| Avtor |
Objavljeno: Sre Jan 02, 2013 1:50 pm Naslov sporočila: I2c ic-ji |
Iskal sem en NF stereo ojačevalec tam do 10W iz I2C kontrolo.
Naletel sem na tole: ***klik***
Morda pride komu prav.
Takega čipa vseeno nisem našel. Če kdo pozna kakega, oz najde še kak spisek I2c čipovja naj ga doda v temo.
MAXIM
I/O expanders:
MAX6956 20-Port LED Display Driver and digital I/O Expander constant current sink, up to 16 Devices, Interrupt
LED Driver:
MAX6953 4 Digit Matrix LED Driver, up to 140 LEDs
Data Converters:
MAX127/MAX128 octal 12 Bit DAC
MAX521 Octal 8 Bit DAC
MAX 1036/1037 4-channel 8-bit ADC, single supply (5V / 3.3V)
MAX 1038/1039 12-channel 8-bit ADC, single supply (5V / 3.3V)
Microchip
Expanders:
MCP23016 16-bit I/O Port Expander
MCP23017 16-bit I/O Port Expander
MCP23008 8-bit I/O Port Expander
Data converters:
MCP3021 10 bit ADC, one channel
MCP3221 12 bit ADC, one channel
MCP3421 18 bit ADC, one channel
MCP4725 12 bit ADC, one channel
TC1320 8 bit ADC, one channel
TC1321 10 bit ADC, one channel
Serial EEPROMs:
24AA00 128
24C00 128
24LC00 128
24AA01 1K
24LC01B 1K
24C01C 1K
24LC014 1K
24LC21A 1K
24LCS21A 1K
24AA02 2K
24LC02B 2K
24C02C 2K
24LC024 2K
24LC025 2K
24LCS52 2K
24AA04 4K
24LC04B 4K
24AA08 8K
24LC08B 8K
24AA16 16K
24LC16B 16K
24AA32A 32K
24LC32A 32K
24AA64 64K
24LC64 64K
24AA65 64K
24LC65 64K
24AA128 128K
24LC128 128K
24FC128 128K
24AA256 256K
24LC256 256K
24FC256 256K
24AA512 512K
24LC512 512K
24FC512 512K
24AA515 512K
24LC515 512K
24FC515 512K
24AA1025 1024K
24LC1025 1024K
24FC1025 1024K
Niigata Seimitsu
NS73M FM Transmitter (source: sparcfun.com) I2C maybe problematic?
NXP (Philips)
LCD/LED Drivers:
PCA 9533 4-bit LED dimmer (8-bit PWM) suitable for H-Bridges (L293D)
PCA 9531 8-bit LED dimmer (8-bit PWM)
PCA 9532 16-bit LED dimmer (8-bit PWM)
PCF 8566 96 segment LCD driver
PCF 8568 LCD Row driver for dot matrix displays.
PCF 8569 LCD Column driver for DOT matrix displays
PCF 8576 160 segment LCD driver
PCD 8577 64 Segment LCD driver
PCF 8578 LCD Row driver for Dot matrix LCD's
PCD 8579 Column driver for Dot matrix LCD's
SAA 1064 4 Digit Led driver
I/O expanders:
PCF 8574 8 Bit I/O port
PCF 8574A 8 Bit I/O port different address.
SAA 1300 5 Bit high current driver
Data converters:
PCF 8591 4 channel ADC + One DAC (all 8 bits)
TDA 8442 Quad 6 bit DAC
TDA 8444 Octal 6 bit DAC
Memory:
PCF 8570 256 byte static ram
PCf 8571 128 byte static ram
PCF 8581 128 byte EEprom
PCF 8582 256 byte EEprom
PCF 8583 256 byte RAM + Realtime clock and calendar
PCF 8594 512 byte EEprom
PCF 8598 1K byte EEprom
Clocks:
PCF 8573 Clock/Calendar
PCF 8583 Clock/Calendar with 256 byte Ram
Audio / Video:
PCD3311 3312 DTMF / Tone generator
SAA1136 PCM interface
SAA524x Teletext processor
SAA7191 S-VHS decoder
SAA7192 Digital color space converter
SAA7199 Digital encoder
SAA9020 Field memory controller
SAA9051 Digital TV decoder
SAA9068 PIPCO Picture in picture system
SAB3035 3037 Tuning interface
SAF1135 VPS decoder
TDA4680 Video processor
TDA8421 HiFi stereo audio processor
TDA8425 Audio processor with loudspeaker channel
TDA8440 Video switch
TDA8442 Color decoder interface
TDA8443 YUV to RGB unit
TDA8461 PAL / NTSC color decoder
TEA6100 Fm tuning interface
TEA6300 6310 Sound fader control
TSA551x TV Pll synthesizer
TSA6057 Fm Pll synthesizer
Miscellaneous:
SAA1300 5 bit high current driver
UMF1009 Frequency synthesizer
