povezava navitij v zvezdo
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Sre Jun 05, 2013 9:13 pm    Naslov sporočila:   Odgovori s citatom
Ali lahko ta sistem uporabim, da določim začetke in konce špul? Opisano je za vezavo v trikot, jaz pa bi enako izvedel, da dobim začetke in konce za v zvezdo.
Take one winding (lets call this one 1), this is your reference. Spin motor (drill press ?) and measure AC voltage accross this
winding using normal multimeter (in the AC setting !!!!).
Take another winding (2 ?) and connect it to the first one in series. Measure the total series AC voltage. I know it sounds a bit
strange but the total series AC voltage should be equal to the AC voltage of a single winding. If you measure around 1.7 times the
voltage of a single winding then reverse the connections of winding 2 to end up with an AC voltage equal to that of a single winding.
Now connect the third winding (3) in series with 1 and 2 and measure the AC voltage again. If you measure 2 times the voltage
of a single winding, reverse the connections of winding 3. If the total AC voltage of the three series connected windings is 0 then
you've connected everything in the correct order. You can now short the start of winding 1 with the end of winding 3 (remember,
the voltage was 0 so this is no problem).
Now you got your 3 windings connected in delta.
3 x 3 = 9
Aktiv.: 39.65
PrispevekObjavljeno: Sre Jun 05, 2013 11:22 pm    Naslov sporočila:   Odgovori s citatom
ro-bi
to je važno samo pri trikotu, kjer mora biti vsota nič, sicer imaš kratek stik.
Pri zvezdi je popolnoma vseeno, saj so navitja staknjena samo v eni točki in ni možnosti kratkega stika.
Če boš eno tuljavo okrog obrnil, se ti bo sistem električno vrtel v drugo smer. Če boš imel 3f usmernik (6 diod) je popolnoma vseeno kako zvežeš tuljave.
transalp
Pridružen-a: Čet 31 Maj 2012 7:08
Prispevkov: 340
Aktiv.: 2.14
Kraj: Ig
PrispevekObjavljeno: Čet Jun 06, 2013 8:30 am    Naslov sporočila:   Odgovori s citatom
aly je napisal/a:
ro-bi
Nisem prepričan, če tole povsem drži... Če vzamem trifazni generator, ki je pravilno zvezan v zvezdo (kar se tiče začetkov in koncev navitij), se z zamenjavo dveh zunanjih priključkov sistem električno res vrti v drugo smer.
Drugače je, če na enem od treh navitij, vezanih v zvezdo, zamenjam med seboj začetek in konec enega (poljubno izbranega) navitja. Tisti konec, ki je bil prej izvod, je torej sedaj vezan na zvezdišče in obratno - kar je bilo priključeno v zvezdišče, postane izvod. V kazalčnem diagramu je torej le ena od faz obrnjena na glavo, ostalo ostane enako. Kazalci sedaj niso več simetrično porazdeljeni v zvezdo s 120 stopinjskimi koti, temveč dobimo "kazalčno pokveko" s koti 60, 60 in 240 stopinj.
Če se motim, me pa prosim popravite ... Rolling Eyes
Aktiv.: 39.65
PrispevekObjavljeno: Čet Jun 06, 2013 7:27 pm    Naslov sporočila:   Odgovori s citatom
hmmm... mogoče imaš pa prav. (pozna ura je bila)
Če se zamenja konca enega navitja, se faza tega izvoda obrne za 180°. Ampak na drugi strani ni navitja, ki bi "skompenziral" obrnjeno fazo.
Jaz si lažje predstavljam v časovnem poteku kot fazni diagram. In tudi napetosti bi šel preverjat z osciloskopom.
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Čet Jun 06, 2013 7:53 pm    Naslov sporočila:   Odgovori s citatom
Sem določil začetke in konce navitij ter povezal v zvezdo. Napetost AC je narasla iz 10,4V na 18,4V pri 2000 rpm.
Sedaj mi je previsoka za drekt in bom moral MPPT regulator gor priklopit.
Ali bi bilo izvedljivo, da navijem trofazni trafo da znižam napetost?
Frekvence ne vem, je pa motor 14 polni in ima 2000 rpm.
Tok bo okrog 10A.
Kako jedro bi moralo biti?
3 x 3 = 9
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Čet Jun 06, 2013 10:16 pm    Naslov sporočila:   Odgovori s citatom
Sprobal sem z motociklističnim reglatorjem in ne dela dobro, ker višek izgleda veže v kratek stik in generator "cuka" in trza.
Ali kdo pozna shemo PWM vezja, ki bi ob vhodni napetosti od 20 do 50V DC , na izhodu vedno imelo 14,4V, max. tok, ki bi ga moralo preživet je okrog 12A?
3 x 3 = 9
Aktiv.: 32.59
PrispevekObjavljeno: Čet Jun 06, 2013 10:33 pm    Naslov sporočila:   Odgovori s citatom
Zakaj pa frekvence enostavno ne pomeriš, saj ima večina današnjih multimetrov vgrajeno to funkcijo in za ta namen bo več kot dovolj?
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Pet Jun 07, 2013 2:47 pm    Naslov sporočila:   Odgovori s citatom
Na mojem multimetru ni frekvence.
