PIC & Atmel usb programator
mzmarez
Pridružen-a: Tor 22 Jan 2008 19:03
Prispevkov: 184
Aktiv.: 0.87
PrispevekObjavljeno: Pon Okt 26, 2009 9:18 am    Naslov sporočila:  PIC & Atmel usb programator Odgovori s citatom
Na spletu sem zasledil usb programator, ki podpira precej Picev in tudi nekaj Atmelov (italjanski avtor). Zdi se mi sorazmerno enostaven. Prednost se mi zdi , da podpira USB . Dela v Linuxu in Windosih.
10F200, 10F202, 10F204, 10F206, 10F220, 10F222,
12F508, 12F509, 12F510, 12F519, 12F609, 12F615, 12F629, 12F635, 12F675, 12F683,
16F505, 16F506, 16F526, 16F54, 16F610, 16F616, 16F627, 16F627A, 16F628, 16F628A, 16F630, 16F631, 16F636, 16F639, 16F648A, 16F676, 16F677, 16F684, 16F685, 16F687, 16F688, 16F689, 16F690, 16F716, 16F73, 16F737, 16F74, 16F747, 16F76, 16F767, 16F77, 16F777, 16F785, 16F818, 16F819, 16F83, 16F83A, 16C83, 16C83A, 16F84, 16C84, 16F84A, 16C84A, 16F87, 16F870, 16F871, 16F872, 16F873, 16F873A, 16F874, 16F874A, 16F876, 16F876A, 16F877, 16F877A, 16F88, 16F882, 16F883, 16F884, 16F886, 16F887, 16F913, 16F914, 16F916, 16F917, 16F946,
18F242, 18F248, 18F252, 18F258, 18F442, 18F448, 18F452, 18F458, 18F1220, 18F1230, 18F1320, 18F1330, 18F2220, 18F2221, 18F2320, 18F2321, 18F2331, 18F2410, 18F2420, 18F2423, 18F2431, 18F2439, 18F2450, 18F2455, 18F2458, 18F2480, 18F2510, 18F2515, 18F2520, 18F2523, 18F2525, 18F2539, 18F2550, 18F2553, 18F2580, 18F2585, 18F2610, 18F2620, 18F2680, 18F2682, 18F2685, 18F4220, 18F4221, 18F4320, 18F4321, 18F4331, 18F4410, 18F4420, 18F4423, 18F4431, 18F4439, 18F4450, 18F4455, 18F4458, 18F4480, 18F4510, 18F4515, 18F4520, 18F4523, 18F4525, 18F4539, 18F4550, 18F4553, 18F4580, 18F4585, 18F4610, 18F4620, 18F4680, 18F4682, 18F4685,
2400, 2401, 2402, 2404, 2408, 2416, 2432, 2464, 24128, 24256, 24512, 241025,
93C46C, 93C56C, 93C66C, 93S46, 93S56, 93S66
AT90S1200, AT90S8515, AT90S8535, ATmega8, ATmega8A, ATmega8515, ATmega8535, ATmega16, ATmega16A, ATmega32, ATmega32A
devices supported for read only:
12C508, 12C508A, 12C509, 12C509A, 12C671, 12C672, 12CE673, 12CE674
http://openprog.altervista.org/
stromar
Pridružen-a: Pon 01 Dec 2008 18:52
Prispevkov: 31
Aktiv.: 0.15
Kraj: Šentjur
PrispevekObjavljeno: Čet Nov 05, 2009 9:55 pm    Naslov sporočila:   Odgovori s citatom
Zanimiva izvedba programatorja. Je že kdo preiskusil, če deluje?
ljudsko
Pridružen-a: Pon 31 Mar 2008 8:19
Prispevkov: 1184
Aktiv.: 5.65
Kraj: Koroška-Mežica
PrispevekObjavljeno: Sob Nov 07, 2009 2:19 pm    Naslov sporočila:   Odgovori s citatom
Tudi mene to zanima, ker si ga bom izdelal.
