jure94 Član
Pridružen-a: Sre 05 Maj 2010 17:11 Prispevkov: 433 Aktiv.: 2.23 Kraj: Jesenice / Lj
Objavljeno: Pet Nov 07, 2014 1:12 am Naslov sporočila: Timer in GPIO - STM32F401RE |
Pred kratkim sem se zašel učiti programiranja na ARM in sem izbral STM32F401RE Nucleo board. Trenutno mi pa dela probleme utripanje LED s timerjem.
LED je povezana na PA.5 uporabljam pa TIM2 CH1 (lahko se ga poveže na PA.5, vsaj tako pravi datasheet). Želel bi utripati LED samo z "hardware-om", kot naprimer tukaj.
Sam timer dela, ne znam pa ga povezati na GPIO, da bi upravljal z LED. Če samo gledam UIF bit v SR in glede na to spreminjam izhod, LED utripa, če pa želim delati to samo z TIM2 pa ne več.
Še moja koda (v test.h so samo deklaracije funkcij):
| Koda: |
#include "stm32f4xx.h"
#include "test.h"
//Main program
int main(void){
//initialize:
clk_init();
set_LED();
//set_BTT();
set_TIM2();
//Toggle LED
while(1){
if (TIM2->SR & TIM_SR_UIF){
TIM2->SR &= ~TIM_SR_UIF;
GPIOA->ODR ^= (1 << 5);
while(1){}
//Functions
int32_t clk_init (void) {
//Enable GPIO clock for all ports A and C
RCC->AHB1ENR |= 0x5;
//TIM2 clock enable
RCC->APB1ENR |= 0x1;
return 0;
int32_t set_LED (void) {
//Set PA5 as output
GPIOA->MODER |= (2 << 10);
//Push-pull output
GPIOA->OTYPER &= ~(1 << 5);
//Medium speed
GPIOA->OSPEEDR |= 0x40;
//No pull-up, pull-down
GPIOA->PUPDR &= ~(3 << 10);
//Connect to TIM2
GPIOA->AFR[0] |= (1 << 4);
return 0;
int32_t set_BTT (void) {
//Set PC13 as input
GPIOC->MODER &= ~(3 << 26);
//Set medium speed
GPIOC->OSPEEDR |= 0x4000000;
GPIOC->PUPDR &= ~(3 << 26);
return 0;
int32_t set_TIM2 (void) {
//Set prescaler
TIM2->PSC &= 0x0;
TIM2->PSC = 0x5DBF;
//Set reload value
TIM2->ARR = 0x3E8;
TIM2->CCR1 = 0x3E8;
TIM2->CCMR1 |= (3 << 4);
TIM2->CCER |= 0x1;
//Enable counter
TIM2->CR1 |= 0x1;
return 0;
tilz0R Član
Pridružen-a: Čet 31 Maj 2012 15:39 Prispevkov: 900 Aktiv.: 5.33 Kraj: Črnomelj
Objavljeno: Pet Nov 07, 2014 1:50 am Naslov sporočila: |
Predlagam, da uporabiš std driverje ali hal cube driverje od st. Bo precej lažje tako tebi kot nam, ko gledamo v te registre.
Lahko narediš pwm z timerjem na recimo 1s periodo in 50% duty cycle.
V tvojem primeru timer nima veze z ledico, ti ledico sam togglaš, s tem ko pišeš v ODR register.
Nastavi PA5 kot output, ne kot alternate function. _________________ Knowledge sharing is caring.
majerle.eu | stm32f4-discovery.net |
jmivsek Član
Pridružen-a: Tor 06 Avg 2013 12:41 Prispevkov: 468 Aktiv.: 3.03 Kraj: Ajdovščina
Objavljeno: Pet Nov 07, 2014 2:17 pm Naslov sporočila: |
Takole sem se prižiganja ledic lotil sam z zgoraj predlagano knjižnico STM Standard Peripheral lib na STMVL Discovery ploščici. Spodaj pa še primer generacije 10MHz signala s časovnikom na ploščici STMF4 Discovery, ki je najbližja tvoji.
