kose19 Član
Pridružen-a: Sre 02 Mar 2005 19:37 Prispevkov: 1228 Aktiv.: 5.18 Kraj: okolica Kobarida
Objavljeno: Ned Mar 06, 2016 9:32 pm Naslov sporočila: |
S katerimi kitajskimi arduino izdelki ste že programirali v bascomu?
Ste direkt na pine avr-ja priklopili programator?
Če lahko malo izkušnje in pristop opišete, ker nebi rad nekaj kupoval in potm metal v kanto  _________________ - Absens, carens -
Branez Moderator
Objavljeno: Ned Mar 06, 2016 9:36 pm Naslov sporočila: |
Čitaj! _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
kose19 Član
Objavljeno: Ned Mar 06, 2016 9:42 pm Naslov sporočila: |
to je bilo pa hitro
bom prebral in se naučil kaj novega. _________________ - Absens, carens -
Branez Moderator
Objavljeno: Ned Mar 06, 2016 9:44 pm Naslov sporočila: |
Teh pet besed tam na linku še nisi prebral?
I’ve made a small program that can be used to upload your own *.hex files to arduino boards using the bootloader. That means you don’t need a flash programmer. I made it for my own use and found it pretty useful. So now I’ve made a more user friendly version..
To use it compile you’re code in something like AvrStudio. Then simply start XLoader.exe, pick a hex file and press upload. That’s it.
Good news it now also supports Arduino Uno.
Hope you find it useful… Please contact me about bugs or suggestions. |
Albert Einstein |
kose19 Član
Objavljeno: Ned Mar 06, 2016 9:53 pm Naslov sporočila: |
Sem
Komentarjev še nisem. _________________ - Absens, carens -
Branez Moderator
Objavljeno: Ned Mar 06, 2016 9:54 pm Naslov sporočila: |
Kaj čejo ti komentarji? Priporočila so važna! _________________ The true sign of intelligence is not knowledge but imagination.
Albert Einstein |
solomojster Član
Pridružen-a: Tor 18 Maj 2010 12:26 Prispevkov: 851 Aktiv.: 4.63 Kraj: NOVA GORICA
Objavljeno: Ned Mar 06, 2016 10:28 pm Naslov sporočila: |
Ravno danes sem spustil z xloaderjem hex datoteko na arduino nano. Nekaj časa sem se obotavljal z ide in knjižnicami, potem pa sem preizkusil ta program. Torej, zadevo povežeš z usb kablom določiš vrata, datoteko ...
Sedaj je hex grlb na nanotu in se lepo poveže z bcnc. Sedaj lahko virtualno rezkam na bcnc-ju. |