Siemens
Audio Video:
SDA3312 TV PLL synthesizer
SDA2121 TV PLL synthesizer
Memories:
SDA2516 1K bit EEprom
SDA2526 2K bit EEprom
SDA2546 4K bit EEprom
SDA2586 8K bit EEprom
SDA3526 2K bit EEprom with write protection
SDA3546 4K bit EEprom with write protection
SDA3586 8K bit EEprom with write protection
STMicroelectronics
Clocks:
M41T00S RTC w. 64b (8 x 8)
M41T00SC6430 RTC w. Embedded Crystal; 64Kb (8192 x 8); w. EEPROM
M41T11 28 RTC w. BATTERY; 512b (64 x 8);
M41T56 512b RTC w. (64 x 8); SRAM
M41T56C64 RTC w. Embedded Crystal; 64Kb (8192 x 8); w. EEPROM
M41T00 RTC w. 64b (8 x 8)
M41ST84W RTC w. 512b (64 x 8); RTC SUPERVISOR
M41ST85W RTC w. BATTERY; with Embedded Crystal; 512b (64 x 8); RTC SUPERVISOR
M41ST87W RTC w. Embedded Crystal; 1280b (160 x 8); RTC SUPERVISOR
M41ST87Y RTC w. with Embedded Crystal; 1280b (160 x 8); RTC SUPERVISOR
M41T0 RTC w. 64b (8 x 8)
M41T60 RTC w. 64b (8 x 8)
M41T62 RTC w. 128b (16 x 8); with Alarms
M41T65 RTC w. 128b (16 x 8); with Alarms
M41T80 RTC w. 160b (20 x 8); with Alarms
M41T81S RTC w. Embedded Crystal; 160b (20 x 8); with Alarms
M41T82 RTC w. 256b (32 x 8), Battery Switchover
M41T83 RTC w. Embedded Crystal 256b (32 x 8), Battery Switchover
M41T256Y RTC w. BAT Cu wo/socket 256Kb (32K x 8)
M41T81 RTC w. 160b (20 x 8)
Memory:
M24C01-R 1 kbit EEPROM
M24C01-W 1 kbit EEPROM
M24C02-R 2 kbit EEPROM
M24C02-W 2 kbit EEPROM
M24C04-R 4 kbit EEPROM
M24C04-W 4 kbit EEPROM
M24C08-R 8 kbit EEPROM
M24C08-W 8 kbit EEPROM
M24C16-R 16 kbit EEPROM
M24C16-W 16 kbit EEPROM
M24C32-F 32 kbit EEPROM
M24C32-R 32 kbit EEPROM
M24C32-W 32 kbit EEPROM
M24C64-R 64 kbit EEPROM
M24C64-W 64 kbit EEPROM
M34D64-W 64 kbit EEPROM
M24128-BR 128 kbit EEPROM
M24128-BW 128 kbit EEPROM
M24256-BR 256 kbit EEPROM
M24256-BW 256 kbit EEPROM
M24512-R 512 kbit EEPROM
M24512-W 512 kbit EEPROM
M24M01-R 1000 kbit EEPROM
Misc.:
LIS3LV02DL Linear Accelerometer 3-Axis ±2g/ ±6g with digital interface
LIS3LV02DQ Linear Accelerometer 3-Axis ±2g/ ±6g Full Scale with digital interface
Texas Instruments
Audio/Video:
TLV320AIC3101 6 Inputs, 6 Outputs, Speaker & Headphone Amp., Enh. Digital Effects, PowerTune
Buffers:
P82B96 Dual Bidirectional Bus Buffer
Expanders:
PCA6107 Remote 8-Bit Low-Power I/O Expander With Interrupt Output, Reset, and Config Registers
PCA9534 Remote 8-Bit Low-Power I/O Expander with Interrupt Output and Configuration Registers
PCA9534A Remote 8-Bit Low-Power I/O Expander with Interrupt Output and Configuration Registers
PCA9535 Remote 16-Bit Low-Power I/O Expander With Interrupt Output and Config Registers
PCA9536 Remote 4-Bit I/O Expander with Configuration Registers
PCA9538 Remote 8-Bit Low-Power I/O Expander With Interrupt Output, Reset, and Config Registers
PCA9539 Remote 16-Bit Low-Power I/O Expander With Interrupt Output, Reset & Config. Registers
PCA9554A Remote 8-Bit I/O Expander with Interrupt Output and Configuration Registers
PCA9555 Remote 16-Bit I/O Expander With Interrupt Output And Configuration Registers
PCA9557 Remote 8-Bit Low-Power I/O Expander with Reset and Configuration Registers
PCF8574 Remote 8-Bit I/O Expander
PCF8574A Remote 8-Bit I/O Expander
PCF8575 Remote 16-Bit I/O Expander with Interrupt Output
PCF8575C Remote 16-Bit I/O Expander with Interrupt Output
TCA6408 Low-Voltage 8-Bit I/O Expander With Interrupt Output, Reset, and Config Register
Multiplexers:
