Modri laser, HD-DVD...
Aktiv.: 70782.83
PrispevekObjavljeno: Ned Feb 04, 2007 1:12 am    Naslov sporočila:  Modri laser, HD-DVD... Odgovori s citatom
NeoTO
Prispevkov: 2752
Aktiv.: 11.61
Kraj: Trzic
PrispevekObjavljeno: Ned Feb 04, 2007 1:21 am    Naslov sporočila:   Odgovori s citatom
:google:
Drugače pa za Blu-ray:
How fast can you read/write data on a Blu-ray disc?
According to the Blu-ray Disc specification, 1x speed is defined as 36Mbps. However, as BD-ROM movies will require a 54Mbps data transfer rate the minimum speed we're expecting to see is 2x (72Mbps). Blu-ray also has the potential for much higher speeds, as a result of the larger numerical aperture (NA) adopted by Blu-ray Disc. The large NA value effectively means that Blu-ray will require less recording power and lower disc rotation speed than DVD and HD-DVD to achieve the same data transfer rate. While the media itself limited the recording speed in the past, the only limiting factor for Blu-ray is the capacity of the hardware. If we assume a maximum disc rotation speed of 10,000 RPM, then 12x at the outer diameter should be possible (about 400Mbps). This is why the Blu-ray Disc Association (BDA) already has plans to raise the speed to 8x (288Mbps) or more in the future.
Lp,
Matevž
NeoTO
Prispevkov: 2752
Aktiv.: 11.61
Kraj: Trzic
PrispevekObjavljeno: Ned Feb 04, 2007 1:28 am    Naslov sporočila:   Odgovori s citatom
Če te zanima pa še kaj več, imaš tukaj lepo tabelo, kjer so tudi hitrosti napisane:
http://en.wikipedia.org/wiki/HD-DVD
Je pa zanimivo to, da so na idejo z laserjem shranjevat sliko/zvok prišli že leta 1958... [vir: http://en.wikipedia.org/wiki/Laserdisc]
Lp,
Matevž
Glitch
Pridružen-a: Pet 07 Apr 2006 11:40
Prispevkov: 1477
Aktiv.: 6.32
PrispevekObjavljeno: Ned Feb 04, 2007 2:12 am    Naslov sporočila:  Re: Modri laser, HD-DVD... Odgovori s citatom
MarE69 je napisal/a:
A ni bolje, če imaš kar zunanji disk malih dimenzij, velike kapacitete, en hot-plug SATA (a to obstaja), pa še obstojnost podatkov je precej daljša od zapisljivih nosilcev?
Ze v osnovi si zgresil primerjavo, zato pa ne gre skupaj. CD, DVD in ostali podobni nosilci so pravzaprav namenjeni prenasanju podatkov naokoli in ne primarni non-stop uporabi, kot jo imajo trdi diski.
Olaf
Pridružen-a: Tor 14 Nov 2006 20:09
Prispevkov: 127
Aktiv.: 0.56
PrispevekObjavljeno: Ned Feb 04, 2007 3:50 pm    Naslov sporočila:   Odgovori s citatom
Glede na Neotov citat - je potem Blue-Ray tehnologija boljša oz. hitrejša od HD-DVD?
Priznam, da se še nisem poglobil v detalje obeh, saj jih zaenkrat še ne potrebujem. Sem pa predvideval, da je razlika bolj v smeri +R in -R.
To mi deli!
Sokrat
Prispevkov: 5584
Aktiv.: 23.56
PrispevekObjavljeno: Ned Feb 04, 2007 5:00 pm    Naslov sporočila:   Odgovori s citatom
Ne, ni tako podobno, kot sta bila -R in +R. Precej na to temo je napisano ravno v tekoci stevilki Monitorja, ce bi rad bral zbrano gradivo v slovenscini, sicer pa je ogromno informacij (v anglescini) v internetu.
GJ
Prispevkov: 946
Aktiv.: 4.17
PrispevekObjavljeno: Ned Feb 04, 2007 8:04 pm    Naslov sporočila:  Re: Modri laser, HD-DVD... Odgovori s citatom
Mene nekaj zanima: kako hitro gre zapisovanje na te nove nosilce? Malo zgrešeno se mi zdi da se proizvajalci zapisljivih medijev in pogonov tako mučijo s čimvečjimi kapacitetami, če zadeva ni res hitra, oz. vsaj pol tako hitra kot so diski.
Poglavitna je cena nosilca! En DVD nosilec stane še vedno nekaj 100 krat manj kot trdi disk. Torej, za prenos podatkov je DVD povsem zadovoljiv.
A ni bolje, če imaš kar zunanji disk malih dimenzij, velike kapacitete, en hot-plug SATA (a to obstaja)...
Še bolje pa je optika.. Cool
LP GJ
Prispevkov: 16777193
Aktiv.: 70782.84
PrispevekObjavljeno: Ned Feb 04, 2007 8:33 pm    Naslov sporočila:  Re: Modri laser, HD-DVD... Odgovori s citatom