return;
brake;
powr
Prispevkov: 668
Aktiv.: 3.13
PrispevekObjavljeno: Sob Nov 07, 2009 7:34 pm    Naslov sporočila:   Odgovori s citatom
Pa je to kompatibilno z mplabom in avrstudijem? Ker kolkor sem na hitro pogledal ni
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Ned Nov 08, 2009 3:12 pm    Naslov sporočila:   Odgovori s citatom
Sprogramiraš v Mplabu ali VisualStudio in narediš .hex datoteko, program v mikrokrmilnik preneseš s tem
return;
brake;
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Sre Nov 25, 2009 7:03 pm    Naslov sporočila:   Odgovori s citatom
Ko izdelujem kako vezje, vedno pošljem mami v službo predlogo, da mi natisne, ker doma nimam laserskega printerja, oz. nekaj zafrkava (izdelujem s postopkom "laminator"). Danes mi je prinesla natisnjeno predlogo za tale programator. Poslal pa sem ji pdf, ki je v paketu na spletni strani. No, zadeva je prevelika, ker sem poizkusil na papirju in se ne ujema s podnožji. Zato sem v Linuxih odprl originalno PCB datoteko in jo izvozil kot .ps datoteko. To sem prenesel v windows in sconvertal v pdf. Nato sem pobrisal ostalo šaro iz datoteke, da sem dobil samo to predlogo. Doma sem jo sprintal z brizgalnikom in sedaj je mera prava. Podnožje štima. Prilagam datoteko, če bo kdo izdeloval programator, da se ne bo mučil z velikostjo:
Oprog.pdf
prava velikost
 Ime datoteke:  Oprog.pdf
 Velikost datoteke:  33.54 KB
 Downloadano:  87 krat
return;
brake;
Aktiv.: 61.92
PrispevekObjavljeno: Sre Nov 25, 2009 7:28 pm    Naslov sporočila:   Odgovori s citatom
Izvorna datoteka "OprogBasePCB_BN.pdf" je čisto vredo. Je pač potrebno ustrezno nastaviti Acrobat pred tiskanjem. V prilogi natisnjena tiskanina iz orginala.
Velikost pri taki nastavitvi ne bo pravilna
 Velikost datoteke:  173.38 KB
 Pogledana:  102 krat
Pravilna nastavitev za izpis
 Velikost datoteke:  174.25 KB
 Pogledana:  63 krat
Test pravilne velikosti
 Velikost datoteke:  419.28 KB
 Pogledana:  44 krat
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Sre Nov 25, 2009 7:37 pm    Naslov sporočila:   Odgovori s citatom
Vztrajam, saj mama ni nikoli nič nastavljala, pa je vedno prinesla prave mere domov. No ne vem, lahko, da imaš prav, ampak kako zdaj to mami dopovedat, da bo nastavila kot je potrebno. Saj sploh ne vem, kateri program ima v službi za pdf datoteke in če bi jo vprašal, verjetno ne bi vedela. Obstaja kakšna možnost, da se v datoteki nastavijo mere in takšne ostanejo? Da se potem samo sprinta.
return;
brake;
Aktiv.: 61.92
PrispevekObjavljeno: Sre Nov 25, 2009 7:45 pm    Naslov sporočila:   Odgovori s citatom
Jaka umetnost pogledat pred tiskanjem kako je nastavljeno?
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Sre Nov 25, 2009 7:47 pm    Naslov sporočila:   Odgovori s citatom
No ok, bom že, pustimo potem, se opravičujem..
PS.: Mama je pa le mama Wink
return;
brake;
Aktiv.: 61.92
PrispevekObjavljeno: Sre Nov 25, 2009 8:01 pm    Naslov sporočila:   Odgovori s citatom
ljudsko je napisal/a:
Dejstvo je, da se to lahko zgodi vsakemu ne le "mami", zato je dobro pogledati nastavitve pred tiskanjem. Tudi sam sem že naredil neustrezno tiskanino, ravno zaradi tega sem napisal tole opozorilo.
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Sre Nov 25, 2009 8:26 pm    Naslov sporočila: icon_note  Odgovori s citatom
Ne, narobe sva se razumela. S stavkom "mama je pa le mama" sem mislil, da bo mamo težko naučiti nastaviti stvari Smile ampak bom že...
return;
brake;
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Pet Nov 27, 2009 11:34 am    Naslov sporočila:   Odgovori s citatom
Silvo, ali si ti dodatno zrcalil vezje pred tiskanjem? Ker meni je narobe prišlo. Shocked
return;
brake;
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Ned Nov 29, 2009 2:37 pm    Naslov sporočila:   Odgovori s citatom
Se bi na forumu našel kdo, ki bi mi hotel sprogramirati tale PIC18F2550? Poslal bi ga po pošti (seveda, jaz plačam poštnino).
Drugače pa sem malo brskal po internetu in me zanima, če bi ga na tak način lahko sam sprogramiral. Ker pa piše, da čip potrebuje zunanje napajanje, bi tak napajalnik naredil iz 9V baterije in 78L05 regulatorjem. Bi šlo?
return;
brake;
ljudsko
Prispevkov: 1184
Aktiv.: 5.65
PrispevekObjavljeno: Ned Nov 29, 2009 7:24 pm    Naslov sporočila:   Odgovori s citatom
Res ni koga?
return;
brake;
Stran 1 od 4