| Koda: |
// Timers example: LED brightness up/down
#include <stm32f10x.h>
#include <stm32f10x_rcc.h>
#include <stm32f10x_gpio.h>
#include <stm32f10x_tim.h>
void initTimer3(void)
GPIO_InitTypeDef GPIO_InitStruct;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStruct;
TIM_OCInitTypeDef TIM_OCInitStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOC, ENABLE);
GPIO_StructInit(&GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_8; // LED3
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF_PP; // Timer 3 output
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_Init(GPIOC, &GPIO_InitStruct);
GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);
TIM_TimeBaseStructInit(&TIM_TimeBaseStruct);
TIM_TimeBaseStruct.TIM_Prescaler = SystemCoreClock/100000-1; // 0..239 = 10KHz
TIM_TimeBaseStruct.TIM_Period = 1000-1; // 0..999 = 100Hz
TIM_TimeBaseStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStruct);
// Timer3 Output Channel 3 init
TIM_OCStructInit(&TIM_OCInitStruct);
TIM_OCInitStruct.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStruct.TIM_OutputState = TIM_OutputState_Enable;
TIM_OC3Init(TIM3, &TIM_OCInitStruct);
TIM_Cmd(TIM3, ENABLE);
void setDutyCycle(int percent)
TIM_SetCompare3(TIM3, percent*10);
void delay(int ms)
int i;
for (i = 0; 100*ms > i; i++) ; //how much is ms?
int main(void)
int i;
initTimer3();
while(1){
for (i = 0; i < 100; i++){
setDutyCycle(i);
delay(200);
for (i = 100; i > 0; i--){
setDutyCycle(i);
delay(200);
| Koda: |
// 10MHz signal from Timer9 on PE5
#include <stm32f4xx.h>
#include <stm32f4xx_rcc.h>
#include <stm32f4xx_gpio.h>
#include <stm32f4xx_tim.h>
void initTimer(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM9, ENABLE);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;
GPIO_Init(GPIOE, &GPIO_InitStruct);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource5, GPIO_AF_TIM9);
TIM_TimeBaseStruct.TIM_Prescaler = 0; // SystemCoreClock/10000000-1;
TIM_TimeBaseStruct.TIM_Period = 16;
TIM_TimeBaseStruct.TIM_ClockDivision = 0;
TIM_TimeBaseInit(TIM9, &TIM_TimeBaseStruct);
TIM_OCInitStruct.TIM_Pulse = 8;
TIM_OCInitStruct.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM9, &TIM_OCInitStruct);
TIM_Cmd(TIM9, ENABLE);
int main(void)
initTimer();
while(1);
jure94 Član
Objavljeno: Pet Nov 07, 2014 5:07 pm Naslov sporočila: |
Hvala za odgovore ampak to ni to kar iščem. Če bi hotel uporabiti knjižnjico, bi jo.
Zanima me kako povezati TIM2 na GPIO in z njim utripati LED. Naprimer, ko je vrednost v TIM2_CNT = TIM2_CCR1 naj avtomatsko preklopi LED. V TIM2_CCMR1 sem nastavil OC1M na 011 in GPIOA_MODER5 na 10 (torej "alternate function 1" na PA5).
Zanima me, kaj sem pozabil oz. ali je to sploh možno tako, kot sem si zamislil in, kot je narejeno na primeru, ki sem ga podal?
Tako, da spremljam vrednost in ko je CNT=CCR1 pišem v ODR register znam ampak to ni to kar želim. |
S53DZ Član
Pridružen-a: Čet 28 Apr 2011 9:27 Prispevkov: 951 Aktiv.: 5.22 Kraj: Ljubljana
Objavljeno: Pet Nov 07, 2014 5:25 pm Naslov sporočila: |
a) šteješ (poženeš timer) in v zanki, če ni drugega dela, preverjaš, ali si že na neki cifri,
b) nastaviš match register, da ti to avtomatsko preverja.
in potem enkrat prižgeš LED, drugič ga ugasneš. |
tilz0R Član
Objavljeno: Pet Nov 07, 2014 5:40 pm Naslov sporočila: |
Spodnja koda vsako sekundo toggla izhod, praktično to pomeni frekvenco 0.5Hz.
