Lenze EPM-S602 counter
polhar
Pridružen-a: Sob 04 Mar 2006 9:11
Prispevkov: 360
Aktiv.: 1.53
Kraj: Dol pri Ljubljani
PrispevekObjavljeno: Sre Nov 09, 2011 4:26 pm    Naslov sporočila:  Lenze EPM-S602 counter Odgovori s citatom
Imam težavo pri branju vrednosti števca. Izgleda kot da ga ne nastavim pravilno in je števec v nekem stop načinu.
uporabljam Lenze EPM-S602 counter (nanjga je prikljopljen enkoder), programiram pa v codesys-2
Bi mogoče kdo vedel katere bite moram postavit da bo delovalo.
Do sedaj mi ga je ratalo nastavit tako da je bil status word=100100100 (STS_SW-GATE, STS_GATE, STS_C_UP) vendar ko sem vrtel enkoder ni delovalo.
lučke za indikacijo na modulu delujejo in mi prikazujejo smer vrtenja enkoderja (torej sklepam da je priklopljeno pravilno)
Koda:
EPM-S602 Status word
Bit   Designation           Function
0     STS_SYNC - Reset was active
1     STS_CTRL_COMP - Is set if the comparison bit is enabled
2     STS_SW-GATE - Software gate status (set if SW gate active)
3     STS_RST - Status of reset input
4     - Reserved
5     STS_GATE - Status of internal gate (set if internal gate active)
6     STS_COMP - Status of comparison bit
7     STS_C_DN - Status set for counter direction backwards
8     STS_C_UP - Status set for counter direction forwards
9     STS_CMP - Comparator status is set if the comparison condition is met.
                If the comparison is deactivated (counter mode byte 1 = 000b), the bit has no function.
10    STS_END - Status set if final value was reached
11    STS_OFLW - Status set in the case of overflow
12    STS_UFLW - Status set in the case of underflow
13    STS_ZP - Status set in the case of zero crossing
14    - Reserved
15    - Reserved
EPM-S602 Control word
0     CTRL_SYNC_SET - Activates the reset mode
1     CTRL_COMP_SET - Enables the comparison bit
2     SW_GATE_SET - Sets the software gate
3     - Reserved
4     - Reserved
5     COUNTERVAL_SET - Sets the counter temporarily to the value in the set value
6     RES_SET Resets the following bits with a 0-1 edge:
              STS_CMP, STS_END, STS_OFLW, STS_UFLW and STS_ZP
7     - Reserved
8     CTRL_SYNC_RESET - Deactivates the reset mode
9     CTRL_COMP_RESET - Inhibits the comparison bit
10    SW_GATE_RESET - Resets the software gate
11... 15 - Reserved
