mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3535 Aktiv.: 28.95
Objavljeno: Tor Apr 03, 2018 11:31 pm Naslov sporočila: Špulca za ITER |
Tale pa ni SMD špula:
https://www.iter.org/newsline/-/2964
| Citiram: |
Six massive magnets will embrace the ITER machine from top to bottom to control the shape and stability of its plasma. Europe is responsible for five out of the six Poloidal Field (PF) coils, one of them being manufactured in China. In line with the spirit of the ITER project, the biggest international collaboration in the field of energy, F4E and ASIPP, The Institute of Plasma Physics of the Chinese Academy of Sciences in Hefei, have signed an agreement to manufacture this coil together in order to mutually benefit from their expertise and deliver the component faster.
The first poloidal field coil to be installed during the ITER machine assembly phase may be one of the smallest in terms of lateral dimensions, but it tops out its five sister coils in weight due to the number of stacked layers (or double pancakes) that go into its construction. |
Vir: http://fusionforenergy.europa.eu/mediacorner/newsview.aspx?content=1217
in https://www.iter.org/newsline/-/2964 _________________ Always going the extra mile. |
Spajky Član
Pridružen-a: Ned 27 Jun 2010 0:05 Prispevkov: 1095 Aktiv.: 5.69 Kraj: Obala
Objavljeno: Sre Apr 04, 2018 2:11 am Naslov sporočila: |
... po toliko in toliko letih in milijardah dolarjev, bi že zdavnaj namesto tega, ki ni vrglo ven niti enega watt-a plusa energije, preizkusili in komercialno razvili do konca Torij-sko nuklearko ... tako pa je to črna luknja za financiranje "zaslužnih" znanstvenikov in priviligiranih proizvajalcev delov za te experimente....
Mogoče pa je v resnici to samo res velik "StarGate" z odprtino, skozi katero gre lahko najmanj komplet Abrams tank ali kamion, pa mislijo napast neki alien planet za surovine, ker jih bo tu zmanjkalo
.. mogoče je pa to samo baza za elektromagnet za HoverBoard https://www.youtube.com/watch?v=A4vE_vpkr90 na katerem naj bi stala cela bodoča am.letalonosilka - in to lebdeča  |
mosqito Član
Objavljeno: Sre Apr 04, 2018 7:04 am Naslov sporočila: |
Hec je, da so ZDA odstopile od projekta. Njihov letni proračun za vojsko je 5x večji od celotnega ITER prijekta, tako da ne govori neumnosti. Ravno zaradi take negativne propagande in kratkega spomina javnosti taki projekti niso dlje kot bi lahko bili. _________________ Always going the extra mile. |
Uptime: 233 dni
