P: VFD IV21 / ИВ-21
sebastiant
Prispevkov: 1814
Aktiv.: 7.88
Kraj: ljubljana
PrispevekObjavljeno: Tor Maj 26, 2020 6:21 pm    Naslov sporočila:  P: VFD IV21 / ИВ-21 Odgovori s citatom
Prodam nove VFD / Vacuum Fluorescent Display / z oznako IV21. Zelo uporabne za izdelavo ure, rabijo nižjo napetost od Nixie. Cena za 1 kos je 4,90€.
http://www.tube-tester.com/sites/nixie/dat_arch/IV-21_IV-27.pdf
#A VFD operates on the principle of cathodoluminescence, roughly similar to a cathode ray tube, but operating at much lower voltages. Each tube in a VFD has an anode coated phosphor that is bombarded by electrons emitted from the cathode filament. In fact, each tube in VFD is a triode vacuum tube because it also has a mesh control grid.
The first VFD was the single indication DM160 by Philips in 1959. The first multi-segment VFD was the 1962 Japanese single-digit, seven-segment device. The displays became common on calculators and other consumer electronics devices. In the late 1980s hundreds of millions of units were made yearly.#
 Velikost datoteke:  57.63 KB
LP Sebastian
sebastiant
Prispevkov: 1814
Aktiv.: 7.88
Kraj: ljubljana
PrispevekObjavljeno: Tor Maj 26, 2020 7:10 pm    Naslov sporočila:   Odgovori s citatom
PRODANO !!!!
LP Sebastian
