ljudsko Član
Pridružen-a: Pon 31 Mar 2008 8:19 Prispevkov: 1184 Aktiv.: 5.39 Kraj: Koroška-Mežica
Objavljeno: Sob Jan 29, 2011 8:44 pm Naslov sporočila: usb 2.0 se obnaša kot 1.1 |
Kolega mi je posodil zunanji disk. Nanj sem hotel skopirati 70GB podatkov. Podatki so se začeli prenašati s 300KB/s, kar je očitna lastnost USB 1.1 vodila. Če grem v Ubuntu-ju pod diskovna orodja, piše za disk, da deluje pri hitrosti 480Mb/s (USB 2.0) in preizkus hitrosti branja mi da rezultate od 30-40MB/s, kar je čisto realno za USB 2.0. Ampak, ko podatke hočem zapisati na disk, pa se obnaša, kot bi bil na 1.1 vodilu. V biosu imam omogočeno USB legacy ter High speed usb 2.0 controller.
#lsusb mi da rezultate:
| Citiram: |
Bus 004 Device 002: ID 046d:c050 Logitech, Inc. RX 250 Optical Mouse
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 1058:0910 Western Digital Technologies, Inc. MyBook Essential External HDD
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub |
#lsmod | grep usb:
| Citiram: |
usbhid 42030 0
hid 84710 1 usbhid
usb_storage 50372 1 |
#lspci -vv za USB:
| Citiram: |
00:02.0 USB Controller: nVidia Corporation MCP78S [GeForce 8200] OHCI USB 1.1 Controller (rev a1) (prog-if 10 [OHCI])
Subsystem: ASUSTeK Computer Inc. Device 82f2
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0 (750ns min, 250ns max)
Interrupt: pin A routed to IRQ 20
Region 0: Memory at fea7e000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [44] Power Management version 2
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Kernel driver in use: ohci_hcd
00:02.1 USB Controller: nVidia Corporation MCP78S [GeForce 8200] EHCI USB 2.0 Controller (rev a1) (prog-if 20 [EHCI])
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin B routed to IRQ 22
Region 0: Memory at fea7fc00 (32-bit, non-prefetchable) [size=256]
Capabilities: [44] Debug port: BAR=1 offset=00a0
Capabilities: [80] Power Management version 2
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME+
Kernel driver in use: ehci_hcd
00:04.0 USB Controller: nVidia Corporation MCP78S [GeForce 8200] OHCI USB 1.1 Controller (rev a1) (prog-if 10 [OHCI])
Interrupt: pin A routed to IRQ 23
Region 0: Memory at fea7d000 (32-bit, non-prefetchable) [size=4K]
00:04.1 USB Controller: nVidia Corporation MCP78S [GeForce 8200] EHCI USB 2.0 Controller (rev a1) (prog-if 20 [EHCI])
Interrupt: pin B routed to IRQ 21
Region 0: Memory at fea7f800 (32-bit, non-prefetchable) [size=256]
Poskusil sem tudi že s tem: #modprobe ehci_hcd in brez učinka. Torej, kaj mi preprečuje hitrost, ki jo omogoča USB 2.0? _________________ return;
brake; |
ljudsko Član
Objavljeno: Pon Jan 31, 2011 10:56 pm Naslov sporočila: |
Ni nobenega rešitelja? _________________ return;
brake; |
lordkreps Član
Pridružen-a: Sre 17 Okt 2007 9:49 Prispevkov: 103 Aktiv.: 0.46 Kraj: Levi žep
Objavljeno: Čet Feb 10, 2011 12:30 am Naslov sporočila: |
Hrošč
Mogoče update kernela (ali kašnega nazaj) ali pa upgrade. |
ljudsko Član
Objavljeno: Čet Feb 10, 2011 7:28 am Naslov sporočila: |
Kako to storim? _________________ return;
brake; |
eagle Član
Pridružen-a: Ned 12 Apr 2009 18:38 Prispevkov: 40 Aktiv.: 0.19 Kraj: Dolenjska
Objavljeno: Čet Feb 10, 2011 10:23 am Naslov sporočila: |
Imaš disk priklopljen na sprednju USB ali direktno na Osnovni plošči zadaj.
