I2c ic-ji
Prispevkov: 14803
Aktiv.: 59.91
PrispevekObjavljeno: Sre Jan 02, 2013 1:50 pm    Naslov sporočila:  I2c ic-ji Odgovori s citatom
Iskal sem en NF stereo ojačevalec tam do 10W iz I2C kontrolo.
Naletel sem na tole: ***klik***
Morda pride komu prav.
Takega čipa vseeno nisem našel. Če kdo pozna kakega, oz najde še kak spisek I2c čipovja naj ga doda v temo.
    MAXIM
    I/O expanders:
    MAX6956 20-Port LED Display Driver and digital I/O Expander constant current sink, up to 16 Devices, Interrupt
    LED Driver:
    MAX6953 4 Digit Matrix LED Driver, up to 140 LEDs
    Data Converters:
    MAX127/MAX128 octal 12 Bit DAC
    MAX521 Octal 8 Bit DAC
    MAX 1036/1037 4-channel 8-bit ADC, single supply (5V / 3.3V)
    MAX 1038/1039 12-channel 8-bit ADC, single supply (5V / 3.3V)
    Microchip
    Expanders:
    MCP23016 16-bit I/O Port Expander
    MCP23017 16-bit I/O Port Expander
    MCP23008 8-bit I/O Port Expander
    Data converters:
    MCP3021 10 bit ADC, one channel
    MCP3221 12 bit ADC, one channel
    MCP3421 18 bit ADC, one channel
    MCP4725 12 bit ADC, one channel
    TC1320 8 bit ADC, one channel
    TC1321 10 bit ADC, one channel
    Serial EEPROMs:
    24AA00 128
    24C00 128
    24LC00 128
    24AA01 1K
    24LC01B 1K
    24C01C 1K
    24LC014 1K
    24LC21A 1K
    24LCS21A 1K
    24AA02 2K
    24LC02B 2K
    24C02C 2K
    24LC024 2K
    24LC025 2K
    24LCS52 2K
    24AA04 4K
    24LC04B 4K
    24AA08 8K
    24LC08B 8K
    24AA16 16K
    24LC16B 16K
    24AA32A 32K
    24LC32A 32K
    24AA64 64K
    24LC64 64K
    24AA65 64K
    24LC65 64K
    24AA128 128K
    24LC128 128K
    24FC128 128K
    24AA256 256K
    24LC256 256K
    24FC256 256K
    24AA512 512K
    24LC512 512K
    24FC512 512K
    24AA515 512K
    24LC515 512K
    24FC515 512K
    24AA1025 1024K
    24LC1025 1024K
    24FC1025 1024K
    Niigata Seimitsu
    NS73M FM Transmitter (source: sparcfun.com) I2C maybe problematic?
    NXP (Philips)
    LCD/LED Drivers:
    PCA 9533 4-bit LED dimmer (8-bit PWM) suitable for H-Bridges (L293D)
    PCA 9531 8-bit LED dimmer (8-bit PWM)
    PCA 9532 16-bit LED dimmer (8-bit PWM)
    PCF 8566 96 segment LCD driver
    PCF 8568 LCD Row driver for dot matrix displays.
    PCF 8569 LCD Column driver for DOT matrix displays
    PCF 8576 160 segment LCD driver
    PCD 8577 64 Segment LCD driver
    PCF 8578 LCD Row driver for Dot matrix LCD's
    PCD 8579 Column driver for Dot matrix LCD's
    SAA 1064 4 Digit Led driver
    I/O expanders:
    PCF 8574 8 Bit I/O port
    PCF 8574A 8 Bit I/O port different address.
