Program mi občasno ne dela - PIC se izgubi
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Osnove programiranja PIC-a v Assembler-ju
pr2501
Pridružen-a: Sre 18 Okt 2006 10:40
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Ned Nov 12, 2006 6:33 pm    Naslov sporočila:  Program mi občasno ne dela - PIC se izgubi Odgovori s citatom
SPISAL SEM PROGRAM, KI MI VČASIH DELA IN VČASIH PA NE
Zanima me če se da iz spodnje kode razumeti kaj mi povzroča da se pic izgubi.?
Kodo sem predelal tako da so noter le zanke (call in goto)
Koda:
                 ORG   0x0000
                  goto Main      ;go to start of main code
                 ORG   0x0008
;_______________________________________________________________INTERRUPT______________________
int
retfie
Main
INI
tibet
                 call ADC
                 call arrived_sign_from_PC
                 call subReal_wish
            call sub_H_E ;
            btfsc DO_reg,0
                 call regulation
                 btfsS DO_reg,0
       CALL _RESET
                 call sub_real_critic
                 BTFSC alarm,0
                 CALL  alarm_ON
     NOP
goto tibet
ADC
RETURN
;___________________________________________________________________
              btfsc       main_flag,0  ; Check for a new character
               call       sign         ; Did not find one go check again (or do other stuff)
return
;___________________________________________________________________________________
sign
bcf        main_flag,0     ; Clear flag bit so that we don't look at it again
CALL set_flag
call test_a_flag
return
set_flag;____________________________________________________________________set_flag
call set_in_w
call set_in_H
call set_in_c
call read_w_TEM
call read_Hysteresis
call read_c_TEM
call read_R_TEM
RETURN
set_in_w
return
set_in_H
return
set_in_c
return
read_w_TEM
return
read_Hysteresis
return
read_c_TEM
return
read_R_TEM
return
test_a_flag; _____________________________________________________test_a_flag
call   write_w
call   write_h
call   write_c
call  read_w
call   read_h
call   read_c
call  read_R
returN
write_w
call start_DIGIT_in
btfsS end_packet,0
goto wait
call BCDtoBin
wait
return
write_c
call start_DIGIT_in
btfss end_packet,0
goto wait1
call BCDtoBin
wait1
return
write_h
call start_DIGIT_in
btfss end_packet,0
goto wait2
call BCDtoBin
wait2
return
read_w
call    BinTObcd
call    send
return
read_h
call    BinTObcd
call    send
return
read_c
call    BinTObcd
call    send
return
read_R
call    BinTObcd
call    send
return
;;_______________________________________________________________________WRITE INTO MCU
start_DIGIT_in;
return
BCDtoBin
RETURN
;;_______________________________________________________________________READ FROM MCU
BinTObcd
RETURN
send
return
;________________________________________________________________________________________
;_________________________________________________________________________________________
;__________________________________________________________________________________________
;REGULATION
sub_real_critic
 RETURN
subReal_wish
 CALL    negativ
 RETURN
negativ
 RETURN
sub_H_E
 RETURN
regulation
call heate
call ventilate
return
heate
return
ventilate
return
_RESET
RETURN
alarm_ON
return
END
NeoTO
Prispevkov: 2756
Aktiv.: 11.15
Kraj: Trzic
PrispevekObjavljeno: Ned Nov 12, 2006 6:58 pm    Naslov sporočila:   Odgovori s citatom
Če pričakuješ, da se bo nekdo za uro ali več poglobil v tvojo kodo, vsaj malo več napiši, kje se izgubi, to simuliraš ali [slovenščina je zame španska vas] v vezju, kaj sploh dela, ...
Lp,
Matevž
pr2501
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Ned Nov 12, 2006 7:34 pm    Naslov sporočila:   Odgovori s citatom
Sedaj sem poslal kodo v celoti.
Poslal sem le zanke, ker mislim da je napaka nekje v povezovanju med glavno zanko in subrutinami.
reguliram temperaturo. Imam senzor grelec in ventilator.
Sestavil sem kodo, ki komunicira s Hiper terminalom.
Ko pošljem male črke: w(željena tem.),h(histereza,oz. dovoljeno odstopanje),c(kritična tem.), pomeni o da treba naslednje tri znake (številke)iz tipkovnice razvrstiti v dva registra za BCD v BIN pretvorbo. Pretvorjene vrednosti se potem uporabljajo v regulaciji.
Če pa napišem na tikovnici veliko črko W,H,C,R pomeni to branje iz MCU v Hiper terminal. Vrednosti najprej pretvorim v BCD in jih pošljem.
Kodo semsestavil iz posameznih blokov ki mi samostojno delujejo in sama koda
mi včasih deluje večinoma pa ne. Recimo učeraj zvečer sem jo pripravil do tega da je delovala, ko sem večkrat povlekel čip iz ležišča in ga potem vrniol nazaj pod napetostjo. Saj vem da to ni najbolj pametno početje ampak. Nevem več kaj storiti.
