powerPC Član
Pridružen-a: Tor 19 Feb 2013 21:59 Prispevkov: 60 Aktiv.: 0.40 Kraj: Postojna
Objavljeno: Tor Mar 19, 2013 7:45 pm Naslov sporočila: vhdl povezava zadnjega Carry bita na signal |
sem začetnik v vhdl zato je verjetno zadeva vam očitna.
Koda: |
entity ndn_alu is
Port ( X,Y: in STD_LOGIC_VECTOR (7 downto 0);
S: out STD_LOGIC_VECTOR (7 downto 0);
nAddSub: in std_logic;
Negative: out std_logic;
Cout: out std_logic;
Overflow: out std_logic;
Zero: out std_logic
end ndn_alu;
architecture Alu of ndn_alu is
signal p0: std_logic;
signal outzac: std_logic;
component rc_add_n_bit is
generic(n: natural :=4);
port(
Cin: in std_logic;
X: in std_logic_vector(n-1 downto 0);
Y: in std_logic_vector(n-1 downto 0);
C: inout std_logic_vector(n-1 downto 0);
S: out std_logic_vector(n-1 downto 0)
end component;
begin
U1: rc_add_n_bit generic map (n => 8) port map (p0,Cout,X,Y,[b]outzac[/b],S);
end Alu;
Kako lahko povežem zadnji Carry bit, na nek signal. Tisti prejšni so povezani na druge, gre za ripple carry polne seštevalnike. Kako samo zadnji bit povezat drugam? |