    SAA 1300 5 Bit high current driver
    Data converters:
    PCF 8591 4 channel ADC + One DAC (all 8 bits)
    TDA 8442 Quad 6 bit DAC
    TDA 8444 Octal 6 bit DAC
    Memory:
    PCF 8570 256 byte static ram
    PCf 8571 128 byte static ram
    PCF 8581 128 byte EEprom
    PCF 8582 256 byte EEprom
    PCF 8583 256 byte RAM + Realtime clock and calendar
    PCF 8594 512 byte EEprom
    PCF 8598 1K byte EEprom
    Clocks:
    PCF 8573 Clock/Calendar
    PCF 8583 Clock/Calendar with 256 byte Ram
    Audio / Video:
    PCD3311 3312 DTMF / Tone generator
    SAA1136 PCM interface
    SAA524x Teletext processor
    SAA7191 S-VHS decoder
    SAA7192 Digital color space converter
    SAA7199 Digital encoder
    SAA9020 Field memory controller
    SAA9051 Digital TV decoder
    SAA9068 PIPCO Picture in picture system
    SAB3035 3037 Tuning interface
    SAF1135 VPS decoder
    TDA4680 Video processor
    TDA8421 HiFi stereo audio processor
    TDA8425 Audio processor with loudspeaker channel
    TDA8440 Video switch
    TDA8442 Color decoder interface
    TDA8443 YUV to RGB unit
    TDA8461 PAL / NTSC color decoder
    TEA6100 Fm tuning interface
    TEA6300 6310 Sound fader control
    TSA551x TV Pll synthesizer
    TSA6057 Fm Pll synthesizer
    Miscellaneous:
    SAA1300 5 bit high current driver
    UMF1009 Frequency synthesizer
    Siemens
    Audio Video:
    SDA3312 TV PLL synthesizer
    SDA2121 TV PLL synthesizer
    Memories:
    SDA2516 1K bit EEprom
    SDA2526 2K bit EEprom
    SDA2546 4K bit EEprom
    SDA2586 8K bit EEprom
    SDA3526 2K bit EEprom with write protection
    SDA3546 4K bit EEprom with write protection
    SDA3586 8K bit EEprom with write protection
    STMicroelectronics
    Clocks:
    M41T00S RTC w. 64b (8 x 8)
    M41T00SC6430 RTC w. Embedded Crystal; 64Kb (8192 x 8); w. EEPROM
    M41T11 28 RTC w. BATTERY; 512b (64 x 8);
    M41T56 512b RTC w. (64 x 8); SRAM
    M41T56C64 RTC w. Embedded Crystal; 64Kb (8192 x 8); w. EEPROM
    M41T00 RTC w. 64b (8 x 8)
    M41ST84W RTC w. 512b (64 x 8); RTC SUPERVISOR
    M41ST85W RTC w. BATTERY; with Embedded Crystal; 512b (64 x 8); RTC SUPERVISOR
    M41ST87W RTC w. Embedded Crystal; 1280b (160 x 8); RTC SUPERVISOR
    M41ST87Y RTC w. with Embedded Crystal; 1280b (160 x 8); RTC SUPERVISOR
    M41T0 RTC w. 64b (8 x 8)
    M41T60 RTC w. 64b (8 x 8)
    M41T62 RTC w. 128b (16 x 8); with Alarms
    M41T65 RTC w. 128b (16 x 8); with Alarms
    M41T80 RTC w. 160b (20 x 8); with Alarms
    M41T81S RTC w. Embedded Crystal; 160b (20 x 8); with Alarms
    M41T82 RTC w. 256b (32 x 8), Battery Switchover
    M41T83 RTC w. Embedded Crystal 256b (32 x 8), Battery Switchover
    M41T256Y RTC w. BAT Cu wo/socket 256Kb (32K x 8)
    M41T81 RTC w. 160b (20 x 8)
    Memory:
    M24C01-R 1 kbit EEPROM
    M24C01-W 1 kbit EEPROM
    M24C02-R 2 kbit EEPROM
    M24C02-W 2 kbit EEPROM
    M24C04-R 4 kbit EEPROM
    M24C04-W 4 kbit EEPROM
    M24C08-R 8 kbit EEPROM
    M24C08-W 8 kbit EEPROM
    M24C16-R 16 kbit EEPROM
    M24C16-W 16 kbit EEPROM
    M24C32-F 32 kbit EEPROM
    M24C32-R 32 kbit EEPROM
    M24C32-W 32 kbit EEPROM
    M24C64-R 64 kbit EEPROM
    M24C64-W 64 kbit EEPROM
    M34D64-W 64 kbit EEPROM
    M24128-BR 128 kbit EEPROM
    M24128-BW 128 kbit EEPROM
    M24256-BR 256 kbit EEPROM
    M24256-BW 256 kbit EEPROM
    M24512-R 512 kbit EEPROM
    M24512-W 512 kbit EEPROM
    M24M01-R 1000 kbit EEPROM
    Misc.:
    LIS3LV02DL Linear Accelerometer 3-Axis ±2g/ ±6g with digital interface
    LIS3LV02DQ Linear Accelerometer 3-Axis ±2g/ ±6g Full Scale with digital interface
    Texas Instruments
    Audio/Video:
    TLV320AIC3101 6 Inputs, 6 Outputs, Speaker & Headphone Amp., Enh. Digital Effects, PowerTune
    Buffers:
    P82B96 Dual Bidirectional Bus Buffer
    Expanders:
    PCA6107 Remote 8-Bit Low-Power I/O Expander With Interrupt Output, Reset, and Config Registers
    PCA9534 Remote 8-Bit Low-Power I/O Expander with Interrupt Output and Configuration Registers
    PCA9534A Remote 8-Bit Low-Power I/O Expander with Interrupt Output and Configuration Registers
