Bluetooth ZS-040
Aktiv.: 61.92
PrispevekObjavljeno: Ned Maj 20, 2018 11:37 am    Naslov sporočila:  Bluetooth ZS-040 Odgovori s citatom
Imam zgoraj omenjen bluetooth -> RS232 modulček. (Cipset CC2541) Koliko sem uspel najti gre dejansko za klona HM10.
Zadeva s strani RS232 deluje - se odziva na AT ukaze. Z strani BT pa je "mrtva" . Ni vidna na nobeni napravi. (preizkušeno na več različnih telefonih) Poskusil sem dva komada. Nobeden ne deluje. Rdec led utripa v ritmu ca 1.sec.
Mogoče kdo ve kje je problem? So modulčki zanič? Imam enega starejšega(mislim, daje HC06), ki pa dela brez problema.
Nabor ukazov, ki jih vrača AT+HELP
Koda:
* Command             Description                    *
* AT                  Check if the command terminal work normally  *
* AT+RESET            Software reboot               *
* AT+VERSION          Get firmware, bluetooth, HCI and LMP version *
* AT+HELP             List all the commands                 *
* AT+NAME             Get/Set local device name                    *
* AT+PIN              Get/Set pin code for pairing                 *
* AT+PASS             Get/Set pin code for pairing                 *
* AT+BAUD             Get/Set baud rate                         *
* AT+LADDR            Get local bluetooth address         *
* AT+ADDR             Get local bluetooth address         *
* AT+DEFAULT          Restore factory default            *
* AT+RENEW            Restore factory default            *
* AT+STATE            Get current state               *
* AT+PWRM             Get/Set power on mode(low power)          *
* AT+POWE             Get/Set RF transmit power          *
* AT+SLEEP            Sleep mode                          *
* AT+ROLE             Get/Set current role.                      *
* AT+PARI             Get/Set UART parity bit.                     *
* AT+STOP             Get/Set UART stop bit.                       *
* AT+START            System start working.            *
* AT+IMME             System wait for command when power on.      *
* AT+IBEA             Switch iBeacon mode.                      *
* AT+IBE0             Set iBeacon UUID 0.                          *
* AT+IBE1             Set iBeacon UUID 1.                          *
* AT+IBE2             Set iBeacon UUID 2.                          *
* AT+IBE3             Set iBeacon UUID 3.                          *
* AT+MARJ             Set iBeacon MARJ .                          *
* AT+MINO             Set iBeacon MINO .                          *
* AT+MEA              Set iBeacon MEA .                          *
* AT+NOTI             Notify connection event .                    *
* AT+UUID             Get/Set system SERVER_UUID .                  *
* AT+CHAR             Get/Set system CHAR_UUID .                  *
* Note: (M) = The command support slave mode only.          *
* For more information, please visit http://www.bolutek.com        *
* Copyright@2013 www.bolutek.com. All rights reserved.         *
+VERSION=Firmware V3.0.6,Bluetooth V4.0 LE
+NAME=CC41-A
PS
EN pin naj ne bi bilo potrebno priklopit nikamor. Sem ga sicer poskusil na visoko in nizko stanje a ni sprermemb.
Vlado
Pridružen-a: Sre 03 Mar 2004 21:35
Prispevkov: 563
Aktiv.: 2.38
PrispevekObjavljeno: Ned Maj 20, 2018 6:18 pm    Naslov sporočila:   Odgovori s citatom
Silvo,
poskusi postopek na tej strani:
http://fab.cba.mit.edu/classes/863.15/doc/tutorials/programming/ble_duplex.html
