| Avtor |
Objavljeno: Tor Sep 18, 2018 9:19 pm Naslov sporočila: Nostalgija PLD |
Na eni zavrženi industrijski kartici sem našal večjo količino GAL-ov (GAL22V10) Glede na to, da so bili na podnožju sem jih spulil dol. Danes sem jih malo potestiral. Najprej sem poskusil, če ga z mojim programatorjem sploh lahko programiram. (G540 se z njim dobro razume) Prav tako ga podpira WinCupl (atmelov software za programiranje PLD-jev)
Naredil sem dve stvari. V prvem galu je astabil in binarni števec. V drugem pa bcd dekoder na 7seg. displej.
| Koda: |
Name Astabil ;
PartNo 00 ;
Date 18.09.2018 ;
Revision 01 ;
Designer Silvo ;
Company - ;
Assembly None ;
Location ;
Device G22V10 ;
PIN 1 = clk;
PIN [2,3,4,5] = [A0..3];
PIN 6 = tst ;
PIN 7 = !Vklop ;
PIN 8 = !Reset;
PIN 9 = Naprej;
PIN [10..11] = [Itmp0..1];
PIN [14..17] = [D0..3];
PIN [18..20] = [Qtmp0..2];
FIELD vhodi = [A0..3];
FIELD segmenti = [A,B,C,D,E,F,G];
FIELD HexStev = [D0..3];
Qtmp0 = !Itmp0;
Qtmp1 = !Qtmp0;
Sequenced HexStev { /* free running counter */
present 'h'0 if Naprej next 'h'1;
if Reset next 'h'0;
present 'h'1 if Naprej next 'h'2;
if Reset next 'h'0;
present 'h'2 if Naprej next 'h'3;
if Reset next 'h'0;
present 'h'3 if Naprej next 'h'4;
if Reset next 'h'0;
present 'h'4 if Naprej next 'h'5;
if Reset next 'h'0;
present 'h'5 if Naprej next 'h'6;
if Reset next 'h'0;
present 'h'6 if Naprej next 'h'7;
if Reset next 'h'0;
present 'h'7 if Naprej next 'h'8;
if Reset next 'h'0;
present 'h'8 if Naprej next 'h'9;
if Reset next 'h'0;
present 'h'9 if Naprej next 'h'A;
if Reset next 'h'0;
present 'h'A if Naprej next 'h'B;
if Reset next 'h'0;
present 'h'B if Naprej next 'h'C;
if Reset next 'h'0;
present 'h'C if Naprej next 'h'D;
if Reset next 'h'0;
present 'h'D if Naprej next 'h'E;
if Reset next 'h'0;
present 'h'E if Naprej next 'h'F;
if Reset next 'h'0;
present 'h'F if Naprej next 'h'0;
if Reset next 'h'0;
HexStev.ar='h'0;
HexStev.sp='h'0;
| Koda: |
Name LedDisply ;
PartNo 00 ;
Date 18.09.2018 ;
Revision 01 ;
Designer Silvo ;
Company - ;
Assembly None ;
Location ;
Device G22V10 ;
PIN 1 = clk;
PIN 6 = tst ;
PIN 7 = !Vklop ;
PIN 8 = !Reset;
PIN 9 = Naprej;
PIN [14..20] = [A,B,C,D,E,F,G];
PIN [21..23] = [D0..2];
FIELD HexStev = [D0..2];
/*ABCDEFG*/
TABLE vhodi => segmenti.d {
'b'0000 => 'b'1111110;
'b'0001 => 'b'0110000;
'b'0010 => 'b'1101101;
'b'0011 => 'b'1111001;
'b'0100 => 'b'0110011;
'b'0101 => 'b'1011011;
'b'0110 => 'b'1011111;
'b'0111 => 'b'1110000;
'b'1000 => 'b'1111111;
'b'1001 => 'b'1111011;
'b'1010 => 'b'1110111;
'b'1011 => 'b'0011111;
'b'1100 => 'b'0001101;
'b'1101 => 'b'0111101;
'b'1110 => 'b'1001111;
'b'1111 => 'b'1000111;
segmenti.ar='h'0;
segmenti.sp='h'0;
segmetni.ot= Vklop;
if Reset next 'h'0;
if Reset next 'h'0;
if Reset next 'h'0;
if Reset next 'h'0;
if Reset next 'h'0;
if Reset next 'h'0;
if Reset next 'h'0;
present 'h'7 if Naprej next 'h'0;
if Reset next 'h'0;
HexStev.ar='h'0;
HexStev.sp='h'0;
Bolj slab posnetek _________________ lp
| Nazaj na vrh |
