Hi-tech picc Error[1091]
ljudsko
Pridružen-a: Pon 31 Mar 2008 8:19
Prispevkov: 1184
Aktiv.: 5.39
Kraj: Koroška-Mežica
PrispevekObjavljeno: Sre Dec 15, 2010 11:41 am    Naslov sporočila:  Hi-tech picc Error[1091] Odgovori s citatom
V Piklabu pišem program v C-ju za merilec hitrosti in uporabljam PICC prevajalnik od HI-TECH (verzija 9.80). Težava je v tem, da uporabljam dve izvorni .c datoteki (merilec_hitrosti.c in lcd.c). Če vsebino lcd.c prekopiram v merilec_hitrosti.c, se projekt zgradi brez težav, čim ko je program v večdatotečni obliki, mi ne da miru z napako
Koda:
Error[1091] /usr/hitech/picc/9.80/sources/float.c 86 : main function "_main" not defined
Lcd.h:
Koda:
 *   LCD interface header file
 *   See lcd.c for more info
/* write a byte to the LCD in 4 bit mode */
extern void lcd_write(unsigned char);
/* Clear and home the LCD */
extern void lcd_clear(void);
/* write a string of characters to the LCD */
extern void lcd_puts(const char * s);
/* Go to the specified position */
extern void lcd_goto(unsigned char pos);
/* intialize the LCD - call before anything else */
extern void lcd_init(void);
extern void lcd_putch(char);
/*   Set the cursor position */
#define   lcd_cursor(x)   lcd_write(((x)&0x7F)|0x80)
Lcd.c:
Koda:
 *   LCD interface example
 *   Uses routines from delay.c
 *   This code will interface to a standard LCD controller
 *   like the Hitachi HD44780. It uses it in 4 bit mode, with
 *   the hardware connected as follows (the standard 14 pin
 *   LCD connector is used):
 *   PORTD bits 0-3 are connected to the LCD data bits 4-7 (high nibble)
 *   PORTA bit 3 is connected to the LCD RS input (register select)
 *   PORTA bit 1 is connected to the LCD EN bit (enable)
 *   To use these routines, set up the port I/O (TRISA, TRISD) then
 *   call lcd_init(), then other routines as required.
#ifndef _XTAL_FREQ
 // Unless specified elsewhere, 4MHz system frequency is assumed
 #define _XTAL_FREQ 4000000
#endif
#include   <htc.h>
#include   "lcd.h"
#define   LCD_RS RA0
//#define   LCD_RW RA2
#define LCD_EN RA1
#define LCD_DATA   PORTB
#define   LCD_STROBE()   ((LCD_EN = 1),(LCD_EN=0))
void
lcd_write(unsigned char c)
   __delay_us(40);
   LCD_DATA = ( ( c >> 4 ) & 0x0F );
   LCD_STROBE();
   LCD_DATA = ( c & 0x0F );
   LCD_STROBE();
void
lcd_clear(void)
   LCD_RS = 0;
   lcd_write(0x1);
   __delay_ms(2);
/* write a string of chars to the LCD */
void
   LCD_RS = 1;   // write characters
   while(*s)
      lcd_write(*s++);
/* write one character to the LCD */
void
lcd_putch(char c)
   lcd_write( c );
void
   LCD_RS = 0;
   lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init()
   char init_value;
   //ADCON1 = 0x06;   // Disable analog pins on PORTA
   init_value = 0x3;
   TRISA=0;
   TRISB=0;
   LCD_RS = 0;
   LCD_EN = 0;
   //LCD_RW = 0;
   __delay_ms(15);   // wait 15mSec after power applied,
   LCD_DATA    = init_value;
   LCD_STROBE();
   __delay_ms(5);
   LCD_STROBE();
   __delay_us(200);
   LCD_STROBE();
   __delay_us(200);
   LCD_DATA = 2;   // Four bit mode
   LCD_STROBE();
   lcd_write(0x28); // Set interface length
   lcd_write(0xF); // Display On, Cursor On, Cursor Blink
   lcd_clear();   // Clear screen
   lcd_write(0x6); // Set entry Mode
merilec_hitrosti.c: (program zdaj še ne dela nič)
Koda:
#include <htc.h>
#include "lcd.h"
__CONFIG(UNPROTECT & LVPDIS & BORDIS & MCLREN & PWRTEN & WDTDIS & HS);
#ifndef _XTAL_FREQ
#define   _XTAL_FREQ 8000000
#endif
void
main (void)
Googlam že 2 uri, pa brez rezultata. V manualu sicer piše nekaj o tej napaki, ampak mi ne pove nič (da mora vsak program imeti funkcijo main()... Brick wall ). Ima kdo kakšno idejo, ker meni se bo utrgalo?
return;
brake;
sraka
Pridružen-a: Čet 20 Nov 2008 23:52
Prispevkov: 481
Aktiv.: 2.27
Kraj: PMAVs
PrispevekObjavljeno: Sre Dec 15, 2010 12:03 pm    Naslov sporočila:   Odgovori s citatom
Nauk: Programiranje je igra, kjer se ti lahko utrga.
Danes je težko biti budala, konkurenca je velika, pa še dokazovati se moraš večkrat na dan.
