Krampus Član
Pridružen-a: Pon 08 Sep 2008 13:07 Prispevkov: 1853 Aktiv.: 9.07
Objavljeno: Ned Feb 21, 2010 7:42 pm Naslov sporočila: |
galex4 je napisal/a: |
kako iz celega števila pretvoriti na decimalko, za DS1820 imam naslednjo kodopisano v mikroBASIC-u
koda:
program One_WIRE_1
dim LCD_RS as sbit at RB4_bit
LCD_EN as sbit at RB5_bit
LCD_D4 as sbit at RB0_bit
LCD_D5 as sbit at RB1_bit
LCD_D6 as sbit at RB2_bit
LCD_D7 as sbit at RB3_bit
LCD_RS_Direction as sbit at TRISB4_bit
LCD_EN_Direction as sbit at TRISB5_bit
LCD_D4_Direction as sbit at TRISB0_bit
LCD_D5_Direction as sbit at TRISB1_bit
LCD_D6_Direction as sbit at TRISB2_bit
LCD_D7_Direction as sbit at TRISB3_bit
dim txt as char[9]
temp as word
dim TextLcd as Char[10]
dim TempLSB as word
dim TempMSB as word
main:
ADCON1 = %00000110
Lcd_Init()
Lcd_Cmd(_LCD_CLEAR)
Lcd_Cmd(_LCD_CURSOR_OFF)
Lcd_Out(1, 1, " Temperatura: ")
Lcd_Chr(2,13,178)
Lcd_Chr(2,14,"C")
while true
Ow_Reset(PORTE, 2)
Ow_Write(PORTE, 2, 0xCC)
Ow_Write(PORTE, 2, 0x44)
Delay_us(120)
Ow_Reset(PORTE, 2)
Ow_Write(PORTE, 2, 0xBE)
temp = Ow_Read(PORTE, 2)
temp = temp / 2
TempLSB = Ow_Read(PORTE, 2)
TempMSB = Ow_Read(PORTE, 2)
temp = (TempMSB << 8) + TempLSB
IntToStr(temp / 2, LcdToStr)
Lcd_Out(2,1,LcdToStr)
WordToStr(temp, txt)
Lcd_Out(2, 8, txt)
delay_ms(520)
wend
end.
ko če temp ne delim z 2 ima 1x večjo vrednost pri delitvi pa dobim celo število, na kak način pa dosežem tistih 0,5??
kakšne vrednosti sta tista 2 byta (LSB in MSB)iz katerih nato preračunamo realno vrednost? |
Malo bolj razdelano, kot bi bilo potrebno, mogoče za boljše razumevanje _________________ Nisem ravno najbolj pameten na svetu, tu in tam pa imam kakšno idejo. |
mato1111 Član
Pridružen-a: Pet 28 Dec 2012 14:42 Prispevkov: 617 Aktiv.: 4.06 Kraj: Vrhnika
Objavljeno: Pet Feb 26, 2016 5:48 pm Naslov sporočila: |
Bi bil kdo tako prijazen in napisal kako se definira in vklopi/izklopi posamezni pin (LED) ? |
tilz0R Član
Pridružen-a: Čet 31 Maj 2012 15:39 Prispevkov: 898 Aktiv.: 5.65 Kraj: Črnomelj
Objavljeno: Sob Feb 27, 2016 12:21 pm Naslov sporočila: |
mato1111 je napisal/a: |
Google je pravi norc _________________ Knowledge sharing is caring.
majerle.eu | stm32f4-discovery.net |
mato1111 Član
Objavljeno: Ned Feb 28, 2016 7:58 pm Naslov sporočila: |
kako se spremenljivko tipa int prikaze na LCD? z tekstom mi je uspelo z spremenljivkami pa nikakor ne. |
tilz0R Član
Objavljeno: Ned Feb 28, 2016 8:00 pm Naslov sporočila: |
Pretvoriš jo v string. _________________ Knowledge sharing is caring.
mato1111 Član
Objavljeno: Čet Apr 27, 2017 11:07 am Naslov sporočila: |
Imam neko deklarirano spremenljivko char a[6];
Kako bi vanjo med izvajanjem programa vpisal vrednost "levo" ali "desno" ? |
