Branez Moderator
Pridružen-a: Pon 14 Apr 2003 7:21 Prispevkov: 7831 Aktiv.: 33.02 Kraj: Koprivnica HR
Objavljeno: Ned Avg 25, 2013 4:38 pm Naslov sporočila: |
mucek je napisal/a: |
AGM in podobni tipi teh problemov načeloma nimajo ... |
Kaj pomeni "AGM"? _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
ro-bi Član
Pridružen-a: Ned 28 Jan 2007 16:53 Prispevkov: 3580 Aktiv.: 15.98
Objavljeno: Ned Avg 25, 2013 4:42 pm Naslov sporočila: |
Jaz pri starejšem akumulatorju naredim par ciklov polnjenja na 15v z večjim tokom (10-15A max) in praznjenja prav tako z večjim tokom. Za praznjenje dam 1,2mm žico med dvoje klešč , da dobim željen tok (tudi 10-15A) in potem izpraznim do 10v. To večkrat ponovim in vsakokrat se pozna, da aku pridobiva na moči (če je seveda še dober). Če je zanič, potem med polnjenjem ne potegne toka in med praznjenjem se takoj sesede.
Za 7,2Ah aku bo seveda tak tok prevelik, morda 2-3A bi pa moral dati od sebe. _________________ 3 x 3 = 9 |
mucek Član
Pridružen-a: Tor 01 Avg 2006 10:47 Prispevkov: 5531 Aktiv.: 24.04 Kraj: Domzale
Branez Moderator
Objavljeno: Ned Avg 25, 2013 4:57 pm Naslov sporočila: |
Še vedno ne vem kaj pomeni "AGM". _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
mucek Član
Objavljeno: Ned Avg 25, 2013 5:18 pm Naslov sporočila: |
Koda: |
VRLA batteries are commonly further classified as:
Absorbed glass mat (AGM) battery
Gel battery ("gel cell") |
In AGM sealed batteries, the acid is absorbed between the plates and immobilized by a very fine fiberglass mat. No silica gel is necessary. This glass mat absorbs and immobilizes the acid while still keeping the acid available to the plates. This allows a fast reaction between acid and plate material.
The AGM battery has an extremely low internal electrical resistance. This, combined with faster acid migration, allows the AGM batteries to deliver and absorb higher rates of amperage than other sealed batteries during discharging and charging. In addition, AGM technology batteries can be charged at normal lead-acid regulated charging voltages, therefore, it is not necessary to recalibrate charging systems or purchase special chargers.
(http://www.dcbattery.com/agmtech.html)
smotanc Član
Pridružen-a: Ned 20 Jan 2008 20:38 Prispevkov: 81 Aktiv.: 0.38 Kraj: Šentvid pri Stični
Objavljeno: Ned Avg 25, 2013 10:03 pm Naslov sporočila: |
ro-bi mislis da je pametno praznit akumulator do 10V |
Profesor Einstein Član
Objavljeno: Pon Avg 26, 2013 10:54 am Naslov sporočila: |
Zdravo
Bo potrebno izdelati en mali pcb in 24V žarnice gor obesiti kot breme (se dobijo 40W, 60W in 100W)
in sam izklopi ko pade do 10V, ker ponavadi to nastaviš in greš... te ni doma celi dan, da bi stal zraven in gledal kdaj bo padlo na 10V
Verjento je za uspešno oživljanje tudi pomembno pri kakem toku glede na kapaciteto naj pade na 10V ?
Ko prideš domov pa daš polnit.
Lp.
Darko _________________ --
Nazadnje urejal/a Profesor Einstein Tor Avg 27, 2013 8:23 am; skupaj popravljeno 1 krat |
ro-bi Član
Objavljeno: Pon Avg 26, 2013 7:35 pm Naslov sporočila: |
Ko ga probam obudit, grem do 10V, drugače je pa odvisno od tipa akumulatorja, do koliko lahko gre. Za AGM se mi zdi, da je meja za uporabo 10,7V. Ampak za uporabo je mišljeno, da to storiš večkrat, med mojim oživljanjem pa se to zgodi samo parkrat.
Pomembno je tudi, da ga na taki nizki napetosti ne pustiš daljši čas, ampak ga čimprej napolniš. _________________ 3 x 3 = 9 |
Uptime: 500 dni