Sem ogledalo: Nisem kriv, če v meni vidite nekaj kar vam ni všeč.
snow
Pridružen-a: Tor 27 Dec 2005 14:02
Prispevkov: 341
Aktiv.: 1.38
Kraj: Ljubljana || Velenje
PrispevekObjavljeno: Sre Dec 15, 2010 10:30 pm    Naslov sporočila:   Odgovori s citatom
To delaš v mplabu ali zaženeš picc compiler na roke?
ljudsko
Prispevkov: 1184
Aktiv.: 5.39
PrispevekObjavljeno: Sre Dec 15, 2010 11:31 pm    Naslov sporočila:   Odgovori s citatom
To delam v Piklabu (Ubuntu-Linux), kjer prevajalnik kličem prek tega IDE-ja. Zakaj, je to pomembno?
return;
brake;
igo
Prispevkov: 3641
Aktiv.: 15.32
PrispevekObjavljeno: Sre Dec 15, 2010 11:40 pm    Naslov sporočila:   Odgovori s citatom
Ja pa napiši notri v main
a=0;
i=0;
for i=0 ; i=100 ; i++
a=i+a :
end for
i=0;
a=0;
ali nekaj podobnega. Ne moreš imeti praznega podprograma, sploh pa ne main (glavni program).
Sicer pa v main spada
- komplet inicializacija (LCD, ADC, I/O, vpis konstant in parametrov,...) nato pa
while(1)
.... glavna zanka, ki kliče podprograme ...
LP, Igor
dule26
Pridružen-a: Tor 28 Sep 2010 7:30
Prispevkov: 26
Aktiv.: 0.14
Kraj: Murska Sobota
PrispevekObjavljeno: Čet Dec 16, 2010 8:09 am    Naslov sporočila:   Odgovori s citatom
Poskusi namesto "void main(void){}" napisat "int main() {}"
ljudsko
Prispevkov: 1184
Aktiv.: 5.39
PrispevekObjavljeno: Čet Dec 16, 2010 12:28 pm    Naslov sporočila:   Odgovori s citatom
int main() brez return?
return;
brake;
dule26
Prispevkov: 26
Aktiv.: 0.14
Kraj: Murska Sobota
PrispevekObjavljeno: Čet Dec 16, 2010 12:32 pm    Naslov sporočila:   Odgovori s citatom
Brez!
ljudsko
Prispevkov: 1184
Aktiv.: 5.39
PrispevekObjavljeno: Čet Dec 16, 2010 2:57 pm    Naslov sporočila:   Odgovori s citatom
Zaenkrat niti preizkusiti ne morem, ker v Piklabu ne morem nastaviti prevajalnika. Kl!k
return;
brake;
ljudsko
Prispevkov: 1184
Aktiv.: 5.39
PrispevekObjavljeno: Ned Dec 19, 2010 4:10 pm    Naslov sporočila:   Odgovori s citatom
Ista napaka. Int main() ne pomaga Confused
return;
brake;
bungee
Prispevkov: 1479
Aktiv.: 5.99
PrispevekObjavljeno: Pon Dec 20, 2010 12:59 am    Naslov sporočila:   Odgovori s citatom
A ni Void main() Rolling Eyes
igo
Prispevkov: 3641
Aktiv.: 15.32
PrispevekObjavljeno: Pon Dec 20, 2010 3:26 am    Naslov sporočila:   Odgovori s citatom
Ali morajo biti frekvence povsod enake?
Enkrat je 4MHz, drugič pa 8MHz.
Povsem izbriši void in main ter ju napiši na novo. Lahko si kak skrit znak pred m natipkal. ALT GR + ... ali podobno.
Morda mora biti main(), namesto main () . Včash so povsem brezvezne stvari.
Vzemi eno delujočo datoteko in pobriši vse ven, razen main.
LP, Igor
ljudsko
Prispevkov: 1184
Aktiv.: 5.39
PrispevekObjavljeno: Pon Dec 20, 2010 1:52 pm    Naslov sporočila:   Odgovori s citatom
Zanimivo je, ker samo to datoteko gre prevest, če dam compile this file, projekta pa ne gre zgradit. Z ukazne vrstice pa gre obe datoteki, vsako posebej prevesti. Ne razumem ravno najbolje ukazne vrstice za ta prevajalnik.
return;
brake;
ljudsko
Prispevkov: 1184
Aktiv.: 5.39
PrispevekObjavljeno: Pon Dec 20, 2010 4:50 pm    Naslov sporočila:   Odgovori s citatom
Odločil sem se, da bom programiral prevajal z SDCC. Zanima me, na kakšen način bi lahko v nek del asm kode, ki jo vključim v c kodo prenesel vrednost iz kode, ki je napisana v c. Recimo imam funkcijo:
Koda:
void funkcija (int vrednost) {_asm 'Tukaj želim recimo movlw vrednost _endasm;}
Namreč dobil sem idejo, da bi driver za LCD napisal sam v zbirniku v neko funkcijo, potem pa bi to funkcijo klical iz glavnega programa:
Koda:
lcd_pisi ("besedilo");
return;
brake;
Uptime: 233 dni
