Arduino spot welder
Doki$
Pridružen-a: Čet 16 Jul 2009 7:49
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Tor Jan 26, 2016 2:28 pm    Naslov sporočila:  Arduino spot welder Odgovori s citatom
Ce mi lahko kdo pomaga delam spot welser z arduinotom in mi nagaja program. pokace se napaka v programu. ta program sem našel na te internetni strani https://endless-sphere.com/forums/viewtopic.php?f=6&t=61046
#include "switch.h"
compilation terminal
exit status 1
error compiling
Koda:
Arduino resistance spot welder timer
Copyright (C) 2012  Albert van Dalen http://www.avdweb.nl
This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License
as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty
of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License at http://www.gnu.org/licenses .
Version 10-9-2013
Guillaume de Bailliencourt (Cybug) : Add support for menu with push buttons and display.
#if ARDUINO >= 100
  #include "Arduino.h"
#else
  #include "WProgram.h"
#endif
//#include <Streaming.h>
#include "switch.h"
// using LiquidCrystal library
#include <LiquidCrystal.h>
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
const byte spotWelderButtonPin = 52;
const byte spotWelder = 53;
bool continuousWelding = 0; // enable continuous welding
bool startWelding = 0;
unsigned long startWeldTime = 0;
int iterWeld = 0;
int preWeld_ms = 50;
int step_ms = 150;
int weldPause = 500;
int tSelect = 3;
Switch spotWelderButton(spotWelderButtonPin);
void setup()
{ Serial.begin(9600);
  pinMode(spotWelder, OUTPUT);
  lcd.begin(16, 2);              // start the library
  updateDisplay(0);
void loop()
  spotWelderButton.poll();
  if(continuousWelding) weld(spotWelderButton.on());
  else
  if(spotWelderButton.pushed()) weldCyclus(step_ms);
 //lcd.setCursor(0,1);            // move to the begining of the second line
 lcd_key = read_LCD_buttons();  // read the buttons
 switch (lcd_key)               // depending on which button was pushed, we perform an action
   case btnRIGHT:
     if (!continuousWelding) {
       tSelect += 1;
       if (tSelect >=4) tSelect = 1;
       updateDisplay(300);
     //lcd.print("RIGHT ");
     break;
   case btnLEFT:
       tSelect -= 1;
       if (tSelect <=0) tSelect = 3;
       updateDisplay(300);
       //lcd.print("LEFT   ");
     break;
   case btnUP:
         if (tSelect == 1)
          preWeld_ms += 1;
        else if (tSelect == 2)
          weldPause += 50;
        else
          step_ms += 10;
     updateDisplay(300);
     //lcd.print("UP    ");
     break;
   case btnDOWN:
         if (tSelect == 1)
          preWeld_ms -= 1;
          weldPause -= 50;
        else
          step_ms -= 10;
       updateDisplay(300);
     //lcd.print("DOWN  ");
     break;
   case btnSELECT:
       continuousWelding = !continuousWelding;
       updateDisplay(300);
     //lcd.print("SELECT");
     break;
     case btnNONE:
     //lcd.print("NONE  ");
     break;
void updateDisplay(int ms_delay)
  lcd.setCursor(0,0);
  if (continuousWelding)
    lcd.print(" Welding while  ");
    lcd.setCursor(0,1);
    lcd.print(" pressing pedal ");
    delay(ms_delay);
    return;
  if (tSelect == 1)
    lcd.print("<Pre>Pause Weld ");
    lcd.print(" Pre<Pause>Weld ");
  else
    lcd.print(" Pre Pause<Weld>");
  lcd.setCursor(1,1);
  lcd.print("     ");
  lcd.setCursor(1,1);
  lcd.print(preWeld_ms);
  lcd.setCursor(5,1);
  lcd.print("      ");
  lcd.setCursor(5,1);
  lcd.print(weldPause);
  lcd.setCursor(11,1);
  lcd.print("     ");
  lcd.print(step_ms);
  delay(ms_delay);
void weldCyclus(int weldTime_ms)
  lcd.setCursor(0,0);
  lcd.print(" << WELDING >>  ");
  //lcd.print(">");
  pulseSpotWelder(preWeld_ms);
  lcd.setCursor(0,1);
  lcd.print(" ");
  lcd.setCursor(4,1);
  lcd.print(">");
  delay(weldPause);
  lcd.setCursor(4,1);
  lcd.print(" ");
  lcd.setCursor(10,1);
  lcd.print(">");
  pulseSpotWelder(weldTime_ms);
  //lcd.setCursor(10,1);
  //lcd.print(" ");
  updateDisplay(0);
 void weld(bool b)
{ digitalWrite(spotWelder, b);
  if (b)
      lcd.setCursor(0,0);
      if (startWelding != b)
        startWeldTime = millis();
        startWelding = b;
        lcd.setCursor(0,1);
        lcd.print("                ");
      if ((iterWeld++ % 50) == 0)
       lcd.setCursor(0,1);
       lcd.print("    ");
       lcd.print(millis() - startWeldTime);
       lcd.print("ms");
  else
    startWelding = 0;
    iterWeld = 0;
    updateDisplay(0);
void pulseSpotWelder(int ms)
{ digitalWrite(spotWelder, 1);
  delay(ms);
  digitalWrite(spotWelder, 0);
  //Serial << ms << endl;
// read the buttons
int read_LCD_buttons()
 adc_key_in = analogRead(0);      // read the value from the sensor
 // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
 // we add approx 50 to those values and check to see if we are close
 if (adc_key_in > 1000) return btnNONE; // We make this the 1st option for speed reasons since it will be the most likely result
 // For V1.0 use the one below:
 if (adc_key_in < 50)   return btnRIGHT;
 if (adc_key_in < 195)  return btnUP;
 if (adc_key_in < 380)  return btnDOWN;
 if (adc_key_in < 555)  return btnLEFT;
 if (adc_key_in < 790)  return btnSELECT;
 return btnNONE;  // when all others fail, return this...