Priznati moram da imam še veliko lukenj v znannju programiranja.Zato prosim za pomoč.
Copy of Brazil.zip
 Ime datoteke:  Copy of Brazil.zip
 Velikost datoteke:  6.18 KB
 Downloadano:  7 krat
pr2501
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Ned Nov 12, 2006 7:39 pm    Naslov sporočila:   Odgovori s citatom
vidim da sem v prvem sporočilu poslal kodo dvakrat.
V drugem pa se nisem pravilno izjasnil kaj je v priponki.
Torej v priponki je celotna koda.
V prvem sporočilu pa samo zanke. (nažalost pa dvakrat)
Hvala
Ni se ti treba opravičevati, da si kodo poslal 2x, ampak imaš zgoraj desno gumb Uredi in enostavno popraviš. Sedaj sem jaz namesto tebe. aly.
NeoTO
Prispevkov: 2756
Aktiv.: 11.15
Kraj: Trzic
PrispevekObjavljeno: Ned Nov 12, 2006 7:46 pm    Naslov sporočila:   Odgovori s citatom
Si slučajno poskusil z drugim PICem?
Lp,
Matevž
pr2501
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Ned Nov 12, 2006 8:06 pm    Naslov sporočila:   Odgovori s citatom
Sem.
Večkrat sem izmenjal 2 pica med seboj.
Sploh pa imam eno vprašanje , kaj program lahko skače s klicanjem subrotin po mili volji ali so kakšna pravila.
Primer:
main
call 1
call 2
goto main
1
call 1a
call 1b
return
1a
call 1aa
call 1ab
return
1b
call 1ba
cal 1bb
return
1aa
call 1aaa
call 1aab
return
in v tem smislu naprej?
Djurodrljaca
Pridružen-a: Pet 19 Dec 2003 16:31
Prispevkov: 393
Aktiv.: 1.59
PrispevekObjavljeno: Ned Nov 12, 2006 8:11 pm    Naslov sporočila:   Odgovori s citatom
Lahko, ampak mislim da ima ta PIC 32 nivojev oz ugnezdenih klicev.
Sokrat
Prispevkov: 5584
Aktiv.: 22.60
PrispevekObjavljeno: Ned Nov 12, 2006 8:12 pm    Naslov sporočila:   Odgovori s citatom
Ne more - omejitev je v globini in izvedbi stacka in ta je pri PICih mocno (in vnaprej) omejen. Obstaja prakticna meja, ki je odvisna od konkretnega PICa, ki ga uporabljas.
Djurodrljaca
Prispevkov: 393
Aktiv.: 1.59
PrispevekObjavljeno: Ned Nov 12, 2006 8:19 pm    Naslov sporočila:   Odgovori s citatom
Če se prav spomnim ima PIC za klice in prekinitve uporabljen HW stack, ki ima 31 nivojev (prej sem se zmotil za 1 nivo).
pr2501
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Ned Nov 12, 2006 9:04 pm    Naslov sporočila:   Odgovori s citatom
Mislim da nisem sel čez to mejo.
Kje se lahko sploh to vidi (pač na katerem nivoju si),?
pri uporabi MpLab simulatorja ?
GJ
Prispevkov: 946
Aktiv.: 3.99
PrispevekObjavljeno: Ned Nov 12, 2006 9:52 pm    Naslov sporočila:  Re: Program mi občasno ne dela - PIC se izgubi Odgovori s citatom
pr2501 je napisal/a:
Ojla..
Sem le nahitro preletel tole solato.. Laughing
Še en, ki uporablja absolute MPLAB asm model namesto relocated MPLAB asm model.
Vidim, da si izklapljal opozorila prevajalnika Shocked , super še žal ti bo!
Razlog boš odkril, ko boš delal z večimi bankami, dokler pa imaš BSF register zmerom 0 bo pa delovalo.
Program je popolna zmeda..
Nekaj si zložil skupaj in sedaj pa bi rad, da ti nekdo pove kaj to je.. Wink
Če pogledva prekinitev je povsem očitno, da ni ravno smiselna.
Pospravljanje/restavriranje registrov ni potrebno ker to naredi hardware, le na koncu mora biti ukaz 'retfie 1'
Prekinitev se ti zgodi, ko UART sprejme karakter. Nakar ta byte preložiš v arrived_sign in prižgeš zastavico main_flag češ, da program ve, da ga čaka nov karkter.
V tem primeru sploh ne rabiš prekinitvene. Enostavno preverjaš v programu 'PIR1,RCIF' flag namesto tvojega 'main_flag'. Rolling Eyes
Seveda pa to v realnosti ponavadi ne gre..
Ne podpisuješ vrstic.. Le kdo bo potem to gledal za teboj?
Dej najprej napiši v kakšnem programskem jeziku (Pascal al pa C) glavni program.
