Precej star računalnik (Philips P3105) 8088XT
Pojdi na stran Prejšnja  1, 2
C-64
Pridružen-a: Ned 01 Dec 2013 12:14
Prispevkov: 141
Aktiv.: 1.00
Kraj: Lesce
PrispevekObjavljeno: Tor Avg 23, 2016 11:44 pm    Naslov sporočila:   Odgovori s citatom
"Doma imam en mislim da helkules ali celo VGA monitor. Pride komu za prav? Drugače bo končal na smetišču. V računalniku je bilo podganje gnezdo, zato je matična uničena. 5 3/4 disketnik in grafična pa bi morala biti še OK"
Simon - bi me zanimalo. Predvsem, če imaš herkules monitor.
Aleš
C64 je zakon.
retro-guy
Pridružen-a: Tor 20 Avg 2013 23:25
Prispevkov: 170
Aktiv.: 1.18
Kraj: Celje/Ljubljana
PrispevekObjavljeno: Tor Avg 23, 2016 11:59 pm    Naslov sporočila:   Odgovori s citatom
AndreaIta je napisal/a:
OH no! I have a complete NMS 9100 but i lost the case, can any one help me ?
The boot problem is simple to solve, first set Switch to: 1ON, 2 to 7 OFF, 8 ON.
Then Floppy cable must me connect first in the 3,5" drive A and then in 5,25" drive B.
When you on the pc, the sequence is 3.5 (led on), 5,25 (led on) and the last MFM HDD.
Insert a dos system floppy into drive A, and power on.
Pc bust boot correctly.
If not you can do this, switch 2 to On, and disconnect 5.25 floppy drive, and repeat to boot.
If not, problem is floppy drive damaged, Today I also had to try 4 drives.
Try another floppy drive, bust be careful.
Look connector on the floppy drive, normaly all floppy drive have pin 5 absente, all this drive not work, you must search a floppy drive with pin 3 absent.
Today I was going crazy.
i show u my NMS 9100
I hope you find a Philips NMS case for it, what you could do is go on all big vintage computer forums like vogons.org and ask around there
that IBM 5153 cga monitor tho !
Odsoten Poglej uporabnikov profil Pošlji zasebno sporočilo Pošlji E-sporočilo AIM - AOL Instant - naslov Yahoo Messenger - naslov MSN Messenger - naslov
AndreaIta
Pridružen-a: Ned 21 Avg 2016 9:32
Prispevkov: 4
Aktiv.: 0.04
PrispevekObjavljeno: Sre Avg 24, 2016 2:24 pm    Naslov sporočila:   Odgovori s citatom
Simons what, can u write also in english?
SimonS
Prispevkov: 4769
Aktiv.: 20.12
Kraj: Kobarid
PrispevekObjavljeno: Sre Avg 24, 2016 4:20 pm    Naslov sporočila:   Odgovori s citatom
Hi Andrealta
I just write, that I have some old computer at home, monitor and some card, HDD and FDD 5.25 are OK, other is unusable. All this stuff go to C-64
Also have ATARI 512 in original box with external floppy and monitor, and AMIGA 500. But this are not for sale.
I'm also looking for ZX SPECTRUM 48 and C64 in good condition to finish my collection of computer that I use when I was young...
Lep dan
Simon
AndreaIta
Prispevkov: 4
Aktiv.: 0.04
PrispevekObjavljeno: Sre Avg 24, 2016 8:26 pm    Naslov sporočila:   Odgovori s citatom
retro-guy je napisal/a:
Yes retro-gauy, but 5153 is for this Smile
 Velikost datoteke:  1.74 MB
 Velikost datoteke:  1.46 MB
Stran 2 od 2