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Tor Jan 26, 2016 9:06 pm    Naslov sporočila:   Odgovori s citatom
Tako na hitro se mi zdi da manjka knjižnjica switch.
Nazadnje urejal/a Jaka57 Tor Jan 26, 2016 9:30 pm; skupaj popravljeno 1 krat
solomojster
Prispevkov: 856
Aktiv.: 4.42
Kraj: NOVA GORICA
PrispevekObjavljeno: Tor Jan 26, 2016 9:24 pm    Naslov sporočila:   Odgovori s citatom
VERJETNO TOLE ?
http://avdweb.nl/arduino/troubleshooting.html?mavikthumbnails_display_ratio=%25ratio%25#h2-missing-libraries
Nazadnje urejal/a solomojster Tor Jan 26, 2016 9:42 pm; skupaj popravljeno 1 krat
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Tor Jan 26, 2016 9:39 pm    Naslov sporočila:   Odgovori s citatom
Bo kar tole.
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Tor Jan 26, 2016 10:14 pm    Naslov sporočila:   Odgovori s citatom
Hvala za pomoč!
sedaj pa imam se en problem javi mi to napako ko je na sliki. Če mi lahko kdo pomaga.
denis
 Velikost datoteke:  86.52 KB
 Pogledana:  69 krat
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Sre Jan 27, 2016 9:54 am    Naslov sporočila:   Odgovori s citatom
Pravilno nisi skopiral switch.cpp in switch.h.
V priponki imaš kompletno mapo, razpakiraj jo v \Moji dokumenti\Arduino\libraries, lahko pa jo razpakiraš kamorkoli in uvoziš preko Arduino IDE Skica->Uvozi knjižnjico in pokaži mapo Switch.
Meni prevede tvojo skico brez problemov (v.1.5.2 r2 in v.1.6.1).
 Velikost datoteke:  116.33 KB
 Pogledana:  16 krat
Switch.rar
 Ime datoteke:  Switch.rar
 Velikost datoteke:  2.43 KB
 Downloadano:  5 krat
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Čet Jan 28, 2016 3:02 pm    Naslov sporočila:   Odgovori s citatom
Najlepsa hvala za pomoč sedaj mi dela.
Tukaj imam se en link če koga znima.
Ko bom dobil se vse stvari bom slikal kako bo izgledalo.
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Tor Jun 28, 2016 10:43 pm    Naslov sporočila:   Odgovori s citatom
http://www.instructables.com/id/DIY-Arduino-Battery-Spot-Welder/
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Tor Jun 28, 2016 10:45 pm    Naslov sporočila:   Odgovori s citatom
Če koga zanima sem naredil in dela fatastično.
solomojster
Prispevkov: 856
Aktiv.: 4.42
Kraj: NOVA GORICA
PrispevekObjavljeno: Sre Jun 29, 2016 6:32 am    Naslov sporočila:   Odgovori s citatom
Doki$ je napisal/a:
Nas zelo zanima. Lahko posnameš kratek video ?
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Sre Jun 29, 2016 10:56 am    Naslov sporočila:   Odgovori s citatom
Doki$ je napisal/a:
Seveda nas zanima! Lahko se pohvališ s kakšno sliko ali albumom slik, če že ne s kratkim video posnetkom.
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Sre Jun 29, 2016 1:21 pm    Naslov sporočila:   Odgovori s citatom
Bom čim prej dal kakšno sliko, kasneje pa kakšen posnetek.
Prispevkov: 5846
Aktiv.: 23.66
PrispevekObjavljeno: Sre Jun 29, 2016 2:19 pm    Naslov sporočila:   Odgovori s citatom
Doki$ je napisal/a:
Odlično!
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Čet Jun 30, 2016 7:24 am    Naslov sporočila:   Odgovori s citatom
slike
 Velikost datoteke:  2.59 MB
 Pogledana:  39 krat
Doki$
Prispevkov: 12
Aktiv.: 0.06
Kraj: LJUBLJANA
PrispevekObjavljeno: Čet Jun 30, 2016 7:27 am    Naslov sporočila:   Odgovori s citatom
Še ena
 Velikost datoteke:  3.23 MB
 Pogledana:  27 krat
Uptime: 233 dni