Še bol pa je, če narediš kar simulacijo.
Najprej naredi delujočo komunikacijo.
Komunikacija mora biti 'task' zase (kot si zastvil toda ne dokončal)! Šele ko sprejmeš celoten ukaz/string na to upozoriš glavni program.
Glavni program mora delati povsem neodvisno od komunikacije!
Ne vem zakaj siliš glavni program na koncu v ponovno inicializacijo procesorja??? Če je ta trenutek kaj v UART bufferju bo verjetno izgubleno!
LP GJ
pr2501
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Pon Nov 13, 2006 1:07 am    Naslov sporočila:   Odgovori s citatom
Ojla..
Solato nisem poslal zaradi vitaminov.
torej to ni razlog za nedelovanje kode. Ali mogoče je ?
Točno vem kaj sem zložil skupaj.
Tudi to torej ni razlog za nedelovanje kode.
Koda ni še končana in nisem jo še imel dajati v javnost.
Samo sedaj nimam več moči, da bi rešaval problem. In mi je počasi že vseeno pa čeprav se gre za mojo diplomo.
Programskih jezikov ne poznam. simulacijo pa sem tudi delal, najprej za komunikacijo in potem za vsak del zase.
Bom pa probal iti jutri skozi simulacijo celotne zadeve.
Komunikacijo sem spisal prvo in deluje. In enako kot delujejo vsi ostali deli kode dobro vsak zase.
Program (regulacija) teče medtem ko jaz tipkam, oz. ne čaka da odtipkam vse tri števila. In šele ko so odtipkana vsa tri števila se začne z BCD v Bin pretvorbo. In nato z pisanjem spremenljivk.
[/quote]
Glavni program mora delati povsem neodvisno od komunikacije![/quote]
saj deluje. Iz glavne zanke grem v komunikacijo le ko dobim ukaz za branje ali pisanje.
tega pa nisem razumel. Iz čega se razume da silim glavni program v ponovno inicjalizacijo
Po tvojem pisanju lahko sklepam, da sem porabil mesec dni brezveze, in si unčil hrbet in oči.
Lej mene prav malo zanima kako se lepo programira mene zanima zakaj moja koda včasih dela včasih pa ne.
pr2501
Prispevkov: 28
Aktiv.: 0.12
PrispevekObjavljeno: Pon Nov 13, 2006 8:21 am    Naslov sporočila:   Odgovori s citatom
Včeraj nisem izklapljal MCU-ja in danes še vedno dela. Ni da nepravilno deluje med obratovanjem. Če mi steče pri uklopu pol deluje.
Včeraj mi ni delal cel dan in je poptem zvečer začel Ko sem ga večkrat poiskusil vzeti iz ležišča ven in ka popnovno vtakniti.
jur
Prispevkov: 5142
Aktiv.: 20.81
PrispevekObjavljeno: Pon Nov 13, 2006 9:51 am    Naslov sporočila:   Odgovori s citatom
Določeni programi začno pravilno delovati šele po določenem času. Če uporabljaš na primer max232 in pcju(oziroma neki napravi) takoj ob vklopu pošlješ znak in čakaš na odgovor, boš čakal v neskončnost. Če ned čakanjem (neskončnosti) pritisneš reset, bo program magično začel delovati. Razlog je v tem, da ob zagonu max232 potrebuje precej časa, da začne delovati (polnjenje kondenzatorjev). Znak, ki ga prekmalu pošlje kontroler maxu bo do maxa prišel, ven iz njega pa ne.
Preveri, če nimaš tekega v programu. Glede na to, da program dela, ko začne delovati, imaš morda neko inicializacijo (software ali hardware) narejeno narobe.
Ja, so pravila. Omejitev je globina klicev procedur (nesting), to je kolikokrat lahko procedura v proceduri kliče proceduro. Določena je z tipom procesorja (dolžina stacka. Posledica je stack overflow, kar je zelo pogosta in fatalna napaka.
Procedura mora imetu svoj return stavek. Če ni returna, ali pa se gre ven iz procedure z goto stavkom, je nedelovanje zagotovljeno.
Nazadnje urejal/a jur Pon Nov 13, 2006 10:03 am; skupaj popravljeno 4 krat
Aktiv.: 38.07
PrispevekObjavljeno: Pon Nov 13, 2006 10:01 am    Naslov sporočila:   Odgovori s citatom
V programu imaš en kup klicev procedur. Vsak klic + interrupt ti zasede stack, ki je pri PICih fiksne dolžine. Po spominu (že 3 leta nisem delal s pici) je stack pri tamalih uC globok 8 lokacij. Za točen podatek poglej datasheet. Preverjaj v simulatorju stack pointer.
Objavi novo temo   Odgovori na to temo   Printer-friendly version    www.elektronik.si Seznam forumov -> Osnove programiranja PIC-a v Assembler-ju Časovni pas GMT + 2 uri, srednjeevropski - poletni čas