PCA8550 Non-Volatile 5-Bit Registered Multiplexer with I2C Interface
PCA9544A 4-Channel I2C And SMBus Multiplexer With Interrupt Logic
PCA9545A 4-Channel I2C And SMBus Multiplexer With Interrupt Logic And Reset Functions
PCA9546A 4-Channel I2C And SMBus Multiplexer With Reset Functions
Levelshifters:
PCA9306 Dual Bi-Directional I2C-Bus and SMBus Voltage Level-Translator
Repeaters:
PCA9515A Dual Bidirectional I2C Bus and SMBus Repeater
Hubs/switches:
PCA9518 Expandable Five-Channel I2C Hub
PCA9543A Two-Channel I2C-Bus Switch With Interrupt Logic and Reset
PCA9548A 8-Channel I2C Switch With Reset
LED-Drivers:
TCA6507 Low-Voltage 7-Bit I2C and SMBus LED Driver With Intensity Control and Shutdown
Xicor
Memories:
X24C01 1k bit EEprom
X24012 1k bit EEprom
X24C02 2k bit EEprom
X24022 2k bit EEprom
X24C04 4k bit EEprom
X24042 4k bit EEprom
X24C08 8k bit EEprom
X24C16 16k bit EEprom
X24164 16k bit EEprom
X24X00 128 bit EEprom
X24001 128 bit EEprom
_________________ lp
| Nazaj na vrh |
Objavljeno: Sre Jan 02, 2013 2:18 pm Naslov sporočila: Re: I2c ic-ji |
| Silvo je napisal/a: |
Obstajajo tudi i2c potenciometri.
serija od analog devices AD51yyBCPZ xx y: številka xx upornost v k ohm
serija od intersil ISL223xx
serija Microchip MCP44xx
Pa še je tega. Torej lahko to kobiniraš z ojačevalnikom, ki ima fiksno ojačenje. _________________ Dokler bodo ljudje mislili, da živali ne čutijo, bodo živali čutile, da ljudje ne mislijo. |
| Nazaj na vrh |
borber Član
Pridružen-a: Pon 23 Maj 2005 8:40 Prispevkov: 3111 Aktiv.: 12.59 Kraj: LJUBLJANA
Objavljeno: Sre Jan 02, 2013 2:36 pm Naslov sporočila: |
LM4681
10 Watt Stereo CLASS D Audio Power Amplifier with Stereo Headphone Amplifier and I2C/SPI Volume Control
MAX9768
10W Mono Class D Speaker Amplifier with Volume Control
itd. |
| Nazaj na vrh |
Objavljeno: Sre Jan 02, 2013 4:38 pm Naslov sporočila: |
Borber hvala,
Tisti prvi je zelo zanimiv, a ga Farnell nima. Pri Digikey-ju je na spisku a ni zaloge.
Volk ve, zakjaj gre , no varianta so seveda tudi digitalni potecionetri.
PS
Kaj več napišem, ko bo zadeva tako daleč, da bo kaj za pokazat Za enkrat je vse še na testni plošči. _________________ lp
| Nazaj na vrh |
Pridružen-a: Ned 19 Sep 2004 22:04 Prispevkov: 16777193 Aktiv.: 67897.58
Objavljeno: Sre Jan 02, 2013 7:49 pm Naslov sporočila: |
| Brisana vsebina odstranjenega uporabnika. |
| Nazaj na vrh |
KernelPanic Član
Pridružen-a: Pon 13 Avg 2012 10:29 Prispevkov: 162 Aktiv.: 0.97 Kraj: Ljubljana
Objavljeno: Pet Jan 04, 2013 2:50 pm Naslov sporočila: |
ST TEA6420: Audio Matrix, 5 Input, 4 Output, glede na napetost na pinu (0V, 5V) se mu lahko nastavljata dva razlicna naslova!
Lp,
Marko
Nazadnje urejal/a KernelPanic Pet Jan 04, 2013 7:14 pm; skupaj popravljeno 1 krat |
| Nazaj na vrh |
bpavsic Član
Pridružen-a: Pet 03 Apr 2009 20:45 Prispevkov: 354 Aktiv.: 1.71 Kraj: Maribor
Objavljeno: Pet Jan 04, 2013 5:13 pm Naslov sporočila: |
Microchip
MCP9808 - i2c temperaturni senzor. |
| Nazaj na vrh |
tilz0R Član
Pridružen-a: Čet 31 Maj 2012 15:39 Prispevkov: 900 Aktiv.: 5.33 Kraj: Črnomelj
Objavljeno: Tor Okt 08, 2013 12:15 pm Naslov sporočila: |
Maxim
DS1307 RTC module _________________ Knowledge sharing is caring.
| Nazaj na vrh |
Pridružen-a: Pon 23 Avg 2004 16:16 Prispevkov: 16777190 Aktiv.: 67897.57
Objavljeno: Tor Okt 08, 2013 1:22 pm Naslov sporočila: |
| Nazaj na vrh |
