[3Dp] STL editor, urejevalnik, zloževalnik
Pojdi na stran Prejšnja  1, 2
besoft
Pridružen-a: Ned 01 Apr 2012 10:22
Prispevkov: 585
Aktiv.: 3.42
Kraj: Žižki - Prekmurje
PrispevekObjavljeno: Pet Apr 25, 2014 4:48 pm    Naslov sporočila:   Odgovori s citatom
Saj se prime, vendar se suport odlomi ali odreže.
damirk
Pridružen-a: Čet 12 Jul 2012 12:39
Prispevkov: 20
Aktiv.: 0.12
PrispevekObjavljeno: Sre Maj 07, 2014 1:57 pm    Naslov sporočila:   Odgovori s citatom
Kroko je napisal/a:
Imam STL datoteko ki bi jo rad natisnil. Problem je, ker je v model v bistvu samo "plašč", za tiskanje pa bi potreboval tudi notranjost.
Mogoče kdo ve kako bi to naredil?
Rešitev je Water Soluble filament s katerim natisneš še notranjost - po tiskanju pa ga namočiš v vodo in notranjost se raztopi...
If your 3D printer has a dual extruder, you can print with ABS/PLA and PVA to build structures which are impossible to make without support material. When your print is done just give it a nice bath in cold/warm water, let the PVA dissolve resulting in a seemingly “impossible” creation made with a FFF/FDM desktop 3D printer. Imagine which complex structures you are now able to print….. Extremely difficult to print models, which were previously only printable with very expensive SLS printers, become available to FFF/FDM 3D printers by making use of a soluble support material like PVA! Think about mechanical applications – such as ball bearings, ball and socket joints, and caged gear mechanisms – which are now available for printing with FFF/FDM 3D printers. Also think about applications, such as being able to make water soluble moulds.
http://www.formfutura.com/175mm-water-soluble-filament-pva.html
http://www.makerbot.com/blog/2011/02/21/makerbot-introduces-water-soluble-3d-printer-filament/
Stran 2 od 2
Uptime: 233 dni