Včasih se je dogajalo, da sprednji USB-ji na ohišju niso podpirali USB2.0 in so delovali kot USB 1.1 |
MarkoM Član
Pridružen-a: Tor 12 Sep 2006 15:29 Prispevkov: 2825 Aktiv.: 11.84 Kraj: Lovrenc na P.
Objavljeno: Čet Feb 10, 2011 10:56 am Naslov sporočila: |
| Če je kabel predolg se zna zgoditi, da se ne more povezati z 2.0. Zato je najbolje priklopiti direktno odzadaj na matično, da ni velikih padcov napetosti na kablu. Nekateri diski imajo dva USB kabla za napajanje. |
ljudsko Član
Objavljeno: Čet Feb 10, 2011 12:57 pm Naslov sporočila: |
Sem že priklopil zadaj, pa se nič ni spremenilo. Zdaj trenutno diska nimam več, pa vseeno, ko ga dobim, da bom vedel kaj storiti. Disk ima posebej napajanje z adapterjem (power jack). Kabel pa nevem, če je dolg 2m. _________________ return;
brake; |
lordkreps Član
Objavljeno: Čet Feb 10, 2011 4:16 pm Naslov sporočila: |
| ljudsko je napisal/a: |
| Kako to storim? |
Upgrade: npr. iz ubuntu 9.10 na 10.4 (ne vem katero verzijo uporabljaš)
Update kernela: Ti ob "update" sistema sam ponudi najnnovejšega, če ne brišeš starih kernelov lahko pa v boot-loaderju izbereš, da ti zažene starejši kernel. (npr. Uporabljaš "kernel 2.6.38-3.30" v bootloaderju izbereš starejšega "kernel 2.6.38-2.29" - če ni viden v bootloaderju so stari izbrisani ali pa prikazuje samo zadnjo verzijo)
Je poznan horšč za tvojo situacijo in to dvoje je ponavadi rešitev.
Nekateri pa spoznajo da je strojna omejitev:
- kabel
- zunanji disk nima usb2 kontrolerja
- vsi usb priključki ne podpirajo usb2 (tudi zadaj računalnika ne vsi, npr. moja matična ima zadaj 6 priključkov in od tega sta dva usb2, celo obarvana imam drugače :=))
Tretja stvar katero bi rekel: Procesorska moč in velikost RAM vpliva tudi na usb predvsem pri velikih datotekah. (to pa ne verjamem da je pri tebi problem) |
ljudsko Član
Objavljeno: Čet Feb 10, 2011 4:23 pm Naslov sporočila: |
Ne, procesor in RAM pri meni res ne bi smela biti problem (4GB in AMD X2 6000+)..Na to pa nikoli nisem pomislil. Zadaj imam res dva priključka rdeča, dva pa črna. Ampak, zakaj bi matična, dokaj sodobna za čas nakupa (2008) imela USB 1.1 priključkov več, kot 2.0?
PS.: Uporabljam Ubuntu 10.10 verzijo, update-am redno... _________________ return;
brake; |
lordkreps Član
Objavljeno: Čet Feb 10, 2011 5:59 pm Naslov sporočila: |
Glede barv sem mislil nekaj napisal drugo
Na matični plošči je več usb 2.0/1.1 kontrolerjev. Na vsakega lahko priključiš določeno število usb naprav. Če je na enem kontrolerju priključenih več naprav usb1.1 in usb2.0 bo naprava z 2.0 delal po hitrostih 1.1.
Zdaj pa kolikor je mojemu serviserju za verjet, tista dva usb, redeče pobarvana, naj bi delala na 2.0 če imaš vse ostale zasedene z različnimi napravami.
Če ni to pa downgrade kernel, pa poglej če je kaj bolje. |
Uptime: 233 dni
