NASTAVITEV TLAČNEGA STIKALA
Pojdi na stran Prejšnja  1, 2
Aktiv.: 32.60
PrispevekObjavljeno: Sob Dec 22, 2012 12:12 pm    Naslov sporočila:   Odgovori s citatom
EVO PTA12 NA TEM LINKU IMA SIGURNO DVA VIJAKA, KER JO IMAM DOMA.
MANOMETER LAHKO MONTIRAŠ NA PROSTI IZHOD ALI PA PRED SPOJKO IN TI BO KAZAL DEJANSKI TLAK V POSODI. TISTI DRUGI PA TI KAŽE NASTAVLJEN TLAK V CEVI, KI GA NASTAVLJAŠ NA REGULATORJU, SEVEDA BO TAK TLAK SAMO NA IZHODU, KI GRE IZ REGULATORJA. NA IZHODU DIREKTNO IZ STIKALA DOBIŠ POLNI TLAK V POSODI.
DEJSTVO PA JE, DA MORA BITI NA TISTI DRUGI PRIKLJUČEK NA STIKALU PRIKLJUČENA CEVKA, KI GRE NA POSODO, AMPAK DEFITIVNO NE DIREKTNO PAČ PA, MORA BITI VMES NEK VENTIL ALI NEKAJ PODOBNEGA ČE PRAV VEM. UPAM, DA BO KDO NAPISAL KAJ JE TOČNO TISTO. KAKOR VEM BREZ TEGA STIKALO NE MORE PRAVILNO DELOVATI.
EVO NEKAJ SEM NAŠEL GLEDE TEGA VENTILA TULE, KJER MED DRUGIM PIŠE, SICER V HRVAŠČINI PA VENDAR:
PA JEDNOSTAVNO JE,TLAČNA SKLOPKA ZA KOMPRESORE IMA SA DONJE STRANE TAKOZVANI RASTERETNI VENTIL KOJI TI VEROVATNO NISI POVEZAO KAKO TREBA...
IZMEĐU KOMPRESORA I BOCE TREBA DA POSTOJI NEPOVRATNI VENTIL A TANKO CREVO KOJE IDE SA SKLOPKE TREBA DA BUDE POVEZANO IZMEĐU KOMPRESORA I NEPOVRATNOG VENTILA ODNOSNO DA RASTERETI GLAVU KOMPRESORA ZA SLEDEĆE STARTOVANJE.
ČE PRAV RAZUMEM, JE TULE NAPISANO DA JE TA VOD ZATO, DA RAZBREMENI KOMPRESOR PRI PONOVNEM ŠTARTU, TAKO DA MOŽNO, DA STVAR VSEENO DELUJE BREZ TEGA. AMPAK PRI NAŠEM KOMPRESORJU GRE TA CEV PREKO NEKEGA VENTILA NA POSODO IN NE NA GLAVO.
Aktiv.: 32.60
PrispevekObjavljeno: Sob Dec 22, 2012 12:25 pm    Naslov sporočila:   Odgovori s citatom
SE OPRAVIČUJEM SEM PODAL NAPAČNE INFORMACIJE. SEM ŠEL POGLEDAT IN UGOTOVIL, DA IMA TA VENTIL TRI PRIKLOPE. EN PRIKLOP GRE NA POSODO DRUGI NA ENO IZMED DVEH GLAV, TRETJI PA NA STIKALO.
ČESA TAKEGA SEVEDA TI NE MOREŠ IZVESTI, KER UPORABLJAŠ HLADILNIŠKE KOMPRESORJE. NISEM PA PREPRIČAN, DA TLAČNO STIKALO NORMALNO DELJE, ČE OSTANE TISTI PRIKLJUČEK PRAZEN.
elsak
Pridružen-a: Čet 30 Sep 2010 22:55
Prispevkov: 571
Aktiv.: 3.18
Kraj: Koroška
PrispevekObjavljeno: Sob Dec 22, 2012 3:05 pm    Naslov sporočila:   Odgovori s citatom
KK PA VEŠ, DA IMA DVA REGULATORJA IN ZA KOLK BAROV JE? NOBENEGA OPISA NI IN TUD CENE NI. PA TUD NE VEM, KAKO SE LAHKO TO NAROČI IN PLAČA?
TUDI ZELO SLABOVIDNI SE UKVARJAMO Z ELEKTRONIKO.
Aktiv.: 32.60
PrispevekObjavljeno: Sob Dec 22, 2012 4:21 pm    Naslov sporočila:   Odgovori s citatom
elsak je napisal/a:
VEM KER IMAM TAKEGA DOMA NA 130L KOMPRESORJU. JE PA ZA 12 BAROV.
SEM ŠELE SEDAJ DOBRO OPAZIL, DA JE TO HRVAŠKA SPLETNA STRAN. MI SMO JO KUPILI NEKJE NA PRIMORSKEM SE NE SPOMNIM VEČ KJE. POKLIČI KAKŠNO LOKALNO ELEKTRO TRGOVINO JIH IMA SIGURNO PA KAK MERKUR VERJETNO TUDI.
elsak
Prispevkov: 571
Aktiv.: 3.18
Kraj: Koroška
PrispevekObjavljeno: Sob Dec 22, 2012 6:03 pm    Naslov sporočila:   Odgovori s citatom
SEM MISLIL DA VEŠ ,D AJE TO CRO SITE.
PRI NAS GA NIMAJO, KER SEM ŽE BIL PREDNO SEM TEGA KUPOVAL. JE REKEL PRODAJALEC, DA JIH DOBIJO IN SEM KLICAL ČEZ PAR TEDNOV IN NIČ. V MERKURJU SEM TUD BIL, GA PA IMAJO SAMO JE PA CENA TOO MUCH.
elsak
Prispevkov: 571
Aktiv.: 3.18
Kraj: Koroška
PrispevekObjavljeno: Tor Jan 01, 2013 4:07 pm    Naslov sporočila:   Odgovori s citatom
VIJAK ZA REGULACIJO PRITISKA, SE NE DA PRIVIT. ČE VRTIM V LEVO STRAN SE ZATEGUJE, ČE PA V DESNO STRAN. POTEM SE PA KAR V PRAZNO VRTI. LAHKO POVRNIM V PRVOTNO STANJE ALI GREM LAHKO KAR NOVEGA KUPIT?
ZA AB IMAM SEDA DOVOLJ ZRAKA, SAMO PREPOZNO ZAČNE POLNIT. IMA SMISEL, DA GA RAZDREM IN POPRAVIM TA VIJAK ALI NE?
elsak
Prispevkov: 571
Aktiv.: 3.18
Kraj: Koroška
PrispevekObjavljeno: Čet Jan 10, 2013 2:42 pm    Naslov sporočila:   Odgovori s citatom
MOGOČE KDO VE.
JE POD NUJNO, DA MORA BITI TLAČNO STIKALO VERTIKALNO MONTIRANO ALI NE?
GA LAHKO MONTIRAM NA T-KOMAD. TAKO DA JE NA ENI STRANI TLAČNO STIKALO, NA DRUGI STRANI V ISTI LINIJI PA IZHOD Z REGULATORJEM IN HITRO SPOJKO?
Stran 2 od 2
Uptime: 501 dni
