| Avtor |
Highlag Član
Pridružen-a: Pet 23 Jan 2004 20:42 Prispevkov: 4034 Aktiv.: 16.33 Kraj: Črnuče
Objavljeno: Pet Okt 14, 2005 6:44 pm Naslov sporočila: Ojačevalnik za slušalke (avdio) |
Kategorija: Avdio
Težavnost izdelave: 3
Tehnološka zahtevnost:2
Potrebno predznanje: 2
Predvideni čas izdelave: 16h
Predvidena orodja in oprema: Spajkanik, univerzalni inštrument za merjenje napetosti, orodja za obdelavo tiskanih vezij
| Koda: |
Kosovnica ojačevalnik:
Oznaka..............Tip..............................Potrebna količina
P1..................100K log stereo potenciometer....1
R1a/b...............1M Ohm 1W metal..................2
R2a/b...............33 Ohm 0,5W metal................2
R3a/b...............47K Ohm 1W metal.................2
R4a/b...............820Ohm 1W metal..................2
R5..................4,7K Ohm 10W AL..................1
R6a/b...............3,3K Ohm 25W AL..................2
R7a/b...............10K Ohm 0,5W metal...............2
C1, C2..............220uF 450V ELKO..................2
C1a, C2a............0,1uF 400V MKT...................2
C3a/b...............220uF 100V ELKO..................2
C4a/b...............0,22uF 250V MKT..................2
V1..................E88CC............................1
V2..................6AS7G............................1
V1-podnožje.........Noval pcb-type tube socket.......1
V2-podnožje.........Octal pcb-type tube socket.......1
| Koda: |
Kosovnica usmernik:
R8, R9..............6,8 Ohm 1W metal ...............2
R3..................33 Ohm 0,5W metal................1
C5, C6 *............22nF 1KV MKT.....................2
D1, D2..............1N4007...........................2
C7, C8, C1..........220uF 450V ELKO..................3
C7a, C8a, C8a1......0,1uF 400V MKT...................3
C9..................1uF 250V MKT.....................1
D3-D6...............P1000J...........................4
C10.................22000uF 25V ELKO.................1
C11.................10uF 25V ELKO....................1
C11a................0,1uF 400V MKT...................1
IC1.................LT1083CP.........................1
P2..................1K Ohm multiturn trimpot.........1
R11.................120Ohm 1/4W......................1
C12.................100uF 25V ELKO...................1
L1..................10H, 90mA, 270Ohm................1
TR1.................Transformator 230/9V 60W.........1
TR2.................Transformator 230V/115V 30W......1
Cilj je bila izdelava vrhunskega ojačevalnika za pogon enih izmed boljših odprtih slušalk: Sennheiser HD600
Odločil sem se za izdelavo ojačevalnika, ki ga je uglasbil Aren van Waarde. Iz opisov navdušenih uporabnikov je bilo razvidno, da je ojačevalnik dober, potrebuje malo delov, ki so relativno lahko dobavljivi in ne pretirano predragi.
Pri nabavi delov sem poizkušal kupiti dele višje kakovosti. Tako so vsi mali upori metalplastni, upori višje moči so upori v AL ohišju, transformatorja imata dodaten magnetni oklep, izhodni kondenzatorji so "audio-grade" kondenzatorji. Potenciometer za nastavljanje glasnosti je profesionalni Alps RK27112.
Po sestavljanju vezij sem se najprej lotil testiranja usmernika, saj je ravno od njega precej odvisna kakovost ojačevalnika. Napetost napajanja katod je bila nastavljena na 6V. Predpisana napetost je sicer 6,3V, vendar se 0.3V nižja napetost pri delovanju ne pozna, se pa pozna pri življenski dobi elektronke.
Ko je bil ojačevalnik že sestavljen in deloval sem opazil, da se še vedno sliši rahel brum. Po meritvah, ki sem jih opravil se je brum pojavil v anodni napetosti. Čeprav izredno majhen, tako rekoč nemerljiv (0,1V) je bil dovolj slišen, da me je motil. Zato sem kasneje dodal še en RC filter v usmernik za anodno napetost. Ta je brum odstranil, do te mere, da je komaj zaznaven. Žaj na tiskanem vezju, ki je pripet ni tega RC člena iz preprostega razloga, ker Free verzija Eagla popdpira vezja do velikosti 100x80mm.
Anodna napetost je visoka, zato je pri testiranju potrebna izredna previdnost! (Sem sam občutil enkrat) Ker je poraba ojačevalca kar se tiče anodne napetosti mala, le ta ostane prisotna precej dolgo časa.
Pri montaži komponent ni potrebna posebna pazljivost. Moje tiskano vezje predvideva spajkanje podnožja za elektronke na stran bakra. Zaradi dveh razlogov. Prvi je bil izbrano ohišje - elektronke štrlijo iz ohišja, druga pa je gretje elektronk, ki sevajo kar precej toplote. V primeru izdelave drugačnega vezje je potrebno poskrbeti, da so elektroliti dovolj odmaknjeni.
Povezave: Aren van Waarde
| Opis: |
| Notranjost končanega izdelka |
| Velikost datoteke: |
122.83 KB |
| Pogledana: |
630 krat |
| Opis: |
13.45 KB |
| Pogledana: |
327 krat |
| Opis: |
16.67 KB |
| Pogledana: |
248 krat |
| Opis: |
| Ime datoteke: |
usmernik.pdf |
47.82 KB |
| Downloadano: |
68 krat |
| Opis: |
| Ime datoteke: |
ojacevalnik.pdf |
59.74 KB |
| Downloadano: |
88 krat |
| Nazaj na vrh |
