Pridružen-a: Pet 24 Sep 2004 21:58 Prispevkov: 14228 Aktiv.: 60.03 Kraj: Divača (Kačiče)
Objavljeno: Tor Sep 03, 2013 1:49 pm Naslov sporočila: L: Mostični Ohm meter NORMAMETER R1 |
Naslov pove vse, kar ni v naslovu je na slikah.
Začetna cena je 15€, viša se po 1€, Licitacija traja do 8.9.13 22:00.
111.68 KB |
4 krat |
63.16 KB |
0 krat |
58.31 KB |
0 krat |
52.52 KB |
0 krat |
97.67 KB |
0 krat |
S55EI Član
Pridružen-a: Pet 21 Maj 2010 12:47 Prispevkov: 569 Aktiv.: 3.10 Kraj: Postojna
Objavljeno: Tor Sep 03, 2013 3:35 pm Naslov sporočila: |
15€
_________________ Lep pozdrav, Marko |
Objavljeno: Ned Sep 08, 2013 7:08 pm Naslov sporočila: |
Še nekaj ur,...
Objavljeno: Pon Sep 09, 2013 12:28 am Naslov sporočila: |
Zmagal si v licitaciji. No zdaj pa res lahko prideš,....
munuainen Neznanec
Pridružen-a: Pon 14 Okt 2013 10:24 Prispevkov: 1 Aktiv.: 0.01
Objavljeno: Pon Okt 14, 2013 11:16 am Naslov sporočila: |
Hi there and greetings from Scandinavia!
Sorry to bump up an old thread, but there's something I need to ask.
I recently found an identical device discarded. I've been trying to figure out what it is and a google search gave me some hints, including this thread. I've understood this is some sort of in-the-circuit ohm meter, based on wheatstone bridge or similar.
What I still need help with is figuring out the purpose of some contact terminals. There are three terminals on the left side of the device. I suppose the two of them, marked + and - in my device, are for feeding external measuring voltage if you don't want to use an internal battery. It appears the third one is in same potential with one of the ohm measurement terminals on the top of the device, the one left to the X mark. I wonder why this additional terminal has been included in the device...anyone?
Also the purpose of the two terminals on the bottom side of the device is still unknown to me.
Help would be very much appreciated. Thanks!
S55EI Član
Objavljeno: Pon Okt 14, 2013 12:03 pm Naslov sporočila: |
Hi.
I will disassemble the device to inform you about the terminals. I will do that until end of this week ( sunday) and posted in new thread, because this is the flea market thread.
Best regards, Marko
