer, sem zgradil sam za uporabo z EPE mag Teach v seriji, je zelo dober in zanesljiv, sem imel nobenih teav s tem, ampak It's a bit omejena z naborom PIC je to lahko program.
2. je Brunning software programer, To je res sistem usposabljanja in razvoja z vgrajenim LCD in tipkovnico tevilo ETC. Sem le programirani 16F628a z njo tako daleč, vendar se zdi dobro in zanesljivo brez teav.
3. je JDM varianta sem zgradil iz kroga na internetu, sem ga zgradili, ker sem hotel program 10f majhno napravo, njene zelo kosmič na mojem serijska vrata, čeprav.
Ive bilo razmiljanje, kako narediti obnovitveno com pristaniče s čip MAX205, kaj takega ..
Nisem prepričan, da delo bo ok, čeprav, kot sem prebral, da JDM programer mora videti resnično čip UART deluje pravilno, vabim vae mnenje o tem.
Moj naslednji programer bo verjetno PICKIT2, sem lahko gradijo klon pa programer Willem tudi izgleda zanimivo, saj ne Brenner.
Neil |
| Nazaj na vrh |
matjay Član
Pridružen-a: Pon 06 Dec 2004 22:07 Prispevkov: 548 Aktiv.: 2.22 Kraj: Ljubljana
| Nazaj na vrh |
Pridružen-a: Tor 28 Sep 2004 14:51 Prispevkov: 9407 Aktiv.: 38.07 Kraj: Kranj - struževo
Objavljeno: Pon Apr 25, 2011 11:00 pm Naslov sporočila: |
I was using WinPicProg. Printer port connection and external power supply. I was using only 16F series of chips. _________________ I'm going to stand outside, so if anyone asks, I'm outstanding  |
| Nazaj na vrh |
matjazkariz Član
Pridružen-a: Sre 03 Nov 2004 18:09 Prispevkov: 1026 Aktiv.: 4.15
Objavljeno: Tor Apr 26, 2011 1:23 pm Naslov sporočila: |
I use ICD2 clone for programming all 5V microcontollers. It works as a debugger as well. You can find an extensive topic regarding this device searching this forum or better yet, find the topic on Edaboard forum (english language) where the debugger clone originates from.
Regards, _________________ LP, Matjaž |
| Nazaj na vrh |
Azrael Član
Pridružen-a: Čet 29 Jan 2009 19:46 Prispevkov: 4432 Aktiv.: 21.14 Kraj: Gorje
Objavljeno: Tor Apr 26, 2011 1:53 pm Naslov sporočila: |
I using Willem PCB 3.
Connecting on the printer port and power supply via USB or external power supply. I use it for the 12F, 16F, flash, EPROM 27 xxx and 27Cxxx integrated circuits.
Programmer hardware itself is fine, but problems with the software for it.
Original software Willem EPROM work with 12F and EPROM / Flash chip, but most of the 16F chips work properly only with ICprog runs in Windows 98
Uporabljam Willem PCB 3.
Priklop na tiskalniška vrata in napajanje preko USB ali zunanjega napajalnika. Uporabljam ga za 12F, 16F, flash, EPROM 27 xxx in 27Cxxx integriranih vezjih.
Sama strojna oprema programatorja je v redu, vendar so težave s programsko opremo zanj.
Izvirna programska oprema Willem Eprom dela z 12F in EPROM / Flash chipi, vendar večina 16F chipov dela pravilno samo z ICprog v Windows 98. |
| Nazaj na vrh |