Je pa verjetno enostavneje narediti step down ali step up, ki ju potem lahko še zreguliram, da ven dobim največ.
Za step up bi bilo dovolj, če prenese 30v vhoda max., za step down pa 50v.
Dajte mi prosim kako shemo prilepit Pray
3 x 3 = 9
zamot1
Pridružen-a: Sre 28 Feb 2007 15:11
Prispevkov: 148
Aktiv.: 0.66
PrispevekObjavljeno: Pet Jun 07, 2013 3:50 pm    Naslov sporočila:  REgulator? Odgovori s citatom
Ali si imel pri motociklističnem regulatorju priklopljen tudi akus?
Ali boš polnil akumulator, ali direktno kuril štrom, ker tu se stvari zakomplicirajo pri regulaciji.
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Pet Jun 07, 2013 6:24 pm    Naslov sporočila:   Odgovori s citatom
Imel sem priklopljen tudi akumulator. Tudi kasneje bo ves čas 150Ah akumulator priklopljen
3 x 3 = 9
zamot1
Prispevkov: 148
Aktiv.: 0.66
PrispevekObjavljeno: Pet Jun 07, 2013 7:55 pm    Naslov sporočila:  Ne kompliciraj. Odgovori s citatom
Imam isti problem pri vetrnem generatorju-kitajcu 400W da pri 40 km/h in sem ga direktno priklopil na akus, zaenkrat imam za omejitev toka kar varovalko, ko napetost generatorja preseže akumulatorsko začne teči tok v akumulator. Pri tem je treba samo paziti na prenapolnjenost in prevelik tok, to se da pa ešit z enostavno poceni elektroniko kupljeno pri Conradu. MPPT regulator ne dela najbolje, prepozno začne polniti, nivo za prenapolnjenost in varovanje za pregloboko izpraznitev niso najbolje nastavljeni. Ko bo čas se bom pozabaval tudi s tem. Vsaka dodana "črna škatla" samo slabša izkoristek in prazni akus.
Če boš poganjal generator z vodno turbino mu "pripaši" ravno prave obrate in ne rabiš nobenega regulatorja, ob polnem akusu izklopiš polnjenje, ob prevelikem toku ga pa omejiš z nekim poceni omejilcem toka.
Moje videnje tvojega problema
LP Tomaž
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Sob Jun 08, 2013 10:09 am    Naslov sporočila:   Odgovori s citatom
Vrtljajev ne morem spreminjat- generator je na isti osi, kot tekač turbine in idealni vrtlaji so 2000 /min.
Tudi prevelikega toka ne morem imeti- jaz bi rad naredil dc-dc pretvornik, ki bi mu reguliral izhodno napetost. Potem bi lahko idealno obremenil turbino in jo držal na idealnih vrtljajih in toku, ki ga pač zmore.
Za prenapolnjenost bom že poskrbel, da ne bo šlo previsoko.
Turbina dela samo, ko sem jaz prisoten. Ko me ni,polni aku panel.
3 x 3 = 9
zamot1
Prispevkov: 148
Aktiv.: 0.66
PrispevekObjavljeno: Sob Jun 08, 2013 10:42 am    Naslov sporočila:  Ne štekam! Odgovori s citatom
V prvem stavku govoriš da ne moreš spreminjati vrtljajev, kasneje pa o tem da boš dobil idealne vrtljaje? Sad
LP Tomaž
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Sob Jun 08, 2013 11:35 am    Naslov sporočila:   Odgovori s citatom
Pri peltonovi turbini so idealni vrtljaji poznani- ti so okrog 1/2 vrtljajev prostega teka in pri meni je to 2000 rpm
Če bi imel dc-dc pretvornik, bi potem lahko z izhodno napetostjo bremenil turbino in gledal na izhodne watte. Ko bi dobil največ, bi tisto nastavitev pustil. In v tistem trenutku bi se turbina vrtela z 2000 rpm.
Razmišljam, da bi probal s tem:
http://www.aliexpress.com/item/600W-DC-10-60V-to-12-80V-Step-Up-Converter-Adjustable-Voltage-Regulator-Car-Notebook-Power/715326557.html
Potem generator povežem v trikot, kot je bilo original in na izhodu dvignem napetost iz 12,4V (pri 2000rpm) na , recimo, 14,4V. V tem primeru bi začel teči nek tok in to je vse, kar rabim.
Edino, kar me skrbi, je izkoristek dc-dc pretvornika. Tam bi sigurno kar nekaj izgubil, ampak ne vidim boljše alternative.
Edino morda 3 fazni transformator direkt na generator in potem malo višja izhodna napetost na usmernik.
3 x 3 = 9
ro-bi
Prispevkov: 3580
Aktiv.: 15.97
PrispevekObjavljeno: Sob Jun 08, 2013 12:45 pm    Naslov sporočila:   Odgovori s citatom
Varijanta je še to:
http://www.aliexpress.com/item/20A-Tracer-2210RN-EP-MPPT-Solar-Controller-With-MT-5-Remote-Meter/549421452.html
Potem zvežem v zvezdo, regulator bi pa sam prilagajal izhodno napetost.
3 x 3 = 9
Uptime: 51 minut
