dkone Član
Pridružen-a: Sre 07 Mar 2007 18:53 Prispevkov: 2120 Aktiv.: 9.11 Kraj: Krško
Objavljeno: Čet Jan 01, 2009 10:43 pm Naslov sporočila: |
Narediš si nov projekt in ga shraniš v poljubno mapo. V mapi narediš še .asm datoteko in jo shraniš. Ko imaš to vse lepo narejeno,klikneš na project/Build all ali ctrl+F10 da se ti zadeve prevede. Nastavljeno je vse po defaultu. _________________ Denis |
pomar Član
Pridružen-a: Čet 04 Dec 2008 21:15 Prispevkov: 255 Aktiv.: 1.21 Kraj: okolica Ptuja
Objavljeno: Čet Jan 08, 2009 11:14 pm Naslov sporočila: |
Z projekt wizard sem ustvaril nov projekt. V isto mapo sem shranil tudi .asm datoko. Ko odprto .asm datoteko mislim pretvorit v .hex z funkcijo project/Build mi izpiše napako. Kaj delam napačno?
Debug build of project `C:\Documents and Settings\aa\Desktop\mpkocka\mpkocka.mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Thu Jan 08 21:52:52 2009
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\aa\Desktop\mpkocka\mpkocka.mcs".
Clean: Done.
Executing: "E:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F690 "LED.asm" /l"LED.lst" /e"LED.err" /d__DEBUG=1
Warning[205] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 47 : Found directive in column 1. (cblock)
Warning[205] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 61 : Found directive in column 1. (ENDC)
Message[305] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2069 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2093 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2095 : Using default destination of 1 (file).
Message[305] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2097 : Using default destination of 1 (file).
Message[302] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2110 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2111 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2116 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2117 : Register in operand not in bank 0. Ensure that bank bits are correct.
Warning[205] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2226 : Found directive in column 1. (end)
Error[173] C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM 2227 : Source file path exceeds 62 characters (C:\DOCUMENTS AND SETTINGS\AA\DESKTOP\3X3X3 KOCKA\FUJSTZVFHOHJJDQ\LED.ASM)
Halting build on first failure as requested.
Debug build of project `C:\Documents and Settings\aa\Desktop\mpkocka\mpkocka.mcp' failed.
Thu Jan 08 21:52:54 2009
BUILD FAILED |
polh Član
Pridružen-a: Pet 08 Apr 2005 18:27 Prispevkov: 225 Aktiv.: 0.91 Kraj: Maribor-Ljubljana
Objavljeno: Čet Jan 08, 2009 11:20 pm Naslov sporočila: |
Vse skupaj vrži v eno mapo s krajšo "potjo". Ustvari direkt na C:\ eno mapo, vrzi vse noter in poženi znova. |
pomar Član
Objavljeno: Čet Jan 08, 2009 11:38 pm Naslov sporočila: |
Sem naredil. Sedaj mi je napisalo tole. Hex mape še pa vedno ni.
Thu Jan 08 22:26:16 2009
Clean: Done.
Build aborted. The project contains no source files.
BUILD FAILED |
mucek4 Član
Pridružen-a: Sob 18 Jun 2005 20:52 Prispevkov: 2952 Aktiv.: 11.95 Kraj: Tržič - Mesto med gorami
Objavljeno: Pet Jan 09, 2009 7:19 am Naslov sporočila: |
| pomar je napisal/a: |
| Build aborted. The project contains no source files. |
V tem novem projektu nimaš nič asm datotek.
Pri ASM zadevah se zelo izogibaj imenikov z presledki (documents and settings). Naredi si mapo C:\Projekti\ in tam imej svoje projekte. |
GregorN Član
Pridružen-a: Tor 20 Nov 2007 7:48 Prispevkov: 1162 Aktiv.: 5.18 Kraj: Maribor
Objavljeno: Pet Jan 09, 2009 7:53 am Naslov sporočila: |
kaj moreš storiti je:
1. odpreti pač nov projekt, nastaviti kateri mikrokontroler, blabla prevajalnik, kateri kvarc uporabljaš in vse.
2. shraniti asm datoteko
3. v source -> add in dodaš to asm datoteko
4. build all in bi moralo delati.
če ti nebo šlo me dodaj na privat kontakt pa bova rešla problem. _________________ LP! Gregor |
bolha95 Član
Pridružen-a: Pet 14 Dec 2007 21:33 Prispevkov: 296 Aktiv.: 1.33 Kraj: Križe / Tržič
Objavljeno: Pet Jan 09, 2009 8:52 am Naslov sporočila: |
| polh je napisal/a: |
Veliko programov ima težave s predolgo potjo. Poskusi tako kot je dejal polh (pismu imamo pa imena: polh, bolha,... ) _________________ LP,
Robi
Kjer se znanje konča, se domišljija začne |
sraka Član
Pridružen-a: Čet 20 Nov 2008 23:52 Prispevkov: 481 Aktiv.: 2.27 Kraj: PMAVs
Objavljeno: Pet Jan 09, 2009 4:32 pm Naslov sporočila: |
| bolha95 je napisal/a: |
(pismu imamo pa imena: polh, bolha,... ) |
Volk, sraka,... |
ljudsko Član
Pridružen-a: Pon 31 Mar 2008 8:19 Prispevkov: 1184 Aktiv.: 5.39 Kraj: Koroška-Mežica
Objavljeno: Pet Feb 26, 2010 6:45 pm Naslov sporočila: |
Če je programator za koga zanimiv, predlagam tega. Cenejša izdelava, kot ICD2 clone in vsaj jaz ne opazim kakšne druge razlike. Prosim, ne omenjati hitrosti, ker za milisekunde se po mojem ne bo noben obremenjeval. Zadeva je dobro dokumentirana in preprosta za izdelavo. Omogoča programiranje tudi nekaj AVR-jev ter EEPROM-ov.
Lp _________________ return;
brake; |
gumby Član
Pridružen-a: Sob 28 Apr 2007 12:32 Prispevkov: 4066 Aktiv.: 17.60
Objavljeno: Pet Feb 26, 2010 6:48 pm Naslov sporočila: |
ICD2 ni samo programator...
Tale stvar sploh deluje iz MPLAB? _________________ Tule nisem več aktiven. |
Objavljeno: Pet Feb 26, 2010 6:49 pm Naslov sporočila: |
| Citiram: |
| ...Cenejša izdelava, kot ICD2 clone in vsaj jaz ne opazim kakšne druge razlike.... |
Seveda ne. ker očitno ne veš kaj je debuger...prosim ne kotalit takih buč.. _________________ lp
romch Neznanec
Pridružen-a: Pet 10 Sep 2010 13:36 Prispevkov: 8 Aktiv.: 0.04 Kraj: Velenje
Objavljeno: Tor Sep 14, 2010 10:58 am Naslov sporočila: |
Jaz se bom kar na icd2 spravil...  |
luka1995 Član
Pridružen-a: Sob 17 Apr 2010 21:42 Prispevkov: 614 Aktiv.: 3.15 Kraj: Ljubljana
Objavljeno: Tor Sep 14, 2010 11:22 am Naslov sporočila: |
| gumby je napisal/a: |
| ICD2 ni samo programator... |
kaj pa še je? |
gumby Član
Objavljeno: Tor Sep 14, 2010 12:05 pm Naslov sporočila: |
In-Circuit Debugger _________________ Tule nisem več aktiven. |
