s56al Član
Pridružen-a: Pon 19 Sep 2005 12:03 Prispevkov: 788 Aktiv.: 3.33 Kraj: JN66SI & JN76TM
Objavljeno: Pet Avg 06, 2021 7:51 am Naslov sporočila: Oddaja slik iz ISS na radioamaterskih frekvencah |
Danes (petek) popoldne in jutri. Za sprejem ni treba neke posebne tehnike. Gre že z "RTL-SDR" USB ključkom in vsaj za silo spodobno anteno. Več v pripetem besedilu.
ZCZC AS09
QST de W1AW
Space Bulletin 009 ARLS009
From ARRL Headquarters
Newington, CT August 2, 2021
To all radio amateurs
SB SPACE ARL ARLS009
ARLS009 SSTV Transmissions Scheduled from ISS
Friday and Saturday, August 6 - 7, Russian cosmonauts onboard the
International Space Station (ISS) will transmit slow-scan television
(SSTV) images from the station on 145.800 MHz FM. They will use SSTV
mode PD-120. The transmissions are part of the Moscow Aviation
Institute SSTV experiment (MAI-75) and will be sent via RS0ISS, the
ham station in the Russian Zvezda (Service) module using a Kenwood
TM-D710 transceiver.
The announced schedule is August 6, 1050 - 1910 UTC and August 7,
0950 - 1555 UTC. Dates and times are subject to change. For stations
in the ISS footprint, the RS0ISS signal should be easy to copy on a
handheld transceiver and a quarter-wave whip. Use 25-kHz channel
spacing, if available. Free ISS software is available to download.
Pass predictions are available from AMSAT via,
https://www.amsat.org/track/ .
Representative images from prior ISS
SSTV events are available in the ARISS SSTV Gallery at,
https://www.spaceflightsoftware.com/ARISS_SSTV/index.php .
Branez Moderator
Objavljeno: Pet Avg 06, 2021 9:52 am Naslov sporočila: |
OpenWebRX web-based SDR receiver S54MTB
Albert Einstein |
mosqito Član
Pridružen-a: Čet 07 Apr 2016 23:22 Prispevkov: 3531 Aktiv.: 31.53
s56al Član
s55m Član
Objavljeno: Sob Avg 07, 2021 7:13 am Naslov sporočila: |
Sandi, a jih prosimo, naj se peljejo malo bolj pocasi? Lepa slikca!
s56al Član
Objavljeno: Sob Avg 07, 2021 7:37 am Naslov sporočila: |
Adi hvala, poskusim danes še kako "uštopat" ! V Bcu gre sprejem velik del preleta bolj na odboje, tu v MB sem pa skrit na S strani Pohorja, tik pod hribom, spet manjka nekaj začetnih / ključnih minut...
114.58 KB |
3 krat |
1.85 MB |
9 krat |
s56al Član
Objavljeno: Sob Avg 07, 2021 7:40 am Naslov sporočila: |
Pa diplomo so "odvrgli" kar med enim od preletov !
https://www.inspace.club/
frenki Moderator
Objavljeno: Sob Avg 07, 2021 10:45 am Naslov sporočila: |
Lepe slikce si uspel ujet.
