Pomoč pri programiranju
Jakey
Prispevkov: 651
Aktiv.: 4.13
Kraj: Ravne/LJ/Kobarid
PrispevekObjavljeno: Ned Apr 13, 2014 12:28 am    Naslov sporočila:  Pomoč pri programiranju Odgovori s citatom
Moram opraviti za faks neke meritve ter podati poročila. Zanima me, če mi lahko kdo pomaga pri tem.
Pic: dsPIC33F modul z DSC krmilnikom dsPIC33FJ12GP202
Prva naloga:
"Izmerite interval prekinitev in interval preklopa LED diod."
Zanima me, kam naj vstavim breakpointe(za merjenje z stopwatchom) ter kam za merjenje dolžine utripa diode?
Koda:
//* 28pin_UART_TX-RX_Using_USB
#include "p33FJ12GP202.h"
// the above include path may be different for each user.  If a compile
// time error appears then check the path for the file above and edit
// the include statement above.
//#define XTFREQ          7370000         //FRC frequency
#define FCY             39613000        //Instruction Cycle Frequency
#define BAUDRATE         9600
#define BRGVAL          ((FCY/BAUDRATE)/16)-1
int main(void)
// Configure Oscillator to operate the device at 40Mhz
// Fosc= Fin*M/(N1*N2), Fcy=Fosc/2
// Fosc= 7.37*43/(2*2)=79.23MHz
   PLLFBD=41;               // M=43
   CLKDIVbits.PLLPOST=0;      // N1=2
   CLKDIVbits.PLLPRE=0;      // N2=2
// Disable Watch Dog Timer
   RCONbits.SWDTEN=0;
// Wait for PLL to lock
   while(OSCCONbits.LOCK!=1) {};
   RPINR18 = 9;         // Make Pin RP9 U1RX
   RPOR4bits.RP8R = 3;      // Make Pin RP8 U1TX
   AD1PCFGL = 0x03C0;      // Make analog pins digital
   LATB = 0x0000;
   TRISB = 0x0FFF;         // Config LED's as output and U1RX as Input
   TMR1 = 0;            // clear timer 1
   PR1 = 0xFFFF;         // interrupt every 400ms
   IFS0bits.T1IF = 0;      // clr interrupt flag
   IEC0bits.T1IE = 1;      // set interrupt enable bit
   T1CON = 0x8030;         // 1:64 prescale, start TMR1
   U1BRG  = BRGVAL;
   U1MODE = 0x8000; /* Reset UART to 8-n-1, alt pins, and enable */
   U1STA  = 0x0440; /* Reset status register and enable TX & RX*/
_U1RXIF=0;
while(1)
      int a;
      while (_U1RXIF==0);         // Wait and Receive One Character
      a = U1RXREG;
      while(!U1STAbits.TRMT);
      U1TXREG = '"';
      while(!U1STAbits.TRMT);      // Echo Back Received Character with quotes
      U1TXREG = a;
      U1TXREG = '"';
      U1TXREG = ' ';
      _U1RXIF=0;               // Clear UART RX Interrupt Flag
return 0;
void __attribute__((__interrupt__, no_auto_psv)) _T1Interrupt(void)
   IFS0bits.T1IF = 0;   // clear interrupt flag
   LATB ^= 0xF000;      //Toggle LED's
int47
Prispevkov: 2104
Aktiv.: 8.88
PrispevekObjavljeno: Ned Apr 13, 2014 1:51 am    Naslov sporočila:  Re: Pomoč pri programiranju Odgovori s citatom
Jakey je napisal/a:
Shame on you Če ugodimo tvoji prošnji, boš verjetno rešil nalogo, vendar se pri tem ne boš naučil skoraj nič.
Pri naslednji podobni nalogi bo spet tema.
Naštudiraj kako program deluje, ali vsaj v kateri vrstici prižiga in ugaša LED.
Jakey
Prispevkov: 651
Aktiv.: 4.13
PrispevekObjavljeno: Sre Apr 16, 2014 12:43 am    Naslov sporočila:  Re: Pomoč pri programiranju Odgovori s citatom
int47 je napisal/a:
Jakey je napisal/a:
Res je, imam 4 naloge za "rešit". Zato pa se lotujem postopno(čeprav roko na srce MOČNO upam, da nikoli nebom rabil delati s pic-i, ker mi je resnično muka), in bi rad vsaj osnovno razumel; jezik kot C razumem, niso mi pa jasni ukazi.
Tonny
Pridružen-a: Sre 23 Dec 2009 11:57
Prispevkov: 289
Aktiv.: 1.53
Kraj: Vrhnika - MS
PrispevekObjavljeno: Pet Apr 18, 2014 7:55 am    Naslov sporočila:  Re: Pomoč pri programiranju Odgovori s citatom
Jakey je napisal/a:
Misliš, da je pri drugih mlinčkih (npr. AVR, MSP430, itd.) kaj drugače? Smile
Katerih ukazov ne razumeš? Glede na to, da "C" poznaš, ti težave verjetno delajo tiste čudne besede, napisane z veliko?
To so imena registrov uC-ja, tisto kar je za piko pa je poimensko določen bit v določenem registru. Na katerem naslovu se nahaja register je definirano v .h datoteki, katera je vključena na začetku programa. Ampak to zaenkrat sploh ni pomembno, ker so v datasheet-u vsi registri in biti predstavljeni z enakimi imeni kot v tvojem programu. Še več - za vsak register se tam najde podroben opis kaj njegovi bitki počnejo. Poleg tega pa imaš opis, kaj določen ukaz naredi, tudi v komentarjih v programu.
Malo bolj podrobno definiraj česa ne razumeš. Wink
Jakey
Prispevkov: 651
Aktiv.: 4.13
PrispevekObjavljeno: Pet Apr 18, 2014 12:12 pm    Naslov sporočila:  Re: Pomoč pri programiranju Odgovori s citatom
Tonny je napisal/a:
kolikor sem delal z Atmeli, ni ravno kaj dosti drugače..se mi pa zdi, da je dosti bolj pregledno :S
Tonny je napisal/a:
Bo držalo Smile
Tonny je napisal/a:
Za začetek, katera vrstica vklopi diode in katera izklopi.
Tonny
Prispevkov: 289
Aktiv.: 1.53
Kraj: Vrhnika - MS
PrispevekObjavljeno: Pet Apr 18, 2014 2:26 pm    Naslov sporočila:  Re: Pomoč pri programiranju Odgovori s citatom
Jakey je napisal/a:
To je bolj konec kot začetek, pa vseeno. Smile
- AD1PCFGL register določa, kateri pini kontrolerja so definirani kot digitalni
- TRIS register določa, kateri digitalni pini so definirani kot izhodi in kateri kot vhodi
- LAT register določa stanje izhodnih digitalnih pinov (visoko/nizko)
- "^" je bitni operator XOR (poglej si tabelco za XOR)
- ukaz "LATB ^= 0xF000;" je enak LATB = LATB ^ 0xF000
Mislim da je to vse kar se tiče ledic.
int47
Prispevkov: 2104
Aktiv.: 8.88
PrispevekObjavljeno: Sob Apr 19, 2014 1:59 pm    Naslov sporočila:   Odgovori s citatom
Ali je res tako težko prebrat komentarje v kodi ?
