Pridružen-a: Ned 19 Sep 2004 22:04 Prispevkov: 16777193 Aktiv.: 70784.54
Objavljeno: Sre Sep 06, 2006 1:50 pm Naslov sporočila: Dolžina USB kabla |
jur Član
Objavljeno: Sre Sep 06, 2006 2:00 pm Naslov sporočila: |
http://www.usb.org/developers/usbfaq/#cab1
1. Why are there cable length limits, and what are they?
A: The cable length was limited by a cable delay spec of 26ns to allow for reflections to settle at the transmitter before the next bit was sent. Since USB uses source termination and voltage-mode drivers, this has to be the case, otherwise reflections can pile up and blow the driver. This does not mean the line voltage has fully settled by the end of the bit; with worst-case undertermination. However, there's been enough damping by the end of the bit that the reflection amplitude has been reduced to manageable levels. The low speed cable length was limited to 18ns to keep transmission line effects from impacting low speed signals.
2. I want to build a cable longer than 5 meters, why won't this work?
A: Even if you violated the spec, it literally wouldn't get you very far. Assuming worst-case delay times, a full speed device at the bottom of 5 hubs and cables has a timeout margin of 280ps. Reducing this margin to 0ps would only give you an extra 5cm, which is hardly worth the trouble.
Jur |
Glitch Član
Pridružen-a: Pet 07 Apr 2006 11:40 Prispevkov: 1477 Aktiv.: 6.32
Objavljeno: Sre Sep 06, 2006 2:18 pm Naslov sporočila: |
Za foro (ker sem vedel kaj bo) sem poskusal podaljsati USB kabel. Uporabil sem dva USB kabla (AA in AB). Jasno, naprava ni delala. |
jur Član
Objavljeno: Sre Sep 06, 2006 3:00 pm Naslov sporočila: |
To omejitev dolžine so naredili zanalašč, da bi lahko prodajali USB hube.
Jur |
mucek4 Član
Pridružen-a: Sob 18 Jun 2005 20:52 Prispevkov: 2952 Aktiv.: 12.45 Kraj: Tržič - Mesto med gorami
Objavljeno: Sre Sep 06, 2006 3:07 pm Naslov sporočila: |
Nekje "neuradni" podatki navajajo 10 metrov. Največ kar sem dosedaj rabil pa je bil 5 meterski podaljšek in 3 metre kabel. Stvar dela. |
robert Član
Objavljeno: Sre Sep 06, 2006 5:48 pm Naslov sporočila: |
Meni je Wlan USB kljucek Canyon delal na 2 x 5m + 2m "zelo kvalitetnega" kitajskega kabla-beri najcenejsega kar sem dobil
Moram pa omeniti,da je slo za USB 1.1 _________________ LP Robert |
trobida Član
Pridružen-a: Ned 09 Jul 2006 12:13 Prispevkov: 1250 Aktiv.: 5.42 Kraj: Savinjska dolina-okolica Gornjega Grada
Objavljeno: Sre Sep 06, 2006 6:40 pm Naslov sporočila: |
Robert lahko mogoče malo napišeš kakšna je bila hitrost prenosa podatkov pri taki dolžini kabla? _________________ Lp
Tomaž, S57KO |
mucek Član
Objavljeno: Sre Sep 06, 2006 6:59 pm Naslov sporočila: |
Jaz sem imel priklopljen printer na original narejenem 15m kablu (Manhattan), delalo bp.
LP, Grega |
TOTAL Član
Pridružen-a: Sre 25 Jan 2006 9:18 Prispevkov: 109 Aktiv.: 0.46
Objavljeno: Sre Sep 06, 2006 7:41 pm Naslov sporočila: |
Meni dela printer USB2.0 na 10m+1m imel sem probleme pri inštalaciji, ker mi ni zaznalo printerja sam, ko sem to zrihtal na krajšem delu in nato ustavi še 10m mi dela brez problema. |
robert Član
Objavljeno: Sre Sep 06, 2006 9:27 pm Naslov sporočila: |
trobida je napisal/a: |
Robert lahko mogoče malo napišeš kakšna je bila hitrost prenosa podatkov pri taki dolžini kabla? |
Uporabljal sem ga samo za Netstumbler,ko sem skeniral okolico za odprte mreze.Na zalost je bilo vse dosegljivo zaklenjeno  _________________ LP Robert |
trobida Član
Objavljeno: Sre Sep 06, 2006 9:38 pm Naslov sporočila: |
Aha ni problema Robert. Ima mogoče kdo izkušnje s tem. Recimo imam 10m dolg USB kabel in preko njega na PC prenašam podatke. Se hitrost prenašanja podatkov kaj bistveno spremeni, kot če bi imel [slovenščina je zame španska vas] recimo dolg 1m?
Hvala! _________________ Lp
Tomaž, S57KO |
jur Član
Objavljeno: Čet Sep 07, 2006 10:30 am Naslov sporočila: |
Omejitve dolžine kablov niso povsem eksaktno določljive. Omejitev pove tisto dolžino, pri kateri mora katerikoli kabel tistega tipa za tisti namen še vedno stoprocentno delovati. Ker pa imajo različni kabli različne karakteristike (karkoli je že to), bo z nekim kablom stvar delovala tudi na večjo dolžino od dovoljene. Nedelovanje (slabo delovanje) se tudi ne začne na določenem metru naenkrat, ampak postopoma narašča. Z tem podobno narašča tudi število napak. Če je napak malo, niso opazne, vendar delovanje ni več zanesljivo, oziroma stabilno.
Za prenos podatkov je vsekakor boljši ethernet. Velika hitrost (10, 100 ali 1000 Mb/s) in dolgi kabli do 100 metrov.
Jur |
frank Član
Pridružen-a: Pet 13 Okt 2006 0:52 Prispevkov: 46 Aktiv.: 0.20
Objavljeno: Ned Nov 19, 2006 10:19 am Naslov sporočila: |
Dobijo se USB/Cat 5 vmesniki, ki podaljšajo USB povezave,
poceni verzije, ki se dobijo pri nas gredo nadalnjih 5-10 metrov,
sam pa imam varianto, ki gre 150m, a stane precej, preveč za hobi uporabo
imam tudi enega, ki prenaša tudi napajanje, na koncu pa ima tudi hub 1/5
na net-u se jih najde pod "USB extender" |
