Problem z programatorjem
skalpel
Pridružen-a: Tor 31 Jan 2012 19:46
Prispevkov: 432
Aktiv.: 2.50
Kraj: Šenčur
PrispevekObjavljeno: Pon Jul 09, 2012 4:15 pm    Naslov sporočila:  Problem z programatorjem Odgovori s citatom
Pred primi dnevi sem dobil kitajski usbasp programator, ko hočem naložiti driver mi ga ne naloži, kaj naj storim? V katerem programu naj programiram sej avr studio in codevision ne podpirata tega programatorja? Khazama je pa čudna saj sploh nemorem izbrati kontrolerja in nima okna da bi napisal kodo.
kastaneda
Prispevkov: 459
Aktiv.: 2.29
PrispevekObjavljeno: Pon Jul 09, 2012 4:38 pm    Naslov sporočila:   Odgovori s citatom
Na TEJ strani med drugim piše tole:
Koda:
follow these steps to install the usbasp drivers on windows 7 for both 64bit and 32 bit platform
1)download the zipped folder LibUSB-64bitfrom the following link
http://sites.google.com/site/openusbboard/file-cabinet
2)plug your USBasp programmer into the USB port
3)extract the file and browse to LibUSB-64bit\libusb-win32-bin-1.2.1.0\bin\x86
4)run inf-wizard.exe
5)Inf-wizard will start, click Next
6)select the device 'USBasp' from the lsit of devices shown and click next
7)make sure these values are associated with the give parameters before proceeding
vendor ID (hex format) = 0x16C0
product ID (hex format) = 0x05DC
mi (hex format) = leave it blank
manufacturer name = VOTI
device name = USBasp
then click next
8)save the information file '.inf' generated in
LibUSB-64bit\libusb-win32-bin-1.2.1.0\bin\amd64
(for 64 bit users)
(for 32 bit users)
9)click install now to install the driver
10)if a windows warning appears telling this driver is not verified , just click on 'install this driver software anyway'
11)once the driver completes installation saying 'installation successful' click ok
thats it! you are good to go!
note - im using 64 bit edition of windows ultimate and this procedure worked for me when all the others failed. i have not tested this procedure for 32 bit systems though.
Srečko
skalpel
Prispevkov: 432
Aktiv.: 2.50
Kraj: Šenčur
PrispevekObjavljeno: Pon Jul 09, 2012 5:26 pm    Naslov sporočila:   Odgovori s citatom
Sedaj sem delal po tem vodiču ki si ga objavil, ampak pri 8 koraku se mi zatakne... Prosim za pomoč.
RGorazd
Prispevkov: 1717
Aktiv.: 6.95
Kraj: Ig
PrispevekObjavljeno: Pon Jul 09, 2012 6:56 pm    Naslov sporočila:   Odgovori s citatom
Khazama ni čuden program, ampak zelo dober. Je pa samo to...programming software, ne pa IDE + COMPILER + DEBUGGER. Za to lahko uporabiš AVR Studio, ali pa Notepad++ ter WinAvr ukazno lupino. USBasp podpira tudi AVRDuDe, ter nenazadnje ga podpira tudi Bascom. Jaz ga uporabljam v navezi z AVR Studiom ter Khazama. V AVR Studiu napišem program, compiler mi generira *.hex file, ga odprem s Khazama in zapečem na AVR. Lahko bi uporabil AVRDude in ga klical znotraj AVRStudia, vendar ima AVRDude eno grdo navado in to je ta, da ne sprosti .hex fajla, bi moral file vedno znova nalagati, pri Khazami pa to ni potrebno. Samo Build ter program in je stvar rešena.
LP G
._. _ _ ._. _.__. _|
[ (_](_)[ (_] /_(_]
._|
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Pon Jul 09, 2012 10:23 pm    Naslov sporočila:   Odgovori s citatom
Za programiranje z USBasp programatorjem uporabljam ProgISP (ver.1.72) in mi deluje brez problemov na Win 7 x64 kot na Win XP. Prav tako nisem imel nikakršnih problemov z inštalacijo gonilnikov (brez spreminjanja inf datotek).
Uporabljam pa naslednje gonilnike:
USBasp-win-driver-x86-x64-ia64-v1.2.5.zip
Gonilniki za USBasp
 Ime datoteke:  USBasp-win-driver-x86-x64-ia64-v1.2.5.zip
 Velikost datoteke:  292.6 KB
 Downloadano:  8 krat
Users Guide (AC-PG-USBASP-UG-V2.0).pdf
Navodila za USBasp.
 Ime datoteke:  Users Guide (AC-PG-USBASP-UG-V2.0).pdf
 Velikost datoteke:  1.95 MB
 Downloadano:  26 krat
Nazadnje urejal/a Jaka57 Pon Jul 09, 2012 10:30 pm; skupaj popravljeno 1 krat
skalpel
Prispevkov: 432
Aktiv.: 2.50
Kraj: Šenčur
PrispevekObjavljeno: Pon Jul 09, 2012 10:30 pm    Naslov sporočila:   Odgovori s citatom
Ker gonilnik si pa uporabil? Jaz sem do sedaj probal dva pa mi ne delata...
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Pon Jul 09, 2012 10:32 pm    Naslov sporočila:   Odgovori s citatom
V pdf datoteki (Users Guide) imaš navodila, kako inštalirat gonilnike.
skalpel
Prispevkov: 432
Aktiv.: 2.50
Kraj: Šenčur
PrispevekObjavljeno: Tor Jul 10, 2012 6:15 pm    Naslov sporočila:   Odgovori s citatom
Dela hvala za pomoč...
Uptime: 233 dni
