toshiba Član
Pridružen-a: Tor 21 Okt 2003 8:56 Prispevkov: 127 Aktiv.: 0.54 Kraj: Ljubljana - Šiška
Objavljeno: Pon Apr 11, 2005 12:55 pm Naslov sporočila: FREEEENKI pomoč, prosim. |
Zdaj, ko sem malo raziskoval zakaj mi noče delovati pripenjanje datotek, sem ugotovil, da mi tudi download ne dela. Isto mi javi kot da so datoteke namenjene uporabnikom foruma. Vem, da mi je to do nedavnega delovalo B.P. sedaj pa je nekaj narobe. Nič nisem spreminjal mail naslovov in sta oba enaka, kar sem preveril tudi v obeh profilih. Prosim za pomoč, ker mi res ne pade več nobena ideja.
Hvala
Objavljeno: Pon Apr 11, 2005 1:38 pm Naslov sporočila: |
koliko vidim jaz v log-u si porabil dnevni limit.
Koda: |
11.04.2005-11:56:35 upload toshiba 212.13.xxxxx data/Zabava/srnica.wmv
11.04.2005-11:59:05 downloadfile toshiba 212.13.xxxxx data/Zabava/srnica.wmv
11.04.2005-11:59:29 deletefile toshiba 212.13.xxxx data/Zabava/srnica.wmv
11.04.2005-12:02:51 createdir toshiba 212.13.xxxx data/Zabava/Fredi Miler
11.04.2005-12:03:21 upload toshiba 212.13.xxx data/Zabava/Fredi Miler/srnica.rar
11.04.2005-12:03:30 downloadfile toshiba 212.13xxxxx data/Zabava/Fredi Miler/srnica.rar
11.04.2005-12:03:49 deletefile toshiba 212.13.xxxxdata/Zabava/Fredi Miler/srnica.rar
11.04.2005-12:07:02 upload toshiba 212.13.xxxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:07:05 view toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:07:08 downloadfile toshiba 212.13xxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:07:41 deletefile toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:09:27 upload toshiba 212.13.xxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:09:31 view toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:09:34 downloadfile toshiba 212.13.xxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:09:59 deletefile toshiba 212.13.xxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:12:38 upload toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:12:50 downloadfile toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:13:11 deletefile toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.zip
11.04.2005-12:22:14 upload toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.rar
11.04.2005-12:22:33 downloadfile toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.rar
11.04.2005-12:22:47 deletefile toshiba 212.13.xxxx data/Zabava/Fredi Miler/srnica.rar
11.04.2005-12:29:37 downloadfile toshiba 212.13.xxx data/Zabava/BMW_M5_-_Fastest_Saloon_Car_on_the_Planet.avi
11.04.2005-12:30:05 downloadfile toshiba 212.13.xxxx data/Zabava/BMW_M5_-_Fastest_Saloon_Ca |
_________________ lp
toshiba Član
frenki Moderator
Pridružen-a: Ned 23 Feb 2003 21:26 Prispevkov: 6734 Aktiv.: 28.42 Kraj: Ljubljana (JN76GB)
Objavljeno: Tor Apr 12, 2005 5:44 pm Naslov sporočila: |
Naredi MD5 hash in ga primerjaj s tem:
Koda: |
0eab0afe8eeab850bae1149aee92d442 srnica.zip |
Da vidimo, kje se pravzaprav začne problem. Na strežniku dobim tole od tvoje datoteke:
Koda: |
unzip -t srnica.zip
Archive: srnica.zip
testing: srnica.wmv bad CRC 735fe666 (should be 77bb9552)
At least one error was detected in srnica.zip.
Lp, Frenki
p.s. Mimogrede : Pravila!
toshiba Član
Objavljeno: Čet Apr 14, 2005 8:55 am Naslov sporočila: |
Frenki, kaj je to MD5 hash in kako to naredim???
Highlag Član
Objavljeno: Čet Apr 14, 2005 3:12 pm Naslov sporočila: |
Obišči tole stran:
http://www.fourmilab.ch/md5/
MD5 je zelo enostavno povedano edinstvena koda, s katero lahko identificiraš kakršnokoli binarno datoteko. Program MD5 pregleda datoteko in generira ključ, ki je "edinstven" za to datoteko. Če ima druga datoteka enak ključ bi morala biti datoteki identični. Če se razlikuje samo za 1 bit bo ključ popolnoma drugačen.
Orodje se uporablja za identifikacijo in preverjanje prenešenih datotek preko spleta. Ker pri prenosu lahko pride do napake lahko z tem ključem preveriš če je datoteka enaka tisti, ki si jo hotel prenesti.
Zakaj pišen edinstven v narekovajih? Zato ker so že odkrili, da je možno da imata dve različni datoteki enak ključ. Je pa verjetnost za to izredno majhna.
frenki Moderator
Objavljeno: Čet Apr 14, 2005 7:11 pm Naslov sporočila: |
Natančno tako, kot je napisal Highlag. No, kljub omenjeni "pomanjkljivosti" pa je zadeva povsem uporabna za marsikakšno kontrolo. Z omenjenim postopkom bi načeloma lahko ugotovil ali je datoteka prišla na strežnik nespremenjena. Če temu ni tako, pa bo potrebno iskat vzroke naprej. Zaenkrat mislim, da so razmeroma redki primeri, v katerih prihaja do napak pri uploadu datotek na ta strežnik.
Lp, Frenki
toshiba Član
Objavljeno: Pet Apr 15, 2005 8:24 am Naslov sporočila: |
Frenki, naredil sem test datoteke srnica.zip, vendar mi izračuna popolnoma drugačno kodo, kot pri tebi. Torej, če pravilno razumem, nastane napaka pri prenosu podatkov. Ali lahko še kaj postorimo, preverim kake nastavitve, ali pa se sprijaznim s tem, da pač deluje kot deluje
P.s. Očitno imam težave tudi pri nalaganju slikic, saj (vsaj pri meni) vidim, da je tudi print screen, ki sem ga pripel malo popačen.
278.44 KB |
31 krat |
pitagora Neznanec
Pridružen-a: Pet 13 Maj 2005 8:19 Prispevkov: 1 Aktiv.: 0.00
Objavljeno: Pet Maj 13, 2005 8:28 am Naslov sporočila: problem pri datotekah |
pravkar sem se registriral, na obeh (foruma, in samega portala)
pa ko zelim kaksno datoteko k sebi prenest mi javi da je samo za uporabnke foruma!!
kaj narediti.
Objavljeno: Pet Maj 13, 2005 8:34 am Naslov sporočila: |
Preberi Pravila na forumu . Lepo piše ..Pravilo Št. 6
aly Član
Objavljeno: Sob Maj 14, 2005 3:25 am Naslov sporočila: |
jaz predlagam, da se tisto besedilo: "samo za uporabnike foruma" razširi še s kakšnim stavkom več, ki bi omenjal tri dni po prijavi, prispevek, dnevni limit in pravilo št. 6.
Sedaj je sistem nekako takšen, kot npr. da se ti avto na avtocesti sam ugasne, in izpiše samo besedico "error" in nič drugega
LP, aly.