Ne bom se spuščal na tvoj nivo programiranja, če bi rad v bite spremenil, izvoli
PS: koda je samo skopirana iz moje strani in ustrezno predelana za F401, zato se lahko zgodi, da so kakšni komentarji napačni.
| Koda: |
* OC toggle mode TIM2 -> PA5
* @author Tilen Majerle
* @email tilen@majerle.eu
* @website http://stm32f4-discovery.com
* @ide Keil uVision 5
#include "defines.h"
#include "stm32f4xx_rcc.h"
#include "stm32f4xx_gpio.h"
#include "stm32f4xx_tim.h"
void TM_LEDS_Init(void) {
/* Clock for GPIOA */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
/* Alternating functions for pins */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_TIM2);
/* Set pins */
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStruct);
void TM_TIMER_Init(void) {
TIM_TimeBaseInitTypeDef TIM_BaseStruct;
/* Enable clock for TIM2 */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/* Max frequency for timer */
TIM_BaseStruct.TIM_Prescaler = 0;
/* Count up */
TIM_BaseStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_BaseStruct.TIM_Period = 83999999; /* Toggle output every 1 second => TIM2 = 32bit */
TIM_BaseStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_BaseStruct.TIM_RepetitionCounter = 0;
/* Initialize TIM2 */
TIM_TimeBaseInit(TIM2, &TIM_BaseStruct);
/* Start count on TIM2 */
TIM_Cmd(TIM2, ENABLE);
void TM_OC_Init(void) {
TIM_OCInitTypeDef TIM_OCStruct;
/* Common settings */
/* Set toggle mode */
TIM_OCStruct.TIM_OCMode = TIM_OCMode_Toggle;
TIM_OCStruct.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCStruct.TIM_OCPolarity = TIM_OCPolarity_Low;
/* Init OC1 */
TIM_OC1Init(TIM2, &TIM_OCStruct);
/* Enable preload */
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
int main(void) {
/* Initialize system */
SystemInit();
/* Init leds */
TM_LEDS_Init();
/* Init timer */
TM_TIMER_Init();
/* Init OC */
TM_OC_Init();
while (1) {
Nazadnje urejal/a tilz0R Sob Nov 08, 2014 1:48 pm; skupaj popravljeno 1 krat |
jmivsek Član
Objavljeno: Pet Nov 07, 2014 7:36 pm Naslov sporočila: |
| Jure, mislim da si pozabil nastaviti Output Compare registrov, zato nimaš nič na izhodnem GPIO pinu časovnika. Tako Tilen kot jaz sva ti poslala primera polne nastavitve, ki ju ni težko preštudirati, nato pa uporabiti tako kot ti - z neposrednim nastavljanjem registrov. |
jure94 Član
Objavljeno: Sob Nov 08, 2014 1:47 pm Naslov sporočila: |
No pa še zaključek. Kriv sem sam, ker sem narobe/površno prebral del glede nastavitve GPIO alternate function registra. Sem pa iskal napake v nastavitvah timerja, ker sem bil prepričan, da so GPIO registri pravilno nastavljeni.
Takole sem imel prej: GPIOA->AFR[0] |= (1 << 4);
to je pa pravilno: GPIOA->AFR[0] |= (1 << 4*5);
Lp |
zaz Član
Pridružen-a: Pon 06 Apr 2015 14:23 Prispevkov: 89 Aktiv.: 0.66 Kraj: Ljubljana
Objavljeno: Ned Nov 08, 2015 11:21 pm Naslov sporočila: |
| Bom še jaz nekaj vprašal glede timer-jev. V datasheet-u za STM32f4-discovery piše pri timer-ju 2 in 5, da štejeta navzgor, ko dosežeta določeno vrednost se izvede overflow event. Zanima me kaj natančno je ta overflow event in kako bi ga lahko zaznal? |
tilz0R Član
Objavljeno: Ned Nov 08, 2015 11:22 pm Naslov sporočila: |
Overflow event je takrat, kadar se števec resetira nazaj na 0.