    PCA9535 Remote 16-Bit Low-Power I/O Expander With Interrupt Output and Config Registers
    PCA9536 Remote 4-Bit I/O Expander with Configuration Registers
    PCA9538 Remote 8-Bit Low-Power I/O Expander With Interrupt Output, Reset, and Config Registers
    PCA9539 Remote 16-Bit Low-Power I/O Expander With Interrupt Output, Reset & Config. Registers
    PCA9554A Remote 8-Bit I/O Expander with Interrupt Output and Configuration Registers
    PCA9555 Remote 16-Bit I/O Expander With Interrupt Output And Configuration Registers
    PCA9557 Remote 8-Bit Low-Power I/O Expander with Reset and Configuration Registers
    PCF8574 Remote 8-Bit I/O Expander
    PCF8574A Remote 8-Bit I/O Expander
    PCF8575 Remote 16-Bit I/O Expander with Interrupt Output
    PCF8575C Remote 16-Bit I/O Expander with Interrupt Output
    TCA6408 Low-Voltage 8-Bit I/O Expander With Interrupt Output, Reset, and Config Register
    Multiplexers:
    PCA8550 Non-Volatile 5-Bit Registered Multiplexer with I2C Interface
    PCA9544A 4-Channel I2C And SMBus Multiplexer With Interrupt Logic
    PCA9545A 4-Channel I2C And SMBus Multiplexer With Interrupt Logic And Reset Functions
    PCA9546A 4-Channel I2C And SMBus Multiplexer With Reset Functions
    Levelshifters:
    PCA9306 Dual Bi-Directional I2C-Bus and SMBus Voltage Level-Translator
    Repeaters:
    PCA9515A Dual Bidirectional I2C Bus and SMBus Repeater
    Hubs/switches:
    PCA9518 Expandable Five-Channel I2C Hub
    PCA9543A Two-Channel I2C-Bus Switch With Interrupt Logic and Reset
    PCA9548A 8-Channel I2C Switch With Reset
    LED-Drivers:
    TCA6507 Low-Voltage 7-Bit I2C and SMBus LED Driver With Intensity Control and Shutdown
    Xicor
    Memories:
    X24C01 1k bit EEprom
    X24012 1k bit EEprom
    X24C02 2k bit EEprom
    X24022 2k bit EEprom
    X24C04 4k bit EEprom
    X24042 4k bit EEprom
    X24C08 8k bit EEprom
    X24C16 16k bit EEprom
    X24164 16k bit EEprom
    X24X00 128 bit EEprom
    X24001 128 bit EEprom
Aktiv.: 57.58
PrispevekObjavljeno: Sre Jan 02, 2013 2:18 pm    Naslov sporočila:  Re: I2c ic-ji Odgovori s citatom
Silvo je napisal/a:
Obstajajo tudi i2c potenciometri.
serija od analog devices AD51yyBCPZ xx y: številka xx upornost v k ohm
serija od intersil ISL223xx
serija Microchip MCP44xx
Pa še je tega. Torej lahko to kobiniraš z ojačevalnikom, ki ima fiksno ojačenje.
borber
Prispevkov: 3111
Aktiv.: 12.59
Kraj: LJUBLJANA
PrispevekObjavljeno: Sre Jan 02, 2013 2:36 pm    Naslov sporočila:   Odgovori s citatom
LM4681
10 Watt Stereo CLASS D Audio Power Amplifier with Stereo Headphone Amplifier and I2C/SPI Volume Control
MAX9768
10W Mono Class D Speaker Amplifier with Volume Control
itd.
Prispevkov: 14803
Aktiv.: 59.91
PrispevekObjavljeno: Sre Jan 02, 2013 4:38 pm    Naslov sporočila:   Odgovori s citatom
Borber hvala,
Tisti prvi je zelo zanimiv, a ga Farnell nima. Pri Digikey-ju je na spisku a ni zaloge.
Volk ve, zakjaj gre Very Happy , no varianta so seveda tudi digitalni potecionetri.
PS
Kaj več napišem, ko bo zadeva tako daleč, da bo kaj za pokazat Wink Za enkrat je vse še na testni plošči.
Prispevkov: 16777193
Aktiv.: 67899.41
PrispevekObjavljeno: Sre Jan 02, 2013 7:49 pm    Naslov sporočila:   Odgovori s citatom
KernelPanic
Pridružen-a: Pon 13 Avg 2012 10:29
Prispevkov: 162
Aktiv.: 0.97
PrispevekObjavljeno: Pet Jan 04, 2013 2:50 pm    Naslov sporočila:   Odgovori s citatom
ST TEA6420: Audio Matrix, 5 Input, 4 Output, glede na napetost na pinu (0V, 5V) se mu lahko nastavljata dva razlicna naslova!
Lp,
Marko
Nazadnje urejal/a KernelPanic Pet Jan 04, 2013 7:14 pm; skupaj popravljeno 1 krat
bpavsic
Pridružen-a: Pet 03 Apr 2009 20:45
Prispevkov: 354
Aktiv.: 1.71
PrispevekObjavljeno: Pet Jan 04, 2013 5:13 pm    Naslov sporočila:   Odgovori s citatom
Microchip
MCP9808 - i2c temperaturni senzor.
tilz0R
Pridružen-a: Čet 31 Maj 2012 15:39
Prispevkov: 900
Aktiv.: 5.33
Kraj: Črnomelj
PrispevekObjavljeno: Tor Okt 08, 2013 12:15 pm    Naslov sporočila:   Odgovori s citatom
Maxim
DS1307 RTC module
Knowledge sharing is caring.
majerle.eu | stm32f4-discovery.net
Aktiv.: 67899.39
PrispevekObjavljeno: Tor Okt 08, 2013 1:22 pm    Naslov sporočila:   Odgovori s citatom