Zaznaš ga tako, da vklopiš timerjev globalni interrupt, ter overflow interrupt za tvoj timer. _________________ Knowledge sharing is caring.
zaz Član
Objavljeno: Čet Feb 18, 2016 7:12 pm Naslov sporočila: |
pri uporabi TIM7 sem naletel na težavo. TIM7 deluje z frekvenco 84MHz. Želel sem, da se vsako 1us tvori interrupt, zato sem v kodi, zapisal, da naj šteje do 84.
TIM_Time_Base_Structure.TIM_Period = 84;
Rezultat tega pa je, da se interrupti tvorijo v precej daljših časovnih obdobjih.
V nastavitah timer-ja ne uporabljam Prescaler-ja.
Celotna koda nastavitve timer-ja
| Koda: |
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
TIM_TimeBaseInitTypeDef TIM_Time_Base_Structure;
RCC_ClocksTypeDef RCC_Clocks;
TIM_Time_Base_Structure.TIM_ClockDivision = 0;
TIM_Time_Base_Structure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM7, &TIM_Time_Base_Structure);
koda prekinitvene rutine:
void TIM7_IRQHandler(void)
if(TIM_GetITStatus(TIM7, TIM_IT_Update) != RESET)
GPIO_ToggleBits(GPIOD, RED_LED);
Timer_Count++;
TIM_ClearITPendingBit(TIM7, TIM_IT_Update);
tilz0R Član
Objavljeno: Čet Feb 18, 2016 7:25 pm Naslov sporočila: |
Tim Prescaler na 0 ter preveri PLL. Bi rekel da ne dela prav.
Kaksen vir ure imaš?
Drugače mora timer štet do 83, ker od 0 do 83 = 84 vrednosti
Je interrupt prepočasen za približno 3x ali približno 1.5x? _________________ Knowledge sharing is caring.
zaz Član
Objavljeno: Čet Feb 18, 2016 7:37 pm Naslov sporočila: |
Kako preverim PLL?
Uro imam nastavljeno prek vodila APB1, kjer je hitrost 84MHz če sem pravilno razumel.
Interrupt bi rekel, da je več kot 3x prepočasen, ker zalo jasno vidim utripanje led diode, ki toggl-a ob vsakem interruptu |
tilz0R Član
Objavljeno: Čet Feb 18, 2016 7:44 pm Naslov sporočila: |
system_stm32f4xx.c:
PLL_M = stevilka, enaka tvoji vhodni frekvenci kristala v MHz. (če ga nimaš, uporabi 16, to je interni clock), recimo za 8MHz kristal uporabi 8.
PLL_N = 336
PLL_P = 4
PLL_Q = 7.
stm32f4xx.h:
HSE_VALUE vrednosti tvojega kristala. Če imaš 8MHz uporabi 8000000.
Ura APB1 vodila za tvoj MCU je 42MHz ob pravem PLL, ampak TIM dela pa z 2x to frekvenco v tvojem primeru, če imaš inicializirano kot je v tem primeru. Glede na link uporabi TIM7 namesto TIM4 in upoštevaj frekvenco TIM7 84MHz ob pravi nastavitvi PLL-ja.
Prescaler daj timerju na 0. Clock division ni prescaler! _________________ Knowledge sharing is caring.
zaz Član
Objavljeno: Pet Feb 19, 2016 5:31 pm Naslov sporočila: |
Sem poskusil konfigurirat časovnik po tistem na tvoji stran pa ne najdem nikjer kolikšna je vrednost TIM_CKD_DIV1
Poskusil sem tudi spremeniti vrednosti v navedenih datotekah, čeprav mi ni jasno zakaj bi bile že zapisane vrednosti napačne, saj so vse plate iste. |
